Question about Linksys WRT160N Wireless Router
Our internet from our ISP works perfectly fine, but when i try to directly connect the ethernet cord directly from the back of my cpu to the router the internetll not work. What can I do to fix this? this is the only way the router will work.
  • Macs R We
    Macs R We May 11, 2010
    You say when you connect the ethernet cord from your CPU to your router, you cannot access the internet. Can you please describe what configuration you use that DOES work? (You say that "the internet from your ISP works perfectly fine," so I am assuming you have some configuration that works, otherwise how could you state that?)
  • 2,260 Answers
Who is your Internet service provider ? If you connect the computer to the modem it works . that means the modem is working but the router is not. You will need to check the settings of the router and set up the router again. Before that press the reset button on the router for 30 seconds. unplug the power to the router and plug it back In. Then open the router set up to check the settings. WRT160N is one of the good router Click Here for step by step solutions
Posted on Nov 17, 2009
I recently moved from Cable ISP to DSL ISP service. For the DSL service, I was asked to configure my Router to use PPPoE with Dynamic IP addressing. I also provided the router with my username and password...
The reason you have no internet is because the router is specifically for cable. your description contains errors what i think you mean is that you have gone from cable dsl to an adsl, correct me if i am wrong. Basically your modem connected to your router via an ethernet cable and then the router fed the wireless signal to your wireless devices or via ethernet through the 4 ports in the back. With adsl you have a feed from your phone line to an adsl modem so the only way for you to get the dsl router working is to have two ethernet leads connecting to your pc, one from the modem to the pc and one from the pc to the router. You would also need to setup internet sharing on the pc thats connected to both devices.
Either do it that way or buy an adsl router
Nov 10, 2010 | D-Link DI-624M Router (DI624MRE)
How to connect to the internet
You should have a home modem from and ISP (Internet Service Provider) Also If you have a router you need to plug the Ethernet Cord (the cord that looks like a Giant phone line) into the internet port of the router, Now if the router is a wireless router and you want to use the internet wirelessly you need to open your wireless connections and you will see your router in the list. Simply double click the connection and it will automatically connect for you. If you do not have a wireless router and you want to connect more than one computer to the internet,Simply keep the ethernet cord plugged into the internet port on the router and you should have 4 other ports next to each other. Plug another ethernet cord into port 1 and plug into the back or side of computer. That's it. I hope this helped have a good day
Sep 29, 2010 | Computers & Internet
Getting ip address, but cannot connect to internet through router. I am connected via an ethernet cord. No problems with modem.
Make sure that your computer is able to go online directly through the modem.
If your computer is able to go online through the modem, that means the modem is working fine.
You will need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for more information about the routers and network
Aug 20, 2010 | Linksys Wireless-G WRT54G Router
Why does my computer say LAN is not connected but my ethernet cable is plugged in?
1. You possibly have lost the IP address from the ISP to your router and you will need to release/ renew the IP or you have a damaged Ethernet cord ( rare) but none the less could be damaged.
2. unplug the Ethernet cord from the connection at the wall for a few seconds and then plug it back in the wall connector.
Then try your connection. Call your ISP ( internet service Provider) and check the line to see if you have proper signal to the router.
Further instructions:
1.Log into router
2. Verify wireless router name( on the computer) >>> ( on/off)
3.Note router name you are connecting to.
4.. Check the laptop do ipconfig /all to see current IP addresses.
5. Set the laptop/desktop up in the router by WEP KEY or MAC address.
6.Note router name you are connecting to.
7. Move the laptop about 20ft away and try to log on to the internet.
This is for all routers to set up wirelessly.
Jul 27, 2010 | 2wire (1000-400108-001) Router
My router flashes DSL, no light on the internet, ethernet and wireless flash together, and power light on. no wired or wireless internet. solution? the afternoon it happened, a lightning storm came thru...
Hey danielbartle,
Since a lighting storm came through there is a good chance your router has been fried.
I would first direct connect via your modem to see if you get a internet connection and rule out your modem as a problem. If that doesn't work I would try another ethernet cord to rule out your cord is a problem. If you get no connection directly through your modem, I would contact your ISP with your problem.
If you get a connection I would then reset the router by unplugging and waiting 30 seconds and plugging it back in.
If still nto succesful I would reset your router to defualt settings by a small button you will find on back.
If none of these work I would head to your local computer shop and pick up a new router.
Thanks for using Fixya!
Jul 22, 2010 | 2wire (1000-400108-001) Router
Internet extremely slow on one network, fine on the other
Not knowing if this relates directly as i am not from Australia but have you checked with the ISP.
The phone line providing the internet access may be damaged in some way or require calibration to reduce line noise (which can cause slow speeds).
Alternatively, have you got a usage limit that you may have reached. ISPs have the ability to throttle back your connection speed.
Thanks
Dec 22, 2009 | D-Link DSL-G604T Wireless Router
I have an ADSL D-Link modem (DSL-300G)that works fine. I hooked a D Link wired router, EBR-2310 and can't get to the internet. It use to work until one day recently the kid moved wires arround because no...
First: Connect your computer directly to the ADSL modem. It has an Ethernet port.
If you can't get to the Internet while your computer is connected directly to the modem, then ytour router never will either. Call ISP if you can't connect to the Internet when directly conencted to the modem.
Next: Check your router wires again, The modem must be connected to the "special" port on the router. Look at the router. There is one port separated from the rest. Connect the modem to that port. Conenct to the Internet.
Still no Internet?
Reset your router by pushing a stylus (straightened-out paperclip) into the reset "hole" on the router (with router powered ON).
Push & hold for 30 seconds or until the lights do their reset dance. Connect to the INternet.
Oct 07, 2009 | D-Link 4-Port Ethernet Broadband Router...
Belkin Wireless G wont connect to cable modem
If you switched ISP then you have tor reconfigure your router according to the settings of your new ISP.
Aug 24, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Wireless router installation
Please see my response to this question. Your university's connection is most probably a LAN connection, so you'd need to follow the instructions as if you had a cable internet connection (unlike DSL, a LAN connection and cable internet connection don't require authentication with the ISP).
Jan 07, 2008 | Linksys Wireless-G Broadband Router
Linksys WRT160N Wireless Router  Logo
62 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
