Question about Fisher and Paykel 23 in. DD603H SS Free-standing Dishwasher
Dishwasher is shorting out and playing music. if you touch the front you get shocked
  • 115 Answers
You have ashort from a hot wire or switch grounding to the frame somewhere, it would be best to have a electrician look at it i would not use this until you get fixed it is very dangerous
Posted on Nov 17, 2009
How to repair my kenmore dish washer not powering on but shocked me before it shut down for good ?
it sounds to me as though you may have a bare wire giving a direct short to the system.therefore by having a hot wire grounding out on the dishwasher body, it is running that current to the dishwasher body where if you touch the dishwasher you will recieve a shock.this also doesnt allow the electricity to go to where it is needed to power your appliance.
May 20, 2014 | Kenmore Dishwashers
Electrick shock when touching machine
Get an electrician to verify the dishwasher is properly wired and grounded. This is a dangerous situation.
Dec 17, 2013 | Smeg Dishwashers
Miele G2830 control panel locks out, unplug and let set would reset it but now it does not. is there a way to reset
I have a Miele G2830sci dish washer since brand new, used twice a week in a domestic environment. I am very dissatisfied with this dishwasher because the front control panel (touch screen, no buttons) became unresponsive after six years, outside the warranty. I had the panel replaced (part was AUD$290 and labour/callout fee $210) and the dishwasher was working properly again for another 3 years. Now the same issue is appearing again. I believe that these control panels only have a relatively short lifespan relative to the other parts of the machine. The touch pane becomes unresponsive, or erratic to respond to your touch when the panel is warm, typically towards the middle or end of the cycle when the hot wash or drying is occurring. The panel would be OK when cold. But give it enough time and even when cold, it would no longer work properly. It looks like this panel only has a short useful working life relative to the rest of the machine, based on my direct first hand experience. Not good.
Nov 27, 2011 | Miele G 2830 SCi Stainless Steel Built-in...
I bought my daughter a Kymko scooter. She is short and her feet will not touch the ground. Can the "chassy" be lowered on a Kymko Agility scooter?
Yes you could lower it by replacing the rear shock absorber with shorter type and adjust the front shocks by grinding a notch to the stopper bolt.
Hope that helps you!
Aug 01, 2011 | Kymco RS2 Matrix Motorcycles
When we plug in the dishwasher da4441s it short circuits.
The short circuit may be located in the junction box from which the dishwasher gets power.
Its probably bare wires touching under the "skirts" of two wire nuts.
If no power problems, then the dishwasher itself has a short. In this case, start locating the short in the
little box to which the power cord is connected - these connections will short if one of the
hot wires, or a hot wire spade lug is touching a frame ground (all components of the frame are grounded).
A third (remote) possibility is a wiring mistake - the dishwasher hot & neutral could be connected, causing a dead short.
May 13, 2011 | Dishwashers
Hi, I have a Fisher & paykel DD603. A really bad smell has developed which appears to come from under the top panel encasing the dishwasher. How do I remove this panel to locate the source of this...
HI- If you mean the front panel they are removed by taking out the plastic retainers that are on each side of the drawer near the front and bottom of the drawer. They are round and about 1/2" in diameter and have a raised straight portion in the middle, they sit flush with the plastic sides. Use needle nose pliers and pull hard. Once both are out grab the bottom of the front panel and pull down, the panel should "slide" off. Be sure to have the power off to the unit (unplugged) because if there is an electrical short that is casing the short all the wires will be exposed and could give you a shock if they are melted. The controller will be in the upper right hand portion of the drawer front. Smell there. I've see them short out and be black and crispy. Good luck. Getting the panel back on is difficult but be patient and don't force it.
Feb 13, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Hotpoint Dishwasher BF1620 blew the main fuse circuit in fuse box during mid cycle wash? Re-set main power fuse circuit but now as soon as Dishwasher switched on immediately blows main kitchen power fuse...
This is happening because you have a very bad fault, a Phase to Earth short, problem. Leave machine UNPLUGGED, Breaker/Fuses OUT. do NOT use it, nor Touch it, It is possible to get severe electric shock. PLEASE get a registered serviceman to inspect this unit.
Feb 07, 2010 | Hotpoint 23 in. BFI62 Built-in Dishwasher
Siemens SE64A630 GB I got a tingle up my arm when holding the dishwasher and touching my sink. I checked and when the dishwasher is plugged in, there is 24VAC between the dishwasher door and the stainless...
I would say it is an earthing problem, check over your earth wires, normally black and grey is neutral, check to make sure your earth wires are connected properly, and tight, better to completely turn appliance off by disconecting power plug while doing this, take care not to play around with the wires too much to prevent a nasty electric shock
Jul 01, 2009 | Siemens 24 in. SE64A630GB Built-In...
Ipod touch problem with jensen vm9312
My iphone works fine, it is a firmware version 1.1.2, maybe you have a different firmware version. you might have to upgrade or downgrade.
Mar 17, 2008 | Jensen VM9510 Car DVD Player
Fisher and Paykel 23 in. DD603H SS Free-standing Dishwasher Logo
127 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
marley mcelhinney
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
