Question about Dell Inspiron mini 9 - Black , Intel® Atom Processor® N270 1.6 Ghz , 1 GB DDR2 at 533MHz, 8GB Soli... PC Notebook
My dell inspiron mini has decided to show a
My girlfriend was using her Dell Inspiron mini, while she was typing she hit a key that caused the display to go sideways...this is really a bit of a problem...how can we make the display go back to normal?
  • 25 Answers
Try holding Ctrl+Alt keys and then pressing the up, down, left or right arrow.
Posted on Nov 17, 2009
How do i restore factory settings on my dell inspiron mini 1018
This is quite easy to do, when your turn on your computer you need to hit a hotkey over and over again. The hotkey is different for each type of laptop but the common ones are f11, f1, f2, alt+0 and f12.
Once you reach the recovery screen you just need to follow the on screen prompts and you're all set
WARNING: Doing this will mean that you will lose all your personal data and installed programs that are on the computer.
Mar 21, 2012 | Dell Inspiron Mini 1012 Netbook PC
I want to factory reset a mini 10 but screen is broke(i am using t.v) im afraid to start the process and then not be able to see anything after
Yes that could be horrid. Try setting the tv as your only screen. If you go to l settings Navigate to the "Start" menu, and click it once to open it. Select "Control Panel." Click "Adjust Screen Resolution" under "Appearance and Personalization." Click the drop-down arrow next to "Multiple Displays" in the window that opens. Select "Show Desktop Only On 2." Windows will disable the Mini 10 display and use the external monitor as the primary screen Read more: How to Run an External Monitor on a Dell Inspiron Mini 9 ' eHow.com http://www.ehow.com/how_6821296_run-dell-inspiron-mini-9.html#ixzz1hFvetaud
Nov 25, 2011 | Dell Inspiron Mini 10 Notebook
My Dell inspiron mini 10 is just over 1 year old not used very much at all, last week for no reason there is no display on the screen, I tried to reboot on battery power and ac no luck. Thanks Frank.
There are 3 mini 10 models sold by Dell. The Inspiron 1010 (Mini 10), Insprion 1012 (Mini 10) and the Insprion 1018 (Mini 10v). Depending on which model you have, you can try to connect an external monitor and see if you get a display. The 1012 and the 1018 have a 15 pin VGA plug on the left side of the laptop and the 1010 has an HDMI jack for video. If you get a display then your LCD display is bad and needs to be replaced.
Feb 07, 2011 | Dell Inspiron Mini 10 Notebook
I have a Dell Inspiron Mini Laptop 1012, how do you set it to factory seting?
You will lose all your data if you wanna set it to factory setting ,have its back up before you loose it.
Here is how to restore at Factory Setting..
1: Restart the computer, click Start, click the arrow next to the Lock button, and then click Restart. 2: As restarts, press the F8 key until the 'Advanced Boot Options' ,menu appears on the screen.It should come up before Window logo appears. 3. Press the (Down Arrow) to select Repair Your Computer on the Advanced Boot Options menu, and then press Enter. 4. Specify the language settings that you want, and then click Next. 5. Log in as a user who has administrative credentials, and then click OK. 6. Click Dell Factory Image Restore. 7. In the Dell Factory Image Restore window, click Next. 8. Click to select the check box for Yes, reformat hard drive and restore system software to factory condition. 9. Click Next. The computer is restored to the default factory configuration. 10. When the restore operation is completed, click Finish to restart the computer.
Jan 05, 2011 | Dell Inspiron Mini 1012 Netbook...
Loud beeps at start up dell inspiron mini
Beep codes for the Inspiron Mini are as follows:
Beep Code Possible Problem
One Possible system board failure — BIOS ROM checksum failure
Two No RAM detected
NOTE: If you installed or replaced the memory module, ensure that the memory module is seated properly.
Three Possible system board failure — Chipset error
Four RAM read/write failure
Five Real Time Clock failure
Six Video card or chip failure
Seven Processor failure
Eight Display failure
Jun 10, 2010 | Dell Inspiron Mini 10 Notebook
Fomating dell inspiron mini 10
You can make a bootable USB stick with everything you want and boot from it.
Stelios.
Feb 21, 2010 | Dell Inspiron Mini 10 Notebook
Dell Inspiron 1440 keyboard keys issue
you need to isolate this issue first.
where are you typing? inside IE or in MSWord?
If both has issues then try typing in the DOS Command Window. If same issue try to boot in safe mode and check if you will still be getting same issue in safe mode. If all yes try to check the bios and update it by downloading the latest bios version from the support site from dell.
Oct 06, 2009 | Dell Computers & Internet
I am trying to restore my computer to original state. Was told to use Ctrl F11. This doesn't to anthing. Help
don't hit ctrl f11 instead hit F8 and then go into Dell Factory Image Restore, that will wipe, format and reinstall all the factory software that's stored on the Recovery Drive.
or reformat your laptop using your cd
Sep 29, 2009 | Dell Inspiron 1501 Notebook
Dell Inspiron mini 9 - Black , Intel® Atom Processor® N270 1.6 Ghz , 1 GB DDR2 at 533MHz, 8GB Soli...  PC Notebook Logo
240 people viewed this question
Alun Cox
