Question about Acer Aspire 6920 Notebook PC
My blue tooth will not turn on with the button. Is there another way to turn it on.
  • 51 Answers
Get the bluethooth driver from there site to update ur system
Posted on Nov 17, 2009
Im just 13 so i cant pay anything but i'd appreciat help, I Would Like to pair my Plantronics 220 bluetooth with my Playstation 3 but i baught it used and do not have any instructions on how
ok first you must turn the blue tooth power to on in your games system menu,then you will have to turn your blue tooth device to discovery mode,to do that most blue tooth manufactures use the power button for this feature,by holding down the power button when turning on your headset for 6 to 10 seconds it should put your device into discovery mode,then you can add or search for the blue tooth device from your game system,once it finds it,it will ask you for a pin pairing code .most blue tooth manufactures use a factory 4 digit pin pairing code,they are as follows,try them from first one because i will put them in order from most common to least common,but one of them will work,they are 0000,1234,1111,or 9999, i hope this helps you have fun gaming
Feb 26, 2011 | Radio Communications
How you play music on jabara bt 2050 0n phone
first you have to pair your blue tooth device to your phone,first you turn the bt power to on on your phone menu,next you have to put your blue tooth device headphones into discovery mode,now most bt manufactures use the power button for this feature,by holding the power button down for 6 to 10 seconds when you turn the bt device on it usually puts the bt intodiscovery mode.a solid light usually remains on on your blue tooth device,then you can search or add new device from your phone menu.once they have paired or recognized you will need a pin pairing code.Most manufactures of blue tooth devices use a factory 4 digit pin pairing code ,they are as follows0000,1234,9999,or1111 i hope this helps
Feb 25, 2011 | Samsung Radio Communications
How do i make my backbeat 903 discoverable
Most manufactures of blue tooth devices use the power button to turn the discovery mode on,by holding the power button down for 6 to 10 seconds when turning on your blue tooth device a solid light should come on,that means your blue tooth is in discovery mode,then what ever device you are connecting it to has to have the blue tooth power turned on,then there should be a add new or search for devices,after thatyou will need a pin pairing code,Most manufactures use a factory 4 digit pin pairing code they are as follow,0000.1234,1111 or 9999 i hope this helps
Feb 22, 2011 | Plantronics Backbeat 903 Bluetooth...
Unable to put phone into pair mode motorola hs810 to a i phone 3g
Most blue tooth device manufactures use the power button to set your device to discovery mode,first you must turn the power to on for your blue tooth from your phone menu,then most manufactures use the power button to put the blue toooth device into discovery mode,by holding the power button down when you turn your device on holding it for 6 to 10 seconds,usually a solid light appears on your blue tooth device,it is now in discovery mode,on your phone menu there should be an add new or search devices,once you've clicked that it should discover your blue tooth device,then you will need a pin or pairing code,Most manufactures use a factory 4 digit pin pairing code the y are as follows 0000,1234,1111,or 9999, if you have done the steps correctly the menu will say connect,press conect and you should be connected..i hope this helps
Feb 22, 2011 | Motorola Mobility HS810 Consumer Headset
How to reset a bluetooth i.tech i.oval 303
Most manufactures have a factory 4 digit pin that once you have put it to discovery mode,usually blue tooth manufactures use the power button to reset the discovery mode,by holding the power button down while turning it on keep holding the power button for 6 to 10 seconds a light should appear on your device,thus the device is in discovery mode,once your blue tooth device has been put into discovery mode you should go into your phone menu and turn the blue tooth power on,then it should have an add new or seach for device,click that and it should pair with the phone,you will need a 4 digit pin pairing code,Most blue tooth manufatures use factory pairing pins they are as follows 0000,1234,1111,or 9999 try them in that order,i hope this helps you
Feb 22, 2011 | Itech i.Tech i.Oval 303 Bluetooth Headset
I turned my headset on and now the blue light is on and I cannot turn it off.
