Question about GE DCVH515GF Gas Dryer
Error E61 appears on digital screen. dryer does
Error E61 appears on digital screen. dryer does not work at all....... help.... resetting has not helped, technican has no idea......
    Problem Solver:
  • 19 Answers
I was told it was main computer board. Ours got the code when we had power surge.. Not sure how yours happen
Posted on Feb 27, 2010
Replaced heating element now I get error E61, I ohmed out the thermostat on top of heating element seem to be ok
Hello Louie, I appreciate your inquiry!
Based off the information you have provided your Frigidaire dryer is displaying an error code of "E61" after you have replaced the element. An "E61" error code means that there could be an issue with your heater relay or main control board. You may need to seek additional assistance from a professional technician for proper diagnosis and repair. This will help you avoid any unnecessary part purchases. I hope this information is helpful to you. -Matt
Mar 28, 2016 | Frigidaire FASE7073LW Affinity 7.0 cu ft...
Replaced circuit board and i have heat but still shows e61 code
Hello friend, thanks for your post!
Based off what you have described your Frigidaire dryer is displaying an error code of E61. I understand that you have replaced the circuit board and you are still receiving the error code. An E61 means that your heater relay as had a failure which could be a potential problem with your heater relay or a wiring harness. You may need to seek professional assistance with proper troubleshooting this will help you to avoid any further unnecessary part purchases. If you need help locating a local technician you can visit your manufacturer's website for a list of available technicians. -Matt
Aug 05, 2015 | Frigidaire Dryers
I have a Frigidaire Affinity electric dryer model number FASE7021NW0. It suddenly began giving error code E61. I called frigidaire. they said it was likely a shorted wire and put me in contact with an
I appreciate your post, Doug Anderson! From the information you have provided your Frigidaire dryer is displaying an error code of "E61". "E61" stands for heater relay failure which could be a problem with wiring, heater relay, or main control board. I would recommend performing a reset on your dryer and you can do that by disconnecting the power cord for ten minutes. This should help clear out any potential false error codes. Hope this information is helpful. -Matt
Dec 20, 2014 | Frigidaire Dryers
E61 Error code Frigidaire Affinity dryer?
Good Afternoon Friend, this is Z. Thank you for your post!
If you are receiving an error code E61 on your Frigidaire Affinity dryer, first check if it is a false error code by resetting the power to your appliance by either unplugging it or flipping off the breaker for about ten minutes. If the error code persists, it could potentially mean that your dryer is experiencing a failure with the heater relay. This is not a typical DIY job. I would recommend reaching out to an experienced appliance tech just to ensure no troubleshooting step has been missed. You can often locate a qualified service provider through the manufacturer website.
Best regards.
Apr 25, 2014 | Frigidaire Dryers
Error code e61
Identification
  • GE dryers use three-character codes that display on LCD screens. Every code starts with "E" and is followed by a two-digit number.
Power Failure
  • When your home loses power, the "E01" error flashes on the screen. Reset the dryer memory by unplugging the device, waiting 30 seconds and plugging it back in. The error code will disappear.
Thermistor Errors
  • Errors "E02," "E03," "E04" and "E05" are thermistor errors. The thermistor, when operating properly, reads the temperature of the dryer. Errors E02 through E05 indicate the thermistor must be replaced.
Effects
  • When there is an error with the door switch and sensor, the "E60" error code will appear. An unbalanced door will produce the E60 code. Try to close the door gently and listen for the click. If the error remains, the door switch may need to be replaced.
Control Board Errors The control board sends signals from the controls to the dryer. When this fails, errors "E61," "E80" and "E81" appear. Contact GE service or install a new control board for the dryer
Jan 15, 2013 | Electrolux Dryers
E61 appears in screen and 2 beeps. No buttons respond
This code indicates improper voltage was sensed between the neutral and hot. If this code is not clearing then the board was most likely damaged by your situation and would need replacing. Unplugging the unit would reset the control and clear the code if all was fine.
Mar 03, 2010 | GE Dryers
Dark Screen, Lense focus gone and error code: E61:00 - Help!
In this situation (salt water) best thing is rinsing the equipment immadiatelly with tap water and drying it throughly and quickly (with hair dryer etc.) But its been three days, so the internal circuitry and metallic mechanisms are most probably affected from salt water since its highly corrosive. Now, you can send it to your dealer/camera manufacturer for throughly check and repair. I believe nothing you can do right now. And its probably still damp inside, means still affecting by corrosive salt water if you did not already dry it throughly.
Jul 08, 2009 | Sony Cyber-shot DSC-T10 Digital Camera
Open Questions:
GE DCVH515GF Gas Dryer Logo
1,036 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
