Question about Kenmore 62602 Electric Dryer
How do I install idler and pulley assembly on a Kenmore 70 Series dryer??
  • 90 Answers
Your local appliance parts store would be glad to help u with this . on the back of some belt paks u will find instructions. good luck hope this helps
Posted on Nov 17, 2009
Removing the Idler Pulley Assembly
Whirlpool manufactured brands including Admiral, Estate, Inglis, Kenmore, KitchenAid, Roper, Maytag, Crosley, Jenn-Air, Hardwick, Magic Chef, Amana, Glenwood, and Caloric. All of these front loader conventional electric dryers are very similar. The idler pulley attaches by a snap in spring assembly.
26031432-cqk4auvkq54bteptus3ub0nf-1-0.jpg The spring assembly is purchased as one part with the idler wheel attached. If the make of your dryer is different than the above please provide additional information.
Dec 31, 2015 | Haier HLP140E Electric Portable Dryer
Kenmore 70 Series Dryer Belt Keeps Breaking
A few things to check. Make sure that the idler pulley is turning freely without any signs of distress from the bearings. Make sure that when the belt is installed that all drum, motor and pulleys are perfectly in line. Even a small amount of misalignment will cause premature failure. Turn the drum by hand and make sure is turns fairly freely. There will be some drag from the drum supports, but it should turn readily with one hand, if it is any stiffer then the drum supports may be badly worn and will need to be replaced. Make sure that the pulleys on the motor and idler are in good condition and not damaging the belt. There are basically only three main reason for a premature failure, misalignment, pulley damage and overloading. It has to be pone of those.
Nov 26, 2017 | Kenmore Whirlpool Maytag Dryer Belt...
How do I get to the belt on my Kenmore 70 series Gas Dryer.
Hi caja2...
You will install the belt around the drum then pinch it into a look, thread it thru the idler pulley and on to the motor.
I will provide you with a link to show you different belt routings.
Free Answer...Please take time to rate me
http://www.expertappliance.com/dryerbeltconfiguration.html
Jun 07, 2011 | Dryers
How do I replace the dryer belt on a kenmore 70 series dryer
remove two phillips screws under lint screen trap door pop lid up... remove two corner screws usualy 5/16 nut driver lift upward and off to the right idler pulley bottom left pat attention to belt routing before taken off relace pulley change belt and repeat steps and reinstall
Jan 31, 2011 | Kenmore Dryers
I have a Kenmore 70 Series Dryer and the belt broke. I ahve since ordered the replacement belt, but am uncertain how to replace it. Is there somewhere I can view a diagram of my dryer so I know where the...
pulley fits into slots in bottom of dryer near motor pulley. idler pulley will be to the left of motor pulley looking at it from the front. loop belt thru idler and place around motor pulley.
Jun 26, 2010 | Dryers
Kenmore 70 series electric dryer. Turns on but will not tumble.
sounds like either a dryer drum belt or a dryer idler pulley is defective
Oct 18, 2009 | Dryers
Broken Belt--kenmore 70 series dryer
it is not that hard to replace the belt if you have the front panel off of the dryer. place the idler pulley in the holes located below the motor pulley put the belt around the drum pull the idler back and the belt loops around the idler and onto the motor pulley
Dec 10, 2008 | Kenmore 24032\24036 Top Load Washer
Belt busted
lets see what we can do. wrap the belt around hte tub assy. the little white roller w/ metal arm (called the tension pulley) needs to be installed .there should be a few ****s directly under ther motor pulley on floor of unit.two sets of ****s you wanna use the set to ther rear of unit. insert the prongs into the left rear **** and then pull the roller portion to the right.(it should hook the back prongs of idler into the rt side ****s. tension holds this into position so it will fall out if you let go) theres an opening in the metal under the roller mounts, e**ugh room to slide the belt through.heres how it works, install the idler as described above, feed the belt through the opening in the idler from the left and under roller through hole pull hte roller and pulley hard to the right.(its springy and as long as installed correctly ** worry of popping out) and loop around the motor pulley.let go of the pulley. and the belt should remain tensioned. it will only go on on way. GOOD LUCK
Mar 10, 2008 | Kenmore 63942 Dryer
Idler pully
there has to be a spring on the idler to keep it pulled against the belt
Mar 01, 2008 | Kenmore 62622 Electric Dryer
Kenmore series 70 electric dryer idler pulley
I figured this one out...there are two pairs slots...the tab of the idler pulley goes in the right slot near the motor and the idler pulley goes off to the left.
Nov 13, 2007 | Kenmore 60172 Electric Commercial Dryer
Kenmore 62602 Electric Dryer Logo
123 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
