Question about Sony KV-27V10 27" TV
Intermittent Power Down and Backup
TV is 14 years old and today I experienced the first problem ever with this set. TV was on and image and color quality were good. Then all of a sudden the TV shut off for a second or two and then came back on. When the image came back on the colors still looked right but I now have some colored streaks that seem to bleed vertically to the right from objects in the image. Hopefully this is an easy and cheap fix. Had this baby for 14 years and never a problem. Sure would be sad to see the old dog go.
  • Gary Fox Jan 10, 2008
    Update on this problem and error correction.
    About 30 minutes after the problem reported above occurred, the horizontal lines went away. I know I reported vertical lines above but they are horizontal not vertical. Then about 30 minutes after that, the TV shut off again and came back on with the lines again. It seems to alternate through this cycle over and over.
    Problem Solver:
THE TV ONLY HEAR THE RELAY BUT NO PUSH IN ON NEVER
Posted on Jul 07, 2009
Problems with colors and display on my Samsung LN37A550P3FXZA flat LCD.
Replace all busted capacitors in power supply board inside.
Jan 10, 2014 | Televison & Video
My Sony Bravia KDL 40WL 135 TV has been flashing strange colors for awhile; today screen is black with a thin blue line across the bottom. No sound. Any help appreciated.
The vertical output section circuit has the fault. Contact any experienced service technician. This is not a user repairable fault.
Aug 10, 2012 | Sony Televison & Video
JVC AV-56WP74 Colors quit working or went out of balance.
Guns or CRT are probably ok. Your TV needs a convergence IC STK392-120 replacement. Lamp are used on LCD and DLP rear projection TV's. Color wheel are for DLP's. :)
Dec 26, 2009 | JVC Televison & Video
Loud buzzing noise which became a very loud screech over the last week. Turning tv off and on seemed to remedy it. Today screen was only black and white, now no video only audio. Is this the picture...
This TV uses a lamp and color wheel. the color wheel is likely the problem since it is known to make noise over time and will eventually sieze. The repair is in the $400 range.
Sep 27, 2009 | GE 46GW945 46" Rear Projection Television
Two lines appearing and moving up and down on my Pana 14"color tv
Hello, This is called 60cycle hum and it is caused by the 60Hz signal of the power supply "leaking" into the video circuitry. It is caused by a faulty filter capacitor. and can be seen by using an oscilloscope. I would suggest that you take the TV to a qualified TV technician for servicing, because this type of repair is not for the do it yourself person. I hope this helps, Thank you, Shuttle83 http://www.electron-age-technologies-llc.com
Jun 10, 2009 | Panasonic TC-14KM30R 14" TV
Can not turn TV on
Failing power supply. It's 14 years old.
Feb 19, 2018 | Toshiba MD14F51 14 in. TV/DVD Combo
Sony projection tv 5 years old
you will need to call an electronic repair shop to get this problem resolved
Oct 30, 2008 | Sony KP-57WV700 57" Rear Projection HDTV
Sony 52XBR Rear Projection
Sounds like some kinda convergence problem. Can you post an image please?
Jul 14, 2008 | Sony KP-51HW40 51" Rear Projection...
Red ghosting on images that are not closeup
1. Power off -- let bulb cool.
2. Display - 5 - VOL+ - Power (in quick sequence) to display service menu.
3. Go into the user menu and set auto revision back to auto.
4. Put an image on the screen that shows the problem. I always found the edges of a 4:3 aspect ratio signal displayed the ghosting very well on my set.
5. Use 2 to scroll through the categories to find D GM TG
6. Use 1 to scroll through items in D GM TG to find V POS D
7. Write down current value.
9. Use 3 and 6 to change the value to minimize the ghosting. You should only need to move it up or down a value or two.
10. Press Mute - Enter to save the changes.
11. Power off and let the bulb cool.
Jun 25, 2008 | Sony Grand WEGA KF50XBR800 50" Rear...
Televison & Video Logo
89 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