your blue tooth device is in discovery mode you must pair it with your phone again,it just you held the power button down to long turning it on ,most blue tooth manufactures use the power button for the discovery mode,in case you don't have the pairing pin code again most blue toooth manufactures use a 4 digit factory code,they are as follows 0000,1234,1111 or 9999 i hope this helps.And if your blue tooth drained the battery and you need to charge it before you proceed ,to put it into discovery mode hold the power button down for 6 to 10 seconds when turning your blue tooth device on.i hope this helps
Feb 18, 2011 | LG HBM-760 Bluetooth Headset
Can i use my plantronics 230 bluetooth for my blackberry phone?
Hi, yes you can use plantronics 230 blue tooth for your blackberry phone.All you would need to do is to pair the device with your phone.that will do.
How to pair a phone to a blue tooth device?
Instructions
Pair Your Blackberry with a Blue-tooth Headset
Turn on Blue-tooth headset and Blackberry hand-held.
Enable the Blue-tooth radio by going to the options window and clicking on Blue-tooth. Click on Enable Blue-tooth in that window.
Add your Blue-tooth headset to your Blackberry by clicking on Add Device in the Blue-tooth window.
Find and select the name of your Blue-tooth headset from the list that appears. The Blackberry will search for all Blue-tooth devices within range, so other devices might show up on the list.
Click Activate Blue-tooth device if you receive a call and the Blue-tooth headset does not pick up automatically.
Use your Blue-tooth Headset with your Blackberry
Make sure the Blue-tooth radio on your Blackberry is turned on before you try to use your Blue-tooth headset.
Use the voice-dial feature to call contacts if your headset has that capability. Not all headsets support voice dialing, but more of the newer models do.
Press the on/off button on your headset to end a call or use the end button on the hand held.
Tips & Warnings
Pair your Blackberry with any Blue-tooth-enabled device using the same steps as those for connecting a Blue-tooth headset.
Remove your Blue-tooth headset from the list of paired devices on your Blackberry by selecting and clicking on Delete Device in the Bluetooth window.
Configure your Blackberry to connect to a paired Bluetooth headset without asking for authorization in the Bluetooth Device Properties window. That will allow your headset to automatically reconnect even if you take it out of range temporarily.
Only configure a Bluetooth headset to your Blackberry once. Once you configure the pairing between the two devices, the settings are saved and you do not have to repeat the processes each time you use it.
Turn off the Bluetooth radio on your Blackberry when not in use for security reasons.
Adjust volume on your headset or hand-held to a comfortable level. Excess volume from in-the-ear headsets can cause hearing damage.
Jan 06, 2011 | Plantronics Explorer 230 Bluetooth Headset
How to use bluetooth device in acer aspire 5745.
first the blue tooth device need to be installed , meaning to have the driver for the device ...after that from the blue tooth button you turn it on ..and the device could be find on any other device with blue tooth and be chosen to receive data ..the same way arround..if you open the blue tooth ..you can search for devices ..and choose data to send to devices found in the area..
Oct 01, 2010 | Computers & Internet
Were trying to ste logitech g25 to our ps3 with great difficulty.we are on manage bluetooth devices and it started scanning but this has been going on for a while.is there any advice someone can give us.
yes, okay.. there should be the turn on button on your blue tooth headset, make sure the blue tooth headset is off.. now before you start the scan, hold down the power button for the blue tooth until it starts blinking colors.. usually red and clue, then start the scan, the pass code for the blue tooth will also be 0000, it is for mostly every single one
Sep 19, 2009 | Sony Playstation 3 (PS3) Console
Can't bond Samsung bluetooth(WEP 200)with my Motorola A1200 Ming
Try this (from the manual)
2 Press and hold the Multi-Function button until
the indicator light turns on in blue
(approximately 8 seconds).
Oct 31, 2008 | Motorola Mobility MING A1200
Acer Aspire 6920 Notebook PC Logo
63 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
