Question about Canon PowerShot SD1000 Digital Camera
I have a Canon Power Shot SD1000 my camera will turn on and do everything else but it will not take pictures. The only thing that has happened is that the red/orange light will still come on even when i try to take a picture.
SOURCE: Canon SD1000 display is black while the camera in shot mode
I had the same problem, i literally smacked the sides of it (after reading possible solutions on this page) and i turned it on and off repeatedly and i was surprised when i saw it working again! Give it a try, it worked for me
Posted on Sep 02, 2008
pontelemon
  • 531 Answers
SOURCE: Can I charge the NB-4L battery on my Canon SD1000 through USB
No
Posted on Mar 18, 2009
xdaveyx
  • 8 Answers
SOURCE: how to transfer pictures from my Canon PowerShot
There are two ways of doing this:
  1. Install the software on the CD that came with the camera, then use the USB cable that came with the camera to connect it to the computer. The software should walk you through the rest of the process.
  2. Buy an SD card reader (example Card Reader from Amazon.com), connect it to your computer, and take out the SD memory card from the camera, and insert it into the appropriate card slot on the card reader. Then use whatever photo management software to manage your photos.
I would recommend the second method since it reduces the wear and tear on your camera and allows you to access the photos easier through Windows Explorer or Finder (MacOS).
Hope that helps!
/davey
Posted on Oct 20, 2009
  • 11967 Answers
SOURCE: lens error-restart camera on my canon power shot sd1000
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Dec 26, 2009
SOURCE: My Canon PowerShot SD1000 won't focus. Most
View is not get displaying in the screen when i select other than Easy mode.If i select auto mode it is displaying only the black screen.Any idea why it is like this?
Posted on Jun 02, 2010
Hello, I have a Canon Power Shot sd1000 Digital ELPH. I cant get the time and date stamp to print on the pictures. How can I fix this?
If the pictures are the ones you have shot without time and date stamp, you can't add them by your camera then. You only can add them by your computer.
Aug 31, 2011 | Cannon Cameras
My cameras power seems to work but the screen is all pur black ?? what can i do to fix this???
I have canon power shot sd1000 camera. Every thing is o.k. except that recently the screen stays dark in picture mode and when on for taking pictures. pl let me know.
Feb 03, 2011 | Canon PowerShot SD630 Digital ELPH / IXUS...
My Canon Powershot SD1000 will not turn on. The battery is fully charged.
What you have here on your SD1000 is just a power problem. It happens sometimes on digital cameras. It's unfortunate, but these things do happen. You would need to get the camera fixed which is a good idea considering what a great little camera that is. The site that I'd go to for help with a Canon Powershot would be www.camerasandparts.com The only thing they fix is the Canon Powershot Cameras and they happen to be excellent for service on these. The deal with them, and this is right on their site for your model, they perform the repair with both parts and labor included, you get all of the service for your model included, they give you a great 90 day warranty on anything on your camera for 90 days, and they include priority shipping going back. For your model that all runs $79. They're the place for help with the Powershot Cameras, your problem and service package is available on their site. I hope that will help you with it.
Bill
Sep 23, 2010 | Canon PowerShot SD1000 Digital Camera
Flash Does not work. canon sd1000
This happened to my SD1000 and I followed the step by step instructions shown here:
http://www.ifixit.com/Guide/Replacing+Canon+PowerShot+SD1000+Broken+Flash+Unit/7778/1
and when I got to step 15, I found that the small plug that connects the flash to the camera body had been disconnected when the camera had been dropped. I simply pressed the connection back in tight and reassembled the camera - and it works. Maybe this happened to yours too??
Dec 10, 2009 | Canon PowerShot SD1000 Digital Camera
Whenever I attempt to download pictures off my Canon Power Shot SD1000 onto my HP Pavilian dv6135nr laptop, the computer apparently is not picking up signal from the camera EVEN THOUGH after plugging in my...
does the laptop recognized you canon power shot? if not try installing the software of the canon power shot to your laptop, these camera comes with installation when you purchased it, try to install it, sometimes win xp does not recognized such devices
regards
michae
Nov 19, 2009 | Computers & Internet
My Canon Powershot SD1000 has a fully charged battery but won't turn on at all.
Does your camera turn on when it's in playback mode? I have a similiar problem with mine. It only turns on in playback mode.
Sep 25, 2009 | Canon PowerShot SD1000 Digital Camera
Canon SD1000, screen blacked out and takes black pictures
try taking the batteries and memory card out let it set and put everything back in it ang cut it on
Jun 18, 2009 | Canon PowerShot SD1000 Digital Camera
I have the sd1000 power shot canon. i was taking a picture the camera took the picture as normal but when trying taking another shot i got an lens error restart camera.
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
One thing, you mentioned that the lens error occurred after you wer able to take a good picture. This really sounds like your battery ran down during shooting, and did not have sufficient power to properly shutdown the camera. Focus on your battery as the potential cause first. Note that if the battery is older than a couple years, it may be time for a new one. Rechargeable are not meant to last indefinitely.
Jan 23, 2009 | Canon PowerShot SD1000 Digital Camera
Canon Powershot SD1000. Not allowing to take pictures
Hi
Try turning the flash off and see if you can then take pictures. If that works then your flash is defective and needs to be replaced.
We are a digital camera repair business (Google Darntoothysam) and we can do that repair for you for a very reasonable price, or you can look for a defective camera online and make one good camera from the two.
Good luck from Darntoothysam com
Thomas
Oct 22, 2008 | Canon PowerShot SD1000 Digital Camera
Canon PowerShot SD1000 Digital Camera Logo
27 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
