Question about Remington Electric Pole Saw
Chain won't engage on remington poll saw. Motor
Chain won't engage on remington poll saw. Motor runs.
  • dontbother10
    dontbother10 May 11, 2010
    If you get bad or worthless advice that is what the was this helpful NO flag is for!!!
  • 188 Answers
SOURCE: Remington Pole Saw Model # 106890-020 - Chain Oil Cap broke
Call Master Parts at 1-800-446-1446, or go online at www.masterparts.net. They have the part (107512-01) you need. I hope this helps...
Posted on Apr 27, 2009
  • 188 Answers
SOURCE: I need an owner's manual for a remington electric chain saw
Here is the owner's manual for the M30016AW... http://12.153.20.74/manuals/113005-01G.PDF. Here is also the instructions on the installation for the chain that goes on the your saw ... http://12.153.20.74/manuals/113556-01A.pdf. If you are need of a part you can conatct Master Parts at 800-446-1446, they can also help you. I hope this helps!
Posted on May 27, 2009
  • 188 Answers
SOURCE: what kind of chain oil to use for a 10in remington electric
According to the manufacturer... "Use SAE 30 motor oil for best results. (For temperatures below 30° F, use SAE 10. For temperatures above 75° F, use SAE 40.) DO NOT use Bar & Chain oil." So, I suggest for any Remington electric chains saw not to use bar and chain oil. I hope this helps...
Posted on Jul 07, 2009
dontbother10
  • 2220 Answers
SOURCE: Remington electric Pole Chain saw - what type of oil do I use?
You need “Bar and Chain Oil”, available at hardware stores and home centers. It is SAE 30 with additives to make it adhere to your bar and chain.
An excerpt from a Remington manual follows (edited).
FILLING OIL TANK
1. Remove oil cap.
2. Fill oil tank with SAE 30 motor oil if the temperature is between 30 & 75°F.
• Colder use SAE 10 oil.
• Warmer use SAE 40 oil.
3. Replace oil cap at once. Tighten oil cap firmly for a good seal. This will avoid oil seepage from tank.
4. Wipe off excess oil.
• It is normal for oil to seep when saw is not in use.
• Empty oil tank after each use to prevent seepage.
Some manuals go from page 6 to page 14. This one is very good.
http://shoppingcart.msservicecompany.com/msservice_net/product_files/113005-01D/113005-01D_OM.pdf
If you have more questions or need additional help please reply below and I will get back to you. Good Luck. HTH
Lou
Thank You for using FixYa.
Posted on Apr 24, 2010
  • 760 Answers
SOURCE: I need a replacement motor for a Remington
You can buy this complete saw for about 75.00 on amazon. I've heard of others burning up the field and armature in this model saw. You can buy a homelite electric at Home Depot 50-75 depending on model. Doesn't seem like it would be worth fixing, only to have it burn up again. Sounds like it needs a thermal overload to prevent damage. GOOD LUCK1
Posted on Jul 01, 2010
Trouble starting
Remington Pole Saw Carbon Brushes
If you're Remington Pole Saw is slowing down, throwing sparks, or not starting you may need to replace the carbon brushes. Replacing brushes and cleaning commutator early can prevent damage to motor armature!
Remington carbon brushes on E-bay Search for:
Remington Pole Saw 8 AMP Carbon Brush
Apr 19, 2014 | Remington Electric Chain Saw
Are brushes available for remington 106890-02
Nov 06, 2013 | Remington Electric Chain Saw
Motor runs but chain does not move
Probably the shaft on the sprocket has sheared off.
Knox Knolls Outdoor Power Equipment
Springfield, IL 62704
www.knoxknollsope.com
Oct 14, 2012 | Remington Electric Chain Saw
Electric chain saw pole wouldn't cut branches
Check to make sure the blade is not installed backwards. It's an easy mistake to make, everything will work OK, but the saw won't cut if the blade is on backwards.
Mar 15, 2012 | Remington Electric Chain Saw
BROKEN PLATE, BEARING
Remington saw is out of business. Look online for any dealers selling parts for these saws. Motor brushes are especially hard to track down and prone to break. Hope this helps!
Jun 12, 2010 | Remington 16" Electric Chain Saw
Motor turns --sprocket or chain doesn't
I'm assuming your kill switch is not engaged, the front handle should be pulled to the rear. It's normal to have some damage on the sprocket from loose chains catching on the corner so I doubt you need a new one. The motor turns? I'm assuming you're talking about the clutch, and if the clutch spins but the chain does not it sounds like your bar may be damaged or as you said the sprocket may need to be replaced if it's seriously been misused.
Apr 15, 2010 | Remington 16" Electric Chain Saw
How to tighten the chain on a electric remington chain saw
This is a Remington OM that is better than most regardless of the manufaxcturer. Please see the first page, pages 7, 8 and 9. Make certain the adjustment tab engages one of the holes in the bar.
http://shoppingcart.msservicecompany.com/msservice_net/product_files/107624-01/107624-01-EL-8-OM.pdf
This may also help.
http://www.fixya.com/support/r4146814-chainsaw_chain_installation
Lou
Apr 11, 2010 | Remington 16" Electric Chain Saw
Remington Polesaw 10" motor is smoking?
Sounds like either the motor is going or that you need a new chain. Is the chain old and dull and is it difficult to cut wood? If so I would try running the saw without cutting and see if the motor smokes. If so the motor may be on it's way out. If you smell an electrical motor winding smell, it's probably time for a new chain saw. I don't know that I would get a new motor for yours as it probably at least $50 and you might want to consider going to another brand like Poulan. Hope this helps!
Mar 16, 2010 | Remington Polesaw Wizard
What kind of chain oil to use for a 10in remington electric
Jun 25, 2009 | Remington Electric Pole Saw
What type of oil do I use for a Remington Electric Pole Saw?
While Bar Chain oil will probably work, the owners manual (sitting in front of me) on page 9 says to "use SAE #30 motor oil". This is the owners manual for Models: M12510US, M15012US, M15014US, M15014AS, M30016US, M30016AS, M30016AW, M35016UW, M35016AW. Remington Electric Chain Saw
Mar 13, 2009 | Remington 16" Electric Chain Saw
Remington Electric Pole Saw Logo
91 people viewed this question
Top Remington Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Remington Garden Expert? Answer questions, earn points and help others
