Question about KitchenAid KGSA906PSS Gas Kitchen Range
Hi there! My Kitchenaid oven won't turn off. All of the other buttons seem to work - they make a beeping sound when I touch them too - except the off button! Nothing. I had to pull the plug on my oven. We just bought the house and didn't find a manual. Do you know what the problem could be and how best to fix it? Thank so much, in advance. Linda
  • 2 more comments
  • cynsagh Nov 26, 2009
    I have the same problem with my Kitchenaid oven--did anyone offer a solution?
  • Fullserve Mar 05, 2010
    This is exactly the problem that we have had on this
    unit. We purchased in 2006 and within 6 months had to replace the entire
    front panel because none of the buttons would work.
    Within a few weeks, the repaired panel "off" button stopped
    working. We came up with the same solution as you and had been using
    "stop time" for the last couple of years. There have also been
    times when the panel stops working altogether. The solution is to unplug
    the oven, wait a few seconds and plug back in. It seems to reset okay.
    Tonight, however, we came home to find the house filled with smoke. This
    oven had spontaneously turned itself on and was flashing an
    "over temp" error. The oven was too hot to touch, so rather
    than unplugging it, we turned off the power to the kitchen. After a
    couple of hours, we tried turning the power back on and the panel itself
    started sparking and clearly was starting an electrical fire. Of course
    we immediately unplugged and now are stuck with a $1,600 paperweight.
    Any suggestions on negotiating w/ KitchenAid for some compensation?
  • Lisa Vickers Apr 25, 2013
    Just has this happen last night! 4am and the oven is on and smells like an electrical fire. Had to turn the breaker off - very frightening! Anymore information on this?
    I had the same issue at 4am - woke to a horrible electrical burning smell and found the oven on and the touchpad not responsive with "communication lost" displayed!! Had to turn the breaker off and now it will stay off until I get a new stove. Very scary!
It appears the 'membrane insert' is defective. I was able to turn my oven off by using the 'stop time'. Just imput one minute ahead of current time, then press start. In one minute the oven will turn off. You can clear the screen by opening the oven door fully, then close.
Posted on Dec 07, 2009
I have the same exact probelm with my oven. Linda, how did you eventually get this fixed?
Scott
Posted on Feb 22, 2010
Cancel key does not work
Sounds like the touch control pad is bad.
Nov 16, 2013 | KitchenAid Architect II Superba EQ Series...
Touch button won't work
If all buttons don't work then check that connection isn't broke through the I/O board.
If not then board is faulty.
Is you display is lightining or not.
if not then the connction is bad
thanks
please rate my work
Sep 10, 2011 | KitchenAid KHMS155L Microwave Oven
I have the KitchenAid microwave oven model KBHC109. For the past few weeks the microwave has been beeping on its own. Sometimes it seems as though we are pressing buttons when we aren't and sometimes...
I am sorry but this is usually the signs your touchpad is going out and the part alone retails for a lil over $300.00. You know your needs better than anyone but in my home we would just keep dealing with it untill it drove us crazy, or quit being usable. Basically the buttons you press are worn and making contact without being pressed.
May 26, 2011 | KitchenAid KBMC140HSS Convection/Microwave...
My beep quit! Beep used to work when the oven came up to temp, the timer timed out, or a button was touched. Can it be reset or will I need to replace it? Where's the control board located and how do I...
We have a Kitchenaid Superba gas stove and the beeps would not sound. We thought the control panel was shot, but we have a WONDERFUL repair man. Here was his re-set.....open oven door, push the cancel button, push stop-time button and hold that button for about 5 seconds. When the beep sounds let go and the panel is re-set. WOW!!!!
Oct 23, 2010 | KitchenAid KGRT607 Gas Kitchen Range
KitchenAid kemc308kss0 Micro/Oven Combo Microwave: At the end of any cycle there is a four-tone beep that will continue to beep until KINGDOM COME until you either a. open the door b. press cancel. That is...
From page 7 of your owner's manual:
All Tones (combination oven models only)
All of the above tones are preset on, but can be turned off.
To Turn Off/On: Touch and hold STOP TIME for 5 seconds. A
tone will sound and “Snd oFF” will appear on the lower oven
display for 3 seconds. Repeat to change back to “Snd on.”
Tone Volume
The volume is preset at high, but can be changed to low.
To Change: Touch and hold the number pad “7” for 5 seconds. A
tone will sound and “Snd Lo” will appear on the lower oven
display for 3 seconds. Repeat to change back to “Snd HI.”
REMINDER TONES
The Timer and Timed Cooking reminder tones are preset on, but
can be turned off. Reminder tones do not include end-of-cycle
tones. On combination oven models, if “All Tones” have been
turned off, the reminder tones cannot be independently turned
on.
Timer
To Turn Tones Off/On: Touch and hold TIMER SET • START until
a tone sounds. Repeat to turn back on.
Timed Cooking (combination oven models only)
To Turn Tones Off/On: Touch and hold COOK TIME until a tone
sounds and the lower oven display returns to inactive mode
(blank). Repeat to turn back on.
Apr 26, 2010 | KitchenAid Microwave Ovens
My oven keeps beeping & it was flashing F5 but now nothing is on the screen & oven won"t turn off.
depending on the make of your oven, it could be a door latch failure, or a stuck touch pad button.
if the door latch it wont heat when you put the unit to bake.
if the touch pad button, then you wont be able to program the controls.
Jan 10, 2010 | Ovens
Kitchenaid Superba Gas Oven Touch Pad not working
We have a gas kitchenaid KGST307HBL9 and the touch pad is blank, but we discovered that you can still touch the buttons and it will work. (example touch bake; temperature; start). It will beep when the target temperature is reached.
Just so we don't forget and leave the oven on, we turn the oven light on as our signal. A little work, but not wanting to "fork" out the money at this time to repair.
Also, if you are handy RepairClinic.com has many items and can also answer question. We've used them for several of our appliance repairs.
Jun 03, 2009 | KitchenAid KGSA906PSS Gas Kitchen Range
Off button doesen't shut off oven
You will probably have to replace the electronic range control.
Jan 03, 2009 | KitchenAid KESC307 Electric Kitchen Range
KitchenAid KGSA906PSS Gas Kitchen Range Logo
4,494 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
