Question about AT&T Quickfire Cell Phone
The quickfire reads that there is a microSD card, but I cannot move any files to the microSC card
Pny sdhc card protected
Mini SD cards, or MicroSD cards, are used in digital cameras and portable media players to house digital media files.
MicroSD cards can house anything from 2GB to 32GB of information.
A write-protection feature gives the owner the ability to lock the MicroSD card to keep their files secure.
If you have a MicroSD card that is write-protected, you can un-write-protect it with a flip of a switch.
Insert your MicroSD card into the adapter that came with it.
Put the data side of the MicroSD card into the data side of the adapter.
Look for the write-protection switch on the left side of the SD adapter.
Flip the switch to the side that reads "Off."
Remove the MicroSD card from the adapter and replace it in the device you were using it with.
or you might
Feel along the lower right and left sides of the Micro SD card to find out if it has a built in write protection switch.
Move the switch over to the "On" position to turn on the write protection feature.
Check the front ports on your computer and see if it already has a built in card reading unit.
Purchase an external card reader that plugs into a USB port if your computer does not already have an internal card reader (see below).
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&DEPA=0&Order=BESTMATCH&Description=card+reader&x=0&y=0
Plug the card reader into any open USB port on the computer.
Power on the computer and let the operating system finish loading.
Insert the card into the Micro SD slot on the card reader.
Wait for a new window to appear that will ask what action you want to take with the Micro SD card.
Click on the link that says "Open a folder to view files."
Right-click on a file if there is just one specific file you want to enable write protection for.
Click on the "Properties" link from the menu that will pop up.
Navigate to the "General" tab.
Click on the box marked as "Read Only" and then close the Properties window.
Close the window and then double-click on the "My Computer" icon on your desktop if you want to enable write protection for every file on the Micro SD card.
Right-click on the name of your Micro SD card in the list of computer drives.
Click on "OK" and then close the window.
Click on "Properties" and then navigate to the "Security" tab. Scroll down to the heading labeled as "Permissions."
Click on "Deny" under the "Write" section.
Nov 23, 2013 | PNY 4GB Secure Digital High Capacity...
My memory card as been locked it is not opening and asking the password
Micro Secure Digital memory cards, or Micro SD cards, provide storage for a variety of different kinds of devices, including mobile phones, PDAs and cameras.
They can be protected by passwords so that the information that you have saved on it is secure. Sometimes, the password can be forgotten or lost.
Recovering your password is easily done with your computer and SD card reader on your computer.
Place the micro SD card into your card reader on your computer.
Right-click your "Start" button and then "Explore".
Find the micro SD card, it will be listed as a removable drive.
Click on the micro SD card and the files will show on the right-hand side.
Find the file that says " MMCSTORE" and then select "Copy."
Right-click on your desktop and then click "Paste."
This will move the MMCSTORE file to the desktop so that you can get access to edit it.
Right-click on the MMCSTORE and then click on "Open With." Open the file with Notepad.
Read the text to find the password. It will be in plain text.
Remove the SD card from the computer and place it into the device for which it is used as storage. Turn on the device.
When it prompts you for the password, enter it.
or
Delete a MicroSD Card Password
Some MicroSD cards are password protected, preventing you from using the card without the password.
You can circumvent this restriction by formatting the card, which eliminates the password requirement.
Insert the MicroSD card in your MicroSD card adapter and insert the adapter in the SD slot on your computer.
Right-click "Start" and select "Explore".
Click "Computer" and right-click the drive letter of the MicroSD card.
Select "Format", select the "FAT32" file system from the drop-down menu and press "Enter" to reformat the card.
Jan 24, 2012 | Kingston 1 GB microSD Card with USB 20...
How can i download songs to my cellular memory card?
Hi welcome to Fixya.com. Please follow the Instructions. Instructions
  1. Insert the microSD memory card inside the microSD memory card USB adapter by removing the cover to the USB adapter and slipping the memory card inside it before replacing the cover.
  2. Plug the microSD memory card USB adapter into your computer's USB port.
  3. Locate the music files that you wish to add to your cell phone and drag and drop the files to the USB drive to move them to your microSD memory card.
  4. Remove the USB adapter from the computer and remove the microSD memory card from the USB adapter.
  5. Open the microSD memory card slot located on the side of your cell phone and press the microSD memory card within the slot until it clicks into place.
  6. Go the "Menu" on your phone and click on "Settings and Tools."
  7. Click on "Memory" and then "Card Memory."
  8. Click on "My Music" and then click on "Options" and then "Move."
  9. Check all the music files that you wish to add to your cell phone and then click "OK." Click "Yes" when prompted to confirm that you want to move the files to your cell phone.
Hope this solves your problem. Please feel free to ask questions on Fixya . Have a nice day. Bye
Mar 12, 2011 | Cell Phones
My SD card. wont read on my phone keeps saying empty it is 4 GB and it says it is in but its not showing any pictures up.everything i do dont work. please help me. i tryed everything.
Just a thought: if your PC is able to read the card, copy all the card's contents to the PC's hard drive. Install this program on your PC and use it to format the SD card. Then, copy the files back to your card, and insert it in your phone.
Hope it works for you
Cheers! Carlos
May 14, 2010 | AT&T Quickfire Cell Phone
My quickfire celphone cant read the sd card anymore? i can used and listen to the music player of my phone before but just recently, i tried to use my music player on my celphone but its always says that...
THIS WILL MAKE YOU LOOSE ALL FILES!!!
(even password)
Take the memorycard out of the phone and,
put it in a computer.Use filesystem FAT-32
to reformat your memorycard.
Now the card will work again!
No password, No files will be left after a
complete reformat
This is your solution! Please vote!
Jan 16, 2010 | AT&T Quickfire Cell Phone
Where does the sd card go into my desktop?
You need to use the adaptor that should've came with it. Plug the micro into the adapter and use like regular sd card in computer.
Feb 11, 2009 | SanDisk 2GB microSD Memory Card
How do I get my images on my computer?
Try inserting the card into the computer. Go to start , then my computer, right click on the drive that has the mini sd card. select format. this will restore the disk, emptying it and bring it back to new condition.
Jan 19, 2009 | SanDisk 1GB microSD Memory Card
UTStarcom Quickfire does not recognize microSD card
if you wanna get your quickfire to work with your sd card you need to buy another one but this one has too only be use ONLY for cell phones! if you want more info about what kind too get text this number and i will give you pictures of what kind too get: 601-616-60545
Dec 13, 2008 | Cell Phones
My phone videos save to microSD but wont show up on computer
google "VLC media player" and install their program - it is more tolerant of file types. WMP is very picky. BUT taht may not work either is it is a real weird format.
Nov 23, 2008 | SanDisk 2GB microSD Memory Card
Transferring audio(music) to microSD card for Nextel i870 phone
Is the format of the files correct the phone probably only reads mp3 files so the files you copy to the phone must end in .mp3 not wma.
Nov 20, 2007 | Sprint PM-8200 Cellular Phone
AT&T Quickfire Cell Phone Logo
47 people viewed this question
Top AT&T Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you an AT&T Cell Phone Expert? Answer questions, earn points and help others
