Question about HP Pavilion dv9000z Notebook
My DV9205 finaly stoped working after 2 years of strugle.It was booting only once a day, was getting very hot, display had lots of multicolor dots spred all over.Now she is dead.HP in Australia don't wana know about it, repair in computer repair shop will cost around $1000 AU. A parently motherboard is cooked and replacement is needed. This piece of **** was given to me by my parents, and now am in the ****, couse they blame me for not looking after it. How could I,...you can't make whip out of the **** - can you? so, is there any way that i can get this HP guys in Australia do something for me? John
  • 458 Answers
You need to look On the Recall/Extended Service List To See If Your dv9000 Series Is Listed... Go To The Link I Post Below,
Flip Your Laptop Over And Look For Your P/N......
then look on the list from the link I posted and see if Your P/N is listed in the DV9200/DV9300 Section... If it is there... You can send it to them for a free repair/motherboard replacement.... You will first have to contact them either by Live Chat or by Telephone and explain your Symptoms and that you found your model listed under the extended service list of recalled laptops....
If your laptop is Not Listed there... You Do not need to replace the motherboard, You can Reflow the Graphics Chip... You have a Faulty Nvidia Graphics CHip That has failed due to thermal damage...
THis involves complete disassembly of the laptop, removal of the motherboard... You'll need to shield all areas around the video chip.. Use Folded up tin foil... You'll also need to put weight on top of the Video Chip... Use a stack of 8 Quarters and Center them in a stack on the video chip... You will need a Heat Gun...(google it)... They cost about $15 US.... You will need to cover all plastic ports and connectors near the video chip... cover the CPU, cover the RAM slots...(use the foil)....
Turn on the heat gun, Set it to LOW... Hold about 6 inches from the chip and rotate clockwise in circles around the outer edge of the video chip, then concentrate the heat gun on the stack of quarters holding the heat gun about 3 inches from the quarters..Hold for 30 seconds, continue to rotate around the outer edge of the chip, slowly moving the heat gun closer, then pulling it away... (go no closer than 2 inches away from the chip... the whole process takes 3 minutes.... Do not overheat the chip... it's better to underheat it ans to have to re-do the reflow...
The goal is to Remelt the Solder Ball Contacts on the underside of the chip to re-make contact with the contact pads on the motherboard...
Make sure when you are done with this process that you thouroughly Clean the Heatsink anf Fan assembly!! Very Important!! You need to make sure no dust/debris are blocking the heat sink Cooling Fins... And that the fan blades are as well dust/debris free....
Reassemble entire laptop and Power on....
Posted on Nov 17, 2009
Testimonial: "I didn't find my model on the list, but your idea with reflowing the solder should work - am sure it will. Thanks for the tip John"
I have a hitachi ultra vision tv and had alot of blue dots a then stop working
A lot of blue (or any color) dots suggests a optical issue---depends on model number.
Nov 01, 2012 | Hitachi Televison & Video
Amd 7750 display driver crash
If there are multicolored **** the most common cause of this is probably that your card has been overclocked too high, fortunately this could be fixed by you downloading a software like amd overdrive and clicking on default or reducing your card's clock levels then try to run those games again.
May 10, 2012 | ATI Computers & Internet
Multicolor vertical lines in hp laptop during booting and eventually getting dark and could not see anything else
This is a Hardware Fault. Check, if there is any Update for Graphics Card from HP Unless you need to Send the Unit for Repair.
More often, it is Either a Faulty Display Driver or Video Card.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Jan 10, 2010 | Compaq Presario M2000 Notebook
Have Garmin Nuvi 660, after a few min. I lose sats. was working fine for the last year. Just the other day it started. I was in the mountains/ bad weather so I thought that was the problem. I have update...
Try this and see if it fixes your problem...follow these steps.
1. Power off the unit.
2. HOLD down the power button and you will see "Pre Boot Mode" appear on the lower part of the display. KEEP HOLDING the power button down and the display will flicker, do this until the pre boot mode message disappears. This seems to take a long time (60 seconds at least).
3. Once the pre boot mode message disappears release the power button and your device will perform some activites to try recover from the problem.
Dec 24, 2008 | Garmin Nuvi 660 GPS Receiver
Booting problems with my Toshiba Satellite P105
Try to reinstall the video driver from Safe mode.
It appears your hard disk is OK but the operating system and or registry is corrupted.
1. Try installing the video driver first.
2. If it still does not work, back up your data files in Safe Mode then re-install XP again, make sure you delete the partition and create a new partition and do a full NTFS format, not a quick format.
Nov 12, 2008 | Toshiba Satellite A25-S207 Notebook
9300 display issues
sounds to me like u r video card has an issue, or it could be the display on it's way out, that problem is really hard to resolve without personally looking at it and toy around with it, I would suggest contacting Dell tech support chat and let them go inside remotely and check it out inside and run a diagnostics on it, if you shut the system off and then restart it and hold the Fn key down you unit should run a diagnostics that should tell you your problem.
hope this helps out and let me know what you find out!
Thanks
Dennis
Jun 16, 2008 | Dell Inspiron 9300 Notebook
Blue dots in the middle of the screen
The image processor must be getting old and worn out. Call Epson or go onto their website and see if it is  a dDIY project or if you will ned to send it in.
Apr 27, 2008 | Epson EMP S1 Multimedia Projector
HP Pavilion dv9000z Notebook Logo
262 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
