Question about Maytag MDG2706A Gas Dryer
Can gator bite connectors be used on natural gass connections
  • 441 Answers
NO, to much risk of arking
Posted on Nov 17, 2009
Peg perego gator model IGOD004
those are the wires that connect into the battery
Jul 01, 2013 | Toys
Battery connectors get hot on gator
are both wheels turning in all of the gears?
May 21, 2012 | Peg Perego John Deere Gator HPX Ride on...
What should the gass pressure drop be when heater is running befour gass valve. propane
MOST OF THESE UNITS ARE FACTORY SET ORIFICE FOR NATURAL GAS AND WILL SMOKE IF USED ON LP
Oct 22, 2011 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
My sons gator will only got in reverse it wont go in forwrd
Pull the shifter switch out and verify that the connectors under neath are connected
Aug 30, 2011 | Peg Perego John Deere Gator HPX Ride on...
Will it run on natural gas at 7 inches pressure from the city mains? Will it help to take the gas pressure regulator off ? Has anyone done this yet? I'm tired of refilling the tanks and figure it may...
If you connect natural gas to a device that is set up for propane it will most likely not work. The caloric content of the two gasses is different and will cause the fuel to air mixture to be wrong. If Sketervac makes a kit to change it to natural gas then that is a way to do it. I hope this helps.
Please vote on this answer. Thank you.
Aug 24, 2011 | Skeetervac SV-3100 Mosquito Exterminator
We got our grandson one of these last christmas and we lost the charger and I have found the charger now but, need directions how to charge it and where to plug it into? Please help with any...
Open the hood, and look for the battery. The battery has a blue connector that is connected to the Gator. You need to squeeze the plastic tabs on each side of the connector to separate them. The charger has a similar connector as the battery. Once you have the battery connector separated from the toy, plug the charger in to the wall and connect the charger to the battery by pushing the connectors together. Allow the battery to charge for about 18 hours for a full charge then remove the battery from the charger. The battery should be charged once a month to mantain the battery. People often forget to keep the battery charged once a month, otherwise the battery won't charge when the kiddies come to play. Hope this helps.
Jul 09, 2010 | Peg Perego John Deere Gator HPX Ride on...
We would like to connect an imperial us copper pipe to an Australian copper pipe. These are water pipes in peoples homes. We are using the imperial standard, which is a bit different from the Australian. I...
they make a piece that fits numerous sizes of pipe, it just slides on, at the Home Depot I think they are called the Gator Bites, lowes has similar but doub't know the name, you have to know what size you are close to ie 1/2 , 3/4 etc
Dec 18, 2009 | Plumbing
PLUMBING - compression valve is leaking
Try Gator Bite plumbing connectors. Quick and easy, they come in all different configurations...available at Home Depot.
I use them...they work great!
Mike...
Nov 21, 2009 | Plumbing
I have a Kenmore natural gas grill, model # 141-17227. I need the woners manual. The side burner will light but very low flame, cannot get the grill to light.
owners manual can be gotten through the internet- Sears.com find parts,type in model# of item, select manual sounds like valves are clogged- propaine and natural gasses are dirty gasses-no filter, it comes up out of ground,through dirty pipes, all the way to peoples homes- and thats why they have to replace valves on hot water tanks/furnuces........
Jun 19, 2009 | Kenmore 505 sq. in. Cooking Area Gas Grill...
Maytag MDG2706A Gas Dryer Logo
112 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
