Question about Canon PIXMA MX310 All-In-One Printer
To connect to computer so i can print. not sure if cable wire is connected right. please text back asap. thank you.
  • 460 Answers
If your printer has usb capabilities then use that cable.hook it to the computer and loed the driver disc that came with your printer and follow the onscreen prompts..that will get you up and going..
Posted on Nov 17, 2009
Turn on shuts off blue screen B8000028
The steps to resolve this issue on a product that you want to set up with a wireless connection and on a product that you want to set up with a wired, or Ethernet, connection differ slightly. Depending on the connection type you want to set up, select one of the following methods, and then follow the steps provided to resolve the issue.Method one: Resolve the error on a product that uses a wireless connectionStep one: Print a network configuration page
  1. Disconnect the power cord from the back of the product.
  2. Remove the phone or Internet cable that is connected to the back of the wireless router. Do not reconnect this cable until instructed to do so.
  3. Reconnect the power cord to the back of the product. If the product does not turn on automatically, press the On button (c00636182.gif ) to turn the product on.
  4. Make sure that the blue Wireless light is on. If the Wireless light is not on, press theWireless button on the front panel of the product to turn wireless on.
  5. When the product is in the ready state, press and hold the Cancel button for several seconds. The network configuration page prints.
  6. On the network configuration page, check the Network Connection Status line. If the status entry reads Ready , continue with 'Step two: Set the product IP information in the Embedded Web Server (EWS).' If the status entry reads anything else, continue with the next step.
  7. Press the Setup button (c01726396.gif ) on the product control panel, select Network , and then select Wireless Setup Wizard . Follow the instructions in the wizard to complete the configuration.
  8. When the Wireless Setup Wizard is complete, press and hold the Cancel button for several seconds. The network configuration page prints.
  1. Make sure that the computer is connected to the same router that the product is connected to.
  2. On the network configuration page that you printed in 'Step one: Print a network configuration page,' look in the General Information section. Make a note of the following information.
    • IP Address
    • Subnet Mask
    • Default Gateway
    note.pngNOTE:Each of these addresses is in the IP address format. For example, 192.168.1.100 is an IP address. Make sure that you note the numbers and the dots exactly as they appear on the network configuration page.
  3. Open a Web browser, such as Internet Explorer or Mozilla Firefox, on your computer.
  4. Type the product IP address in the address bar of the Web browser, and then pressEnter . The Embedded Web Server (EWS) page for the product opens.
  5. On the EWS page, click the Networking tab.
  6. In the left pane of the Networking screen, select Wireless (802.11) , and then select theIPv4 Configuration tab in the right pane.
  7. Select Manual IP .
  8. In the IP Address text box, type an IP address that is within the range of 192.168.1.10 to 192.168.1.60. For example, the IP address 192.168.1.25 is correct, but 192.168.1.61 is incorrect.
  9. In the Subnet Mask text box, type the Subnet Mask address that you located on the network configuration page.
  10. In the Default Gateway text box, type the Default Gateway address that you located on the network configuration page.
  11. Click Apply to save these settings.note.pngNOTE:After the new IP address is set in the EWS, the computer loses the connection with the product, and the EWS page becomes unresponsive. This is expected behavior. Wait 10 seconds, and then continue with the next step.
  12. Close the Web browser.
Step three: Restart communication and complete the installation
  1. Press the press and hold the Cancel button for several seconds. The network configuration page prints.
  2. Make sure that the product is connected to the network and that the IP address matches the IP address that you typed in 'Step two: Set the product IP information in the Embedded Web Server (EWS).'
  3. Connect the phone or Internet cable to the back of the router.
  4. Continue the product installation. If the software has already been installed, insert the software CD into the computer CD drive, and then select Add A Device from the menu that appears on the computer.
If the installation is successful and the error message does not appear again, the issue is resolved, and there is no need to continue troubleshooting.If the installation is not successful and the error message appears on the product control panel, continue with the steps in the Workaround section.Method two: Resolve the error on a product that uses a wired (Ethernet) connectionStep one: Print a network configuration page
  4. When the product is in the ready state, press and hold the Cancel button for several seconds. The network configuration page prints.
  5. On the network configuration page, check the Network Connection Status line. If the status entry reads Ready , continue with 'Step two: Set the product IP information in the Embedded Web Server (EWS).' If the status entry reads anything else, continue with the next step.
  6. Make sure that the network cable, or LAN cable, is connected to the computer and to the product.
  7. When the product is connected to the network, press and hold the Cancel button for several seconds. The network configuration page prints.
    • IP Address
    • Subnet Mask
    • Default Gateway
  6. In the left pane of the Networking screen, select Wired (802.3) , and then select the IPv4 Configuration tab in the right pane.
  1. Press and hold the Cancel button for several seconds. The network configuration page prints.
Or else remove CMOS battery located on formatter, wait 15mts refix then check..
Oct 06, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
Myy Brother MFC5460 will not print at all. Printer status says it is ready, but the printer never receives the print material. The information remains in the print queue. Work Offline is not checked, so I...
How is it connected?
If its connected via usb cable just follow the steps below:
1. Make sure that Mfc5460cn lcd shows date & time. 2. Disconnect the usb cable from the computer and printer. 3. Turn off the printer and unplug it from the power outlet. 4. On the computer, cancel the document on queu. Go to printers folder and right click on the Mfc5460cn icon and left click on cancel all documents. 5. Reconnect the usb cable from the printer then to your computer. Make sure that it is connected securely. 6. Plugged the printer back to the power outlet and then wait for the lcd to show date & time. 7. Open the printers folder again. Make sure that the status is ready document 0 8. Right click on MFC5460cn then left click on properties. ON the lower left side of the window click on print test page.
