Question about Westinghouse Televison & Video
I have a westinghouse tv and my wife was pushing some buttons on the remote and now i have a black box in the center of my tv. It only allows you to view the image on the outside of the black box. How do I remove the black box?? Thanks
  • 192 Answers
Sounds like she turned on one of the Closed Captioning options; not the standard CC style, but the style called Text. Jump into the menus and turn off the Closed Captioning, and all should well
Posted on Nov 17, 2009
My Westinghouse TV was working just fine, but stopped turning on after I had issues with the cable box. Those are resolved, but I can't get it to turn on. Anyone have any ideas on how to fix this?
Patience may be the key--It may be substrate charge phenomenon--
Disconnect everything from the TV, including power cord and all ins & outs and wait awhile (3 days is sufficient) to let the internal charges bleed off. Reconnect TV and try it again. It sounds like a power surge (or lightning strike nearby) jammed a temporary "substrate charge" onto TV's circuitry.
May 05, 2015 | Westinghouse Televison & Video
I have a westinghouse LED 40in TV I was watching TV and my finger hit a button on my cable remote, usually I have to get the TV remote and press HTML1 now my TV has a purple box I tried everything and cant...
if that purple box is in the center of the screen you have hit closed caption, you just need to locate that in either TV menu or cable menu & turn it off
Apr 30, 2014 | Westinghouse Televison & Video
Westinghouse tv, remotes do not work on it
Each tv remote has a code list....you must find the code that corresponds withe the Brand of tv and enter the code then ALL the buttons will function properly
Mar 06, 2014 | Westinghouse Televison & Video
Westinghouse Setup wizard
westinghouse will not work with an APPLE remote
Jun 09, 2013 | Westinghouse Televison & Video
Lost remote. Must do manually on t.v. Two problems:\r\n1) I cannot get channel back on channel 3. It skips from 2 to 4. 2) TV has large black box on screen covering most of screen. I can push buttons...
Try website like Remotes.com to buy the tv original remote to used.U will used the tv original remote to turn to channel 3 with ease.After u have the tv original remote push the menu button go into Closed Captioning functions turn off like TEXT 1,2,3...The big black box will not appear on the screen again.Tv used it manually control buttons up and down channels trying to get to channel 3.U will never get it to tv channel 3 because tv channel 3 was not save on it memory list of on the tv turn manually channels buttons programming memory.Tv have a manual button said MEMU button on it tv front bazel frame?Yes.Might could used the Menu button on the tv frame to get in to turn off TEXT 1,2,3...to stop the big black box to show up on the tv screen again.
Aug 17, 2011 | Toshiba 36A50 36" TV
Westinghouse - 60" Class / 1080p / 120Hz / LCD
There is a method called a Power Scan this method allows you to search for all possible codes. Try this until you reach a code that carries all of the functions desired. If the TV mode button starts flashing rapidly during this process you have exhausted all possible codes.
Power Scan
1.) Hold down the clear "TV" button on the remote for four seconds, then press 500 pound ( #)
2.) Hold down the clear "TV" button on the remote for four seconds, press the big power button once.
3.) Press the channel up button once per second until the TV turns off then press pound (#).
Daniel Busa
DISH Network
Customer Service
Apr 17, 2011 | Westinghouse 16093 Remote Control
I have a westinghouse LCD tv SK-32H635S. I used
Hi:
If you are using the television with a cable box try looking a format button the the cable boxs remote to change aspect of the pictue. Also try unpluging the unit from the AC outlet for at least two minutes to reset the unit.
Mar 14, 2010 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Mitsubishi CS 40503, black box in center of screen, takes up 90
check on the remote control for the function text maybe by mistake you put it on
Mar 14, 2009 | Mitsubishi CS-40503 TV
Close captioning
Hi ckay31,
If your remote is not allowing you to navigate through the menus, you may need to replace the batteries.
If this does not work, in the meantime you should be able to navigate the menus using the menu button on the TV. The Closed Captioning option should display under Channel Settings.
If you are still unable to get your remote to function properly, I recommend you contact Westinghouse Customer Service at (866) 287-5555. You may also view your product's manual at http://www.westinghousedigital.com/pdf/15_User_Manual.pdf
Thank you,
Jason,
Go Ahead. Use Us.
Jun 16, 2008 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
White Westinghouse 32 in Issue
Turn off the closed caption portion in the menu . The text 1-2-3 or 4 is on blanking out the center of your screen . The closed caption button could be on your remote and is being accidently pushed . Good luck
Mar 03, 2008 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Televison & Video Logo
383 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
