Question about LG TROMM WM2688H 4.0 cu.ft. Front Loading SteamWasher
Error LE WM0642HW Direct drive System washer is blinking LE How do we repair?
  • 975 Answers
The "IE" code indicates a water inlet problem. If the correct water level is not reached in eight minutes, this code is generated. Check the water inlet valve. Unplug the machine, turn off the water, and remove the water supply hoses. Check the small metal screens inside the openings on the water inlet valve. Make sure they are clear of rust or debris. Check the solenoids using a multimeter or ohmmeter.Check for continuity. A lack of continuity means a bad solenoid and the water inlet valve assy will have to be replaced. I'll attach a photo for reference. Sorry for your trouble and I hope this helped. Best wishes.
Posted on Nov 17, 2009
Error Code "LE" not "IE"... I have the same problem. Manual says to call for service but would like to know if I may fix myself.
Posted on Dec 15, 2009
Error code LE on Kenmore Elite washer mdl **********0
le code on washer indicate washer over load putting a stange on washer motor .performing a reset on washer will normally resolve this error, if the motor still lock up maybe need replace motor
Dec 23, 2017 | Kenmore Washing Machines
Error le on lg direct drive washer what can be done without a repairman
often that is a hall sensor-motor speed/position sensor. common issue. easy replacement. part under $20. check out youtube or repairclinic.com or appliancepartspros.com for how to video. part readily available at above sites or on eBay. just plug in your model number and the parts list will come up. takes about 30 mins tops
Oct 22, 2016 | LG Washing Machines
Lg front load wm conversation moto type le error pls
Hi Jilu, The link below is a list of error codes for your washing machine..... CHEERS..
LG Washing Machine Error Code = LE
LG Washer Error = Drive Motor Locked Error
CHECK / REPAIR / FIX = Check the wire harness connections on the motor and the hall sensor (tachometer). Repair any wiring issues. If the wiring connections check good then check for damaged motor components. Replace if needed. If motor is good the replace the hall sensor.
LG Washing Machine Error Codes Washer Fault Codes
Apr 03, 2016 | LG Washing Machines
Drum starts to move then stops then Le appears and a slight hissing noise from direct drive motor. Looks like intemittant fault
The LE error message means "locked motor error" which means the control is not seeing the motor running.
The problem can be caused by a broken wire or loose connection but the most likely cause of the problem is a bad hall sensor.
The sensor can be accessed by removing the rear panel and the rotor assembly. See the image below for help with this. Remember to unplug the washer first.
Make sure the rotor and drum rotate. Anything blocking the tub rotation might trigger an LE code.
Aug 11, 2011 | LG WD-1080FD Front Load Washer
LG TROMM Direct Drive WM0642HW when filled and started LE light comes on and machine stops, why. how do I reste or fix
LE is for a overload error. Do the following:
1) Unplug machine
2) Drain machine
3) Open machine and rotate barrel clockwise 4 times and counter-clockwise 4 times
4) Plug in, power on, and run regular cycle
Feb 27, 2011 | LG Washing Machines
I have an LG Tromm washer. I start it up it start
LE code stands for locked motor error. When this error code appears in your front load washer it indicates a fault in the motor unit.
1 . Check the connections to the Coil/Stator at the rear of the unit possibly it should be something like a broken wire.
2 . Coil/Stator Assembly will be defective preventing the drive to operate.You should go for a replacement of that assembly.
Thank you !!
Jul 25, 2010 | LG WM0642H Front Load
LG Front load washer LE error
Here is a link to the service manual for your washer...
http://136.166.4.200/contents/Laundry/WM2277/WM2277xx_Service_Manual.pdf
Check page 18 for error code LE which is 'locked motor' There are several causes, the manual will help you determine the cause. If you're not comfortable taking the thing apart, call your appliance repair man...
Oct 11, 2009 | LG WM-2277HW Front Load Washer
"UE" error code LG washer wm0642hw
This is an Imbalance code. Your issue may be with:
  • The load is too small
  • The appliance is tilted
  • Laundry is gathered to one side
  • Non-distributed things are put into the drum
Try adjusting the load size, and make sure the unit is level.
Aug 07, 2009 | LG WM1814CW Front Load Washer
LG WM0642HW washer gives error during spin cycle and stops.
I have this problem and you can find the solution on this same web page by searching. It is likely the Hall Sensor that needs to be replaced (see proflevy posting on Jul 16, 2008). According to the postings, it is from soap build up on the sensor and replacing it costs $18 for the part and is easy (many responses on this). I am waiting for the part and will try to fix mine soon.
Mar 06, 2009 | LG WM-2277HW Front Load Washer
LG Washer LE Error
Yes this is the same Hall sensor as in the WM 2277
You can Order them HERE and have them within a few days.
Easy fix
Jun 14, 2008 | LG WM-2277HW Front Load Washer
Washing Machines Logo
543 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
