Question about LG Prada KE850 Cellular Phone
Date Changing Since the year has changed to 2008, my phone isn't changing the days date correctly. I have tried resetting the date but for some reason it just doesn't last. At midnight last night it had changed over to 10/01/2008 but when I woke up it was 09/01/2008. I don't know if it is related or not but my alarm wont go off at the time i set it either! I haven't got to work on time once in 2008 hahaha!
  • 2 more comments
  • Aldona Jan 10, 2008
    I have the same two problems
  • aus_jess Jan 10, 2008
    Aldona, not sure if you saw the other thread on the same topic but someone in Holland contacted LG who have told them to send their phone in to be repaired. Most people seem to be having the same problem so you may want to conact LG!
  • Anonymous Jan 22, 2008
    I am having the same problem as well -- that is, the date not changing. It seems to be 1 day behind always. I correct it manually myself, but after midnight, it ends up lagging behind again :(
  • Trababe Jan 23, 2008
    OMG! i have the same problem Grrr! it is driving me mad! What am i meant to do ..send my phone back??? Cheers Tracie.
Type 2945#*# C > Engineering menu will show up then select Factory Reset. This should solve the problem. Worked for me!
Posted on Jun 13, 2008
You shud try change settings so that date and time will auto update. this is under settings, date & time, auto update....mite work!
Posted on Jan 11, 2008
Cannot advance date manually when crown is in 1st position on eco citizen ladies watch
Return for warranty repair. They have a 5 year warranty. Your instruction book has details and address to send it in. Send a copy of your receipt also.
Oct 08, 2012 | Watches
Advent 5431 date keeps changing back to 2008
IS your TimeZone is Correct?
Right click on your clock, choose Adjust Date/Time.
Click Time Zone Tab. Make sure your Time zone is correctly set.
Boot into the BIOS (setup) screens and check the date and time there. If the date is off by years then that verifies you need a new CMOS battery. Do not confuse the CMOS battery with the large external battery you run the computer with.
Jul 25, 2012 | Advent Netbook
Hi, My watch is changing date at 12 noon instead
Your watch is 12 hours out of step. (The date changes every second revolution of the hour hand.)
Wind your watch forward 12 hours, (you may have to reset the date) and it will then change around midnight.
Jun 07, 2011 | Hamilton X-Wind H77646733 Wrist Watch
My LG KS360 phone has developed a date fault since 1 Jan 2011 whereby it is saying 32/83/2010. I cannot fix it. Please advise.
Noticed the same problem today. The "set date" option wouldn't let me reset the day, month or year to anything sensible. Changed the date format to MM/DD/YYYY (it was previously DD/MM/YYYY). Then it let me set correct month, day and year. Reset the date format back to DD/MM/YYYY and it's still correct (and will now let me change it while in this format). Don't understand it, but seems to have fixed the problem. (Guessing it was something to do with 2009 changing to 2010??). worked for 2011 also.
Jan 02, 2011 | Cell Phones
I need to change the time.
Must be done on a MLX20-L
Changing the time on a Avaya Merlin Magix system is accomplished from the system programming console. The date is change separately from the time.
Changing the date:
1. Press Menu
2. Press System Program
3. Press Exit or Start
4. Press System
5. Press Date
6. Enter the date as: mmddyy where mm = month, dd = day, yy = year
7. Press Enter
8. Press Exit or Back
9. Press Home or Exit
Changing the time:
1. Press Menu
4. Press System
5. Press Time
6. Enter the date as: hhmm where hh = hours & mm = minutes
7. Press Enter
Nov 02, 2009 | Avaya MLX 5D Corded Phone
Mitsubishi HS-U500
Just set it to record"today" choose the correct day and month,the year will be unimportant.
Sep 24, 2008 | Mitsubishi HS-1280U VHS VCR
Mobile phones
yeah tht is a bit of a prob. one way to eliminate tht is by using the 24hr clock. having set it to 24hr mode i found eliminated the prob.
but again the phone does have a bug with the date changing back and lg needs to address it.
Feb 26, 2008 | LG Prada KE850 Cellular Phone
Date
I also had this problem. I changed the date to the next days date. It then changed back to the previous date (which was now the correct one) and so far it has stayed there... hope it works for you.
Tam
Feb 13, 2008 | LG Prada KE850 Cellular Phone
Date not changing on mobile phone
Hi i had the same problem
wot i did was change the date to a day forward say the 10th of jan
and then it automatically started working after tht
(previously it was going back a day so i just used the date of the next date and left it like tht and it has been ok since then)
Jan 03, 2008 | LG Prada KE850 Cellular Phone
Wrong date on the radio.
RESETTING THE CLOCK AFTER A TOTAL MEMORY LOSS
If you do not change the built in lithium battery within a reasonable period of time after you see the ‘flashing’ LOW BATT. warning indicator, the lithium battery may become exhausted and will no longer be able to supply back up power to the SmartSet internal computer.
If the unit is disconnected from the AC outlet after the battery is exhausted, or if a power interruption occurs, the SmartSet memory will be lost and the clock will need to be reset when the power is restored. Be sure to install a fresh lithium battery before you reset the clock, otherwise the clock will need to be reset each time the power is interrupted.
If the lithium battery is exhausted and you experience an interruption in the AC power supply, the clock will reset itself to its initial default setting when the power is restored.
The initial default setting is “12:00 AM, Saturday, January 1
(1 1), 2005”.
If you notice that the time on your SmartSet clock radio is completely incorrect, and the day indicator is also wrong, press the MONTH/DATE button to see the date. If the date display is showing “1 1” (January 1 ), you probably experienced
a total memory loss. To reset the clock after a total memory loss, proceed as follows:
1.) Install a new CR2430 lithium battery in the battery compartment.
2.) Connect the radio to your AC outlet and let the clock set itself.
3.) Depress the MONTH/DATE and TIME buttons together. The display will change from ‘time’ to ‘year’. While holding the MONTH/DATE and TIME buttons, press the UP button to
set the display to the correct year, then release the buttons.
4.) Depress the MONTH/DATE button. The display will change from ‘time’ to 'month/date’ (mm/dd). While holding the MONTH/DATE button, press the UP button to set the display
to the correct month and date. The Day indicator will change automatically as you adjust the month/date settings. When the correct month and date appear on the display, release the buttons.
5.) Depress the TIME button and the UP button to set the display to the correct time. Be sure to confirm that you have set the time correctly to ‘AM’ or ‘PM’ by observing the AM indicator.
6.) After you set the time, reconfirm that the Day, and Month/Date displays are still correct. Make final adjustments if necessary.
The SmartSet clock memory is now reset and the new lithium battery will maintain it for the next 5 to 8 years, depending on the number and duration of the power outages you experience.
IMPORTANT NOTE:
After resetting the clock, don’t forget to reset your wake up times, and alarm mode settings, and sleep timer settings as well.
Oct 22, 2007 | Emerson SmartSet CKS1850 Clock Radio
LG Prada KE850 Cellular Phone Logo
125 people viewed this question
Top LG Cell Phones Experts
skiffy99
skiffy99
Level 1 Expert
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
