Question about E-Machines eMachines Desktop PC
Power switch does not turn computer on
I have a e machines desktop computer. When I press the circular button on the front of the tower, nothing happens. It is like the power is dead. I tried switching out the power cord, but that did not solve the problem. There is a switch behind the button, but I do not know if that is the problem.
  • Anonymous Feb 06, 2008
    same problem when push power button nothing happens
  • sitruc 1 Mar 11, 2008
    my power supply shorted out.i installed a new one,it has a switch in the back(the old one didn't)when i switch to on the tower lights up ,both fans run then power supply fan stops ,cpu fan keeps running ,keyboard lights come on but nothing on monitor?
  • 1,601 Answers
If the switch has a (O) and (I) on it ,the (I) should be pushed in.
Posted on Jan 10, 2008
My emachine desktop tower will not power on
the sound you are hearing or heard could have been power surging through a powersupply unit that just blew.. hopfully it did not effect any of the other trouble shoot this you can do one of two things..1 disconnect the 20/24 pin powerconnector from the motherboard 2 disconnect the cpu power connector 3 disconnect the 6pin power connector from the graphics card if there is one some machines have onboard video chipsets if thats the case then no worries 4 disconnect the Harddrive power 5 jump the power supply to see if you get any power from it any questions on that go to youtube and type in how to jump a power supply... or option 2 is buy a new power supply make sure its 80plus certified and replace it...i know its a lot of work but i hope this has helped you
Aug 26, 2012 | E-Machines eMachines Desktop PC
Press tower button and nothing happens
press power button and nathing happens, u need to check your power supply
Nov 27, 2011 | E-Machines eMachines Desktop PC
Hello, Last night I shut down my Dell E510 desktop - the proper way - by going to the start menu, shut down, turn power off. Then, today, I pressed the power button on the front of my tower and...
This sounds like a definite power issue. This means that the problem could range from being as simple as the power button itself not working/disconnected to the power supply being dead.
Things to try:
1. Have the side of your computer open and press the power button. Notice if any fans start to move or anything that happens.
2. Do you notice the Hard drive light flashing at all when turning on?
3. Has anyone else been using or been close in proximity to the computer that could have bumped it, causing something to come loose?
4. ONLY if you feel competent enough, check the cable connections inside the computer. Make sure to disconnect from the wall for 30 seconds and reconnect before touching any cables inside. Leaving the cable connected allows the computer case itself to act as a ground to prevent static shock.
Dec 23, 2010 | Dell Dimension E510 PC Desktop
I cannot boot up the computer. When I push the front power button, nothing happens. When I flip the switch on the back, or unplug it for 30 secs and plug it back in, the fan starts up and a yellow light...
I had this happen to my emachines T1842 about a year ago. I replaced the power supply and it worked fine. It was about 25 bucks but fixed my problem. Make sure the red switch on the back hasnt been messed with. it should be on 115. If you have moved it, it may have blown a fuse inside the power supply.
Feb 04, 2010 | E-Machines eMachines Desktop PC
My computer(a dell) is stuck on save power mode
The reason your computer is in power save mode is because the little battery inside your tower is going dead. It needs to be replaced. It is a small battery about the size of a nickle inside your tower. Change the battery and it will solve your problem.
Apr 07, 2009 | Dell Dimension 4700 PC Desktop
Computer seems totally dead
If the power cord is firmly plugged in - both ends, remove the battery. Does it turn on now? If so, replace battery.
Mar 21, 2009 | Dell Dimension E510 PC Desktop
HP Tower (2000 Media Edition)
Sounds like your power supply unit is dead. Do you get any power or hard drive lights on the unit? If not, I'm afraid it's a repair shop problem.
Sorry to be the bearer of bad news!
Oct 30, 2008 | Computers & Internet
Power problem
look for a switch on the back of the computer by the power supply it must be in the I position not the O . if that will not work then the motherboard my be damaged or the power supply itself not the cord for it is very rare for a power cord to polarize any more. last the power button itself may be damaged but in al my years I have not found a bad power button yet. Always it has been the motherboard or the power supply.
May 08, 2008 | E-Machines eMachines Desktop PC
Emachines model T1862 WILL NOT START
There are a wide range of possibilties. first if nothing at all happens when you press the power button. (no lights no sounds etc.) then the most obvious culprit would be a dead power supply or a switch in the back thats off.
Are there any fans or lights?
Please let me know...
Jan 17, 2008 | E-Machines T1862 PC Desktop
E-Machines 2862 Dead On Power-Up
I believe that the front button is not connecting to the switch for the power supply. Also make sure all internal connections are secure. Sometimes the button breaks from behind so that it cannot contact the switch. Let me know if it helps. There are other solutions if you tried this one first.
Nov 01, 2007 | E-Machines T2682 (000002965) PC Desktop
E-Machines eMachines Desktop PC Logo
107 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
