Question about Samsung Smooth SCH-u350 Cell Phone
The front display wont stay lit for the clock on my samsung smooth how do i fix it to keep it on
Samsung range with digital display not working properly. Clock shows half of the numbers.
Replace the display board. There will be a segment driver that has failed.
May 06, 2017 | Samsung Ovens
I have a kenmore glasstop range. the time on the display will not stay lit, why?
This is a "feature" imposed upon us by those energy-saving freaks and environmentalist-wackos. What you need to do is press and hold the clock button for 12 to 15 seconds. When you first press this button, the display will appear. Then in about 7 or 8 seconds it will disappear. Keep holding it for 12 to 15 seconds until it re-appears. Now if you release the clock button, it should remain on.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Sep 23, 2014 | Kenmore Kitchen Ranges
Clock display stays lit
yes on some cars this is normal, the amount of current that the clock draws is very minimal and should not cause problems with a battery. Unless not used for very long periods
Jul 09, 2012 | 1995 Buick Skylark
Clock display won't stay lit
Same thing happened to our Kenmore range and I found a solution on the web about fixing this problem on a fridgedaire range. It was to hold down the clock button for an extended time ~15 sec. It worked for our kenmore and hopefully for yours too.
Feb 10, 2010 | Kenmore Ovens
KitchenAid Superba Double Oven clock won't light up
hold down the clock button for 3-5 secs. youve somehow toggled the clock dosplay off.
Nov 05, 2008 | Ovens
Clock changing time
my clock keeps changing time, i have sent for repair to samsung.
they said they replaced the display . i still have the same problem .
i exchanged the dvd ar650 and this one is the same.
what the ? , i might have to change get rid of samsung and find something else.
any help since samsung can't fix thier product.
May 04, 2008 | Samsung DVD-AR650
Clock doesn't stay lit up
To turn the time of day display OFF or ON in the display press and hold for 15 seconds (the control will beep
once) and then release. This feature does not remove the set time of day from the memory of the control. When the display
is turned OFF the time of day will re-appear for a few seconds any time the pad is touched
Mar 04, 2008 | Frigidaire FEF366 Electric Kitchen Range
ELECTRONIC DISPLAY WONT RESET
i think you have to set your clock manually lift the top up by the florecsent lite there should be instructions
Dec 16, 2007 | Kitchen Ranges
Clock doesn't stay on
the clock to my kenmore stove wont stay on. only works for about three seconds and then it turns off.
Oct 30, 2006 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Samsung Smooth SCH-u350 Cell Phone Logo
193 people viewed this question
Top Samsung Cell Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
