Question about Nokia N95 Cellular Phone
See my report calls for my cellular metrops - Nokia N95 Cellular Phone
How do i reset my metrop pcs lte
You may try default phone and security code to remove restrictions.
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
Sep 04, 2012 | LG Metro Pcs Connect 4g Lte Ms840 Phone...
How do I print a single call report for a FAX previously sent
Printing a fax call report
A fax call report is a brief report that indicates the status of the last fax that was sent or received.
To print a fax call report
1. On the all-in-one control panel, press Menu.
2. Use the < or the > button to select Reports, and then press .
3. Use the < or the > button to select Fax Call report, and then press .
4. Press to select Print report now. The all-in-one exits the menu settings and prints the report.
NOTE To set the fax call report to print automatically, see Setting print times for the fax call
report.
Setting print times for the fax call report
You can set the all-in-one to print a fax call report after any of the following events:
? Every fax error (the factory-set default)
? Send fax error
? Receive fax error
? Every fax
? Send fax only
? Never
NOTE If you select Never, you will have no indication that a fax failed to be transmitted
unless you print a fax activity log.
To set the print times for the fax call report
Use the following steps to set when the fax call report is printed:
4. Press the > button once to select Print report, and then press .
5. Use the < or the > button to select the option for when you want the fax call reports to be printed.
6. Press to save your selection.
The following print-time options are available:
Including the first page of each fax on the fax call report
If this option is turned on and the page image still exists in the all-in-one memory, the fax call report
includes a thumbnail (50% reduction) of the first page of the most recent fax that was sent or
received. The factory-set default for this option is On.
To include the first page of each fax on the fax call report
Use the following steps to include the first page of each fax on the fax call report:
4. Use the < or the > button to select Include 1st page, and then press .
5. Use the < or the > button to select On or Off, and then press to confirm your selection.
Jul 06, 2011 | HP LaserJet 3050 All-In-One Printer
I dont know the puk code i never tried to lock my sim card
the only way to recover it is to report it to your network service provider. try to call their customer service assistant in their hotline numbers.
May 30, 2011 | Cell Phones
Some one stole my LG Rumor cell phone, is there anyway I can lock it so they cant use it? Or do I have to call the service provider??
Actually you should call the police and report it, then your carrier.
They will close the imei serial of the phone so no one can ever use it again.
Feb 14, 2010 | LG RUMOR Cellular Phone
Nokia n95 provider call barring, i found a nokia n95 and it's unlocked except when you put a simcard in it and try and make a call it says 'call barring activated' can this be unlocked and if so how????
You'll need PIN2. If that doesn't work then phone is reported lost/stolen and is blacklisted, ie phone wont work, but still can be used as music player...
Jun 26, 2009 | Nokia N95 Cellular Phone
Automatic redialling isd call from my phone nokia n70
someone has hacked your phone or your sim and is making full use of your phone. Whether file a report in police station or change the o thats the only thing you can do. after filing the report the person who is using your phone will be behind the bars.
actually you can save yourself from that person by changing the software of your phone
pls rate me thank you
Feb 14, 2009 | Nokia N70 Cellular Phone
I loss my lg mobile(RD6100) how to stop, to mobile work, SKU: HSLG50J1ZZZZ, MSN;802CYSF0049662, RSN;RLGHS1027010462;
Call your mobile service provider that you have lost your phone.
You may also trying calling your cellular phone
If your phone is found, the person may answer your call.
If you report your phone lost, the phone can be trace back to the you.
Feb 02, 2009 | Cell Phones
Nokia 6500 slide can u get it unblocked ir reported lost or stole
got o settings
then go to phone
then go to call and then go to
send my caller id -- make this to set by network by selection the option....
hope this will work
Jan 08, 2009 | Nokia 6500 Slide Cellular Phone
My nokia 6500 classic has been stolen. How can I block the phone
Sorry for that news.
Yes we should report those stealers. You may try the following ways.
1.Ring your service provider and report it with your IMEI No.
2.Just go to the police and they may find it With sattelites.
3.If you want to more information about "IMEI", pls click here to check: http://www.1010store.com/forum/viewtopic.php?f=2&t=180
Good Luck.
Dec 12, 2008 | Nokia N95 Cellular Phone
Cant make or receive calls
hello i had they same problem it means vodafone hads blocked it the person ou brought it off reported it stolen
Jul 08, 2008 | Nokia 6300 Cellular Phone
Nokia N95 Cellular Phone Logo
15 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
