Question about GE (PSS26MSRSS) Side by Side Refrigerator
GE fridge and dishwasher
GE Model#GSS25SGRE SS - makes howling noise intermittently.
GE dishwasher - banging/clanking pipes when water is filling.
what to do
  • 4 more comments
  • Kstoner Feb 11, 2008
    Our side by side (GE) howls as well and apparantly is coming from the freezer. It's very annoying and it sounds like you're in Alaska during a windstorm or snow storm.
  • Anonymous Feb 13, 2008
    My ge side by side howls alot every now and then and it comes from the freezer by the ice maker.
  • Smorton Feb 28, 2008
    Refrigertor started howling just as the warranty expired. Freezer freezes up after about 4 days. Freezer and refrigerator are set on 5 not really high for this to happen every 4 days. As the howling gets louder I turn the refrigerator off and let the refrigerator thaw for 2 days remove the panel from back of freezer side to make sure all ice has meltd.
  • sumosmoker Jan 20, 2009
    My GE side by side is also making an intermittent howling noise. The ice maker works but it will only dispense crushed ice and not whole ice cubes even when it is on the cubed ice setting. Are these somehow connected? Also, is it worth getting an actual GE service guy come out ($85 just to show up) or should I call a local (grand prairie, tx) appliance repair company?
  • Gary Davd
    Gary Davd May 11, 2010
    the fan mtr will need to be replaced ...The banging is Water Hammering you will need to turn down your pressure or install a bellows tank on you lines
  • Anonymous Mar 29, 2014
    Also water flow slows way down when making the noise.
  • 35 Answers
For GE Model# GSS25SGRESS
replace the evap fan motor in the freezer..or have it checked
PART# WR60X10185 W/O THERMISTOR
PART# WR60X10074 WITH THERMISTOR
Posted on Mar 02, 2008
  • Dave Mar 02, 2008
    if the freezer is freezing up replace the heater and bracket assy. # WR51X10055 ALSO
GE Model GSH25JSRF SS is clicking non stop, the click comes from a small panel on the back right of the fridge. Started out that the water and ice dispenser didn't dispense. Then the clicking just came...
Is it still cooling? I had an issue where there was a clicking noise from the back panel and the fridge did not cool. Pulling off the panel the noise seemed to from a box on the circuit board. Turns out there was a problem with the controler board and after some research I found that the board was covered under a recall. GE ended up sending a guy out to replace the board at no charge. Pretty cool being that if was after the warranty had expired; but I guess it makes sence since there was a recall. Good luck.
Dec 10, 2009 | GE GSH25JFR Side by Side Refrigerator
GE Model PSC23SGRC SS Serial #RH418861. Refrigerator make a howling noise Dave eci.david@gmail.com
I suggest a defrost with doors open over night, what often happens with this model is that you get an ice build up near the fan which causes an extremly loud noise, very common problem.
Sep 07, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Our new LG dishwasher makes loud clunking noise
I believe this is a brand new dishwasher. Please listen carefully to determine of the sound you hear (clunk) is being made inside the dishwasher or is it being made near by. Most times, the problem is that the hot water pipe is baking the noise when the dishwasher closes the water inlet valve ... and the pipe goes "clunk"
I have not had an LG dishwasher make a clunking sound inside itself when the cycle changes. Also, because this dishwasher is so very quiet (well insulated) the pipe banging would be louder than something inside the Dishwasher.
If you have access to the hot water pipe, listen very near it when the cycle changes for the sound. Follow that pipe (hot water) pipe back and insulate it at the point it is banging. (or get a plumber to evaluate and resolve.)
Please get back to me with what you find, OK?
Good Luck!
Apr 06, 2009 | LG LDF6920ST Stainless Steel 24 in....
Loud clanking noise in dishwasher
Most likely the motor as food caught in the sump would not make a noise you described.
http://tclaundryrepair.com/home
Feb 19, 2009 | Kenmore Dishwashers
Howling noise
I don't see anything located directly behind the icemaker on this model. Try to better isolate the location of noise if you can. If the icemaker is at fault, I wouldn't bother trying to repair. Order another one. One other thing to check is the water flow. When the noise happens again, stick your finger in the ice mold and feel for water. If it just filled, then problem may be in the water valve. Hope this helps,
Oct 27, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Fridge - Model #GSH25JFTA CC - is making a howling noise...
FAN MAKING NOISE BECAUSE OF BAD COMP BOARD, PUT UP WITH NOISE OR REPLACE EXPENSIVE BOARD
Sep 12, 2008 | GE GSS25JEM Side by Side Refrigerator
I also had the same problem (gsh25jfta ww). It did that for a couple of months now the coils freeze up and fridge gets warm. Still looking for solution?
Jul 03, 2008 | GE GSS25JFPCC / GSS25JFPWW Side by Side...
Fridge makes howling noise
Hi there!
Check at the back for any objects or packets that are in contact with a fan. This often causes unusual noises.
See if you can identify the source of the noise, ao I can help further.
Thanks.
Jun 21, 2008 | GE GSS25JFPCC / GSS25JFPWW Side by Side...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
574 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
