Question about Canon PIXMA iP1600 Printer
My printer says there is a paper jam and I have taken it completely apart. There is nothing in there. It won't do any of the maintenance tools because the orange light comes on and the same message- paper jam. How do I fix this?
  • 74 Answers
Make sure the paper is totally removed and close the cover well
Posted on Nov 17, 2009
Our hp printer/fax/copier says there is a paper jam but we cannot find one and we have all but taken the thing completely apart
if you have taken the ting apart and there is no paper in it, then the jam is likely to be caused by a dirty or faulty sensor.
Try cleaning the sensors, if not working, then you may have to change parts to determine the cause of the problem
Sep 17, 2010 | Computers & Internet
The paper in the printer is lined up and everything should be working however I need to print things for work and it tells me that it is either jammed or that I need to load/ reload the paper. I can't...
I have found over the years that printers really don't lie. If it says there is a paper jam there usually is. I have completely taken apart a large laserjet printer to find a very tiny piece of paper causing the problem. Also if you run sticky labels through printers they have a tendency to leave residue or even part of a label behind which will cause the printer to tell you there is a jam. Check your printer very carefully, use some canned air to blow it out. You may need a printer repair person to come out and take it apart to look for possible stuck paper.
Jul 03, 2010 | Canon Pixma iP2600 Photo InkJet Printer
Paper jam---can't at the paper
First off - DON'T PULL! Pulling on a jammed paper can crack the maintenance unit and then you might as well buy a new one. Visit you local ASC, find one here, The printer may need to be taken apart for the paper to be removed correctly.
Thank you for using FixYa! - Don't forget to rate our service.
Feb 02, 2010 | Brother MFC 240C All-In-One InkJet Printer
Printer jammed. I cleared the jam but it
You most likely have a tiny piece of paper stuck in the paper path that cannot be seen unless taken apart. Depending on the type of printer... remove the paper tray and the back cover and look for any small shred of paper. If you still see nothing, a local repair shop would be your best option.
Jan 02, 2010 | Office Equipment & Supplies
How to solve a paper jam on dell 924 printer
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Nov 26, 2009 | Dell 924 All-in-One InkJet Printer
ROYAL RL170MX Shredder won't shred
Did you ever put shredder oil onto the cutting blades?????
The blades can clog with paper dust and then it can't shred as many papges as it should or even jam completely...you should occasionally shred a sheet of paper with shredder oil poured onto the sheet.
Aug 11, 2009 | Royal 1280MX Shredder
Error, paper output slot
That means the sensor flag under the platen roller is broken, bent, or jammed in the up position. Hard to see and must be taken apart to repair.
Aug 07, 2009 | Canon PIXMA MP610 InkJet Printer
There is NO paper jam- and the paper won't feed. We have taken the printer apart- NOTHING hung up- gears are okay- still won' feed paper.
hi...
Most of our printers pull the paper down on one side slightly faster than the other. The printer hardware should even this out when printing. You should also ensure the paper meets the automatic feeder requirements of the printer.
If printing is skewed, feeding multiple pages or jamming, please follow these instructions (use a regular letter size paper to test after doing the steps given below):
Please check to ensure there is nothing obstructing the paper feed mechanism down inside the printer where it is not easily seen. If there is nothing obvious, unplug the printer and remove the paper. Open the front cover and look above the steel rod. You should see a conveyor belt with rubber teeth on it, like a fan belt. Take the bottom part of that belt and move it gently to the left. The cartridges should come out with it. Make sure the cartridges can move fully from one side of the printer to the other. Check also the output rollers on the bottom of the printer for any blockage. If it is jamming under the carrier assembly, you may be able to fix it using the manual feed slot. Turn the printer off. Next take a #10 envelope and feed it through the left side of the paper feed slot (The manual paper feed slot is preferred, but the automatic feed will do if there is no manual paper feed for this printer) until it comes completely through the printer to the back of the exit rollers. Move it up and down and slowly move it over to the right side. If something is stuck under the black guide plate this may work it loose or you may have to feed the envelope through the front rollers and push your way backward (please be careful here).
Next, take a damp warm cloth and clean the rubber rollers in the automatic sheet feeder. Dust may be coating the rollers there and as they become less tacky, they cannot feed paper correctly.
try it out....
Apr 05, 2009 | Lexmark P4350 All-In-One InkJet Printer
Paper Jam & Flashing Light
take everything out and look at all the rollers and printer path and look in the back of the printer
Jan 15, 2008 | HP LaserJet 1320 Printer
Canon PIXMA iP1600 Printer Logo
93 people viewed this question
old marine
old marine
