Question about Toshiba Televison & Video
I have a Toshiba 57H83, 5 years old. there is a green cast to the picture. This is most obvious when the station is changed and the black is a greenish black and not a sharp color. All the colors are seen, but the contrast and sharpness are not as they should be.
  • Toshiba Master
  • 3,866 Answers
This would be a convergence issue an nothing more then that the convergence needs to be realigned with these old projection systems the SDK IC's do wear from time to time sometime to where the just go and you got a total mis alighend screen "seeing double or triple" The green cast is evident in the wear on the convergence now this can be repaired to look like new but will it last another 5- 10 years I doubt it. The repair might last another year at the most depending on how many hours your putting on the set.
Now you looking at $85 just to have someone come out and TRY to adjust it now if it does not adjust or i does they still walk with the $85 bucks. No one will do work for free unless you have a friend in the business even in that he has to cut his losses.
If the SDK needs to be changed out your looking at $150 just for the placement of those as its hard soldering and de-soldering a convergence board. You might walk with $250 out of your pocket for the total repair you might have to dig further who knows?
I am only telling you that this seems to be a issue with convergence now when the tech gets there and discovers maybe a irregular in the power supply or even fly back do not be shocked but I doubt it since you just seeing green.
Thanks I try to work hard on all my solutions to get you a answer if you can return the favor and click the Accept button I would be more then grateful.
Posted on Nov 17, 2009
Green tint on tv and picture randomly cuts out
Sounds like a Sony, if it uses a lamp the green cast is most likely the optical light engine in the set---major part.
Aug 28, 2012 | Televison & Video
I have a 50'' Panasonic LED monitor TV about 4 years old the past week it has had a green cast to the picture what might be wrong??
Nov 02, 2009 | Panasonic PT-50DL54 50" Rear Projection...
9 year old Toshiba TV. The picture is totally
Symptom shows TV got problem in vertical out deflection section, please check and replace vertical output IC and nearby electrolytic capacitors.
Jun 25, 2009 | Toshiba Televison & Video
No picture; black screen; only red light blinking.
take to a service station i think just changing the displsy IC would do . but check in service centre
Jun 19, 2009 | Toshiba CZ32V61 32" TV
Out of focus tv picture
if you have already adjusted the focus pot on the line o/p transformer (a small transformer with a lead that has a plastic cap attached , and is typically clamped onto the top of the crt/tube BE CAREFUL DONT TOUCH CAP WHEN TV ON VERY HIGH VOLTAGES)
also could be your crt/tube is bad if so then scrap/recycle
cheers
Jun 16, 2008 | Toshiba Televison & Video
Too much green color
Problem solved. I tried playing DVD and the TV picture was fine. So I double-checked cable wires from cable box - one of the wires was loose (obviously it was the red color input). After tightening, the TV picture is good as new.
Mar 20, 2008 | Sony FWD-50PX1 50 in. HD-Ready Plasma...
Suspected Convergence Issue on Toshiba 51H83?
Needs chassis pull & convergence IC's replaced....then
Touch Focus will work again..................T.
Nov 19, 2007 | Toshiba 51H83 51" Rear Projection...
Loss of colour
With the set being 12 years old, I'm sure the picture tube is near the end of its useful life. You probably have a defective semiconductor, either an IC or transistor that has gone up giving you no color, but with the green picture, it is not likely worth repair.
Jan 02, 2007 | Toshiba 36AF61 36" TV
Constant changes in picture colors.
It is a 20" TV set and will most likly, im afraid to tell you, cost more to fix then it is worth. The problem is a bad Picture tube, an intermittant CRT socket or the video jungle IC is intermittant. If you want to invest in an estimate, check out first if it will go towards the repair, as then maybe you can get it fixed at a good price, as long as the picture tube is not the problem Good Luck
Oct 07, 2006 | Toshiba 20AF46 20" TV
Televison & Video Logo
26 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