The printer should print a test page. And it should work,
Hope this helps. Rate if it works. Thanks
Apr 09, 2011 | Brother MFC-5460CN InkJet Printer
Installed sucessfully the hp laserjet 1018 printer but can't prind any page.
If you're using a Windows based computer, you may follow the steps below:
1. Go to the Control Panel and double click the "Printers" icon.
2. Look at the HP Laserjet printer icon and make sure that the status is ready.
3. If not, right click on the printer icon and click on "Use printer online".
4. Right-click on the printer icon again and select Properties.
5. Click the "Print a test page" button under the general tab
If the same problem occur, check the printer manual and make sure that the printer is compatible with the OS of your computer. And be sure that you install the right driver of your printer to the computer.
Lastly, you may try to uninstall and re-install the printer driver.
Thank you and good luck!
Dec 13, 2010 | HP LaserJet 1018 Printer
Hi, I have an HP Officejet 7310 All-in-One but also have 1 computer and 1 laptop on different floors, both of which I need to print from! How can I connect 2 computers to this same printer please? I've...
the machine has built-in 10/100 Ethernet port connect it to a wireless router and you can set it to share with anything connected up to you intranet. Of course add the drivers is a must to yor PCs.
Aug 23, 2010 | HP OfficeJet 7310 All-In-One InkJet...
Cannot print, i've already change the ink, black and colored.
Check all cables to and from the computer. Also check that the electrical cable is connected to the wall outlet. Be sure that all cables are securely connected and in the right locations and turn the printer on.
Step 2Try to print a test page. Click "Start", "Control Panel" and "Printers". Right click the printer. On the "General" tab click "Print a Test Page". Click "OK" if the printer prints the test page correctly. If not, follow the onscreen directions for trouble shooting.
Step 3Open Notepad and type some text into the window. Select "File" and "Print". Select the printer that you are trying to print to and print. If it prints, copy and paste the text into program is giving you problems. Try to print again, if again it doesn't print, then a corrupt font may be the problem. Reinstall the font.
Aug 17, 2010 | Office Equipment & Supplies
When I try to print nothing happens
Check the cable wire if connected well. Remove then attach it back. Restart you computer then try print again. Thank you
Dec 01, 2008 | HP Photosmart C3180 All-In-One InkJet...
Wont print any text
Good day!
That problem happens when the connection of cable is loss from the printer to the unit. Please try to check the cable. If it is on network check if the printer was shared.
Thanks.
Nov 02, 2008 | Epson Stylus C64 InkJet Printer
Connecting USB cannon mp610 printer to computer
You need USB A-B cable and use the USB jack lying on the back-right corner of the printer (not the front one - that is for connecting cameras).
Sep 02, 2008 | Zebra LP 2844 Thermal Printer
Canon i850
Hello  btfsplk,
Me is Vikram Kumar Thumu from India-Hyderabad. I have seen your message and issue on this issue. I would like to provide my suggestions on this issue.
Generally, this issue could happen if the Port selected that is Printer Properties  is not same as the Port connected to the Computer or Notebook, if this is the case the Printer starts Printing Blank pages from Computer . The issue could also happen if the Printer software is corrupted.
To resolve the issue I recommend you to check and try out below options:
1. try to restart the Print Spooler.
2. Make sure that you selected the correct port in the Ports tab of the Printer Properties.
Example: If your Printer uses USB cable to connect the Computer, then make sure that it is USB001 or USB002 is selected in the Ports tab of Printer properties.
Note:  Make sure that Printer is connected to the USB ports of Computer at Rear End and not in front end. Since, front end USB ports in Desktop Computer are meant for USB flash Drive or other USB devices and not for connecting Printers.
Well, I need much more information of your computer so that I can help you further steps of troubleshooting.
So please let me know below information:
1. Version of Operating System that you are using on your Computer.
2. Please let me know the Printer Model number and Serial number along with Manufacturer.
3. Did you receive any other error messages on this issue?
4. Please let me know cable type ( USB/Parallel) that you are using to connect Printer to the Computer.
Please mail the information at thumuvikram@rediffmail.com, I'll be glad to help you with further information on this issue.
Bye .
Oct 15, 2007 | Canon i850 InkJet Photo Printer
MY HP PSC 1315 ALL IN ONE PRINTER
First try and print a test page from the printer .... if its an Hp printer the following link should help http://h10025.www1.hp.com/ewfrf/wc/gener... make sure that the printer test page prints fine. Now if the printer is connected through a USB cable, try and disconnect the cable from both ends ( from the back of the computer and from the back of the printer ) plug it back in. you might get a Found new Hardware popup at the right hand side bottom cornner, if you do then wait for 2 or 3 minutes. It might ask you to inser the installtion cd, so please do so. That should work for you. Try a different usb port from the back of your computer. If it still doesn't work, go to the printers and faxes folder under the control panel and still the printer icon is showing offline, right click on the printer icon click on cancel all documents and then again right click on the printer icon and delete the printer icon. insert the printer installtion cd and it will automatically install all the printer drivers automatically. I got this resolution from *** , those people are excellent.
Jan 22, 2007 | HP PSC 1315 All-in-One Printer
Canon PIXMA MX310 All-In-One Printer Logo
46 people viewed this question
old marine
old marine
