Question about Kitchen Ranges
Stovetop burners won't ignite. Piezoelectric non-operational
Stovetop burners won't ignite. Piezoelectric starters non-operational. Lights with match. Oven operates normal.
  • cbsteele2 Nov 17, 2009
    Thank you for your response. Yes, she cleaned the burners 3 days ago. I just retried and they are now functional! Surprised that the ignitor(s) would take so long to dry out. Are the ignitors linked in series or parallel, i.e., if one is damp will all fail to spark until damp one dries??
  • John Riley May 11, 2010
    have you cleaned top recently, if so the ignitors might be wet, will take a day or two to dry
  • 441 Answers
Each ignitor is seperat, but it does not take much water to get them to not ignite
Posted on Nov 17, 2009
Testimonial: "Use this site! Response was very quick and knowledgeable. Thanks!!!"
Igniters won't lite on stovetop
Check the wiring connection to igniter. If electricity is reaching the igniter and still nada, then the igniter is bad and needs replacement.
Oct 26, 2015 | Kitchen Ranges
Frigidaire GLG=F366asd stove igniter problems and solutions . ... on the element lights up the smell of gas is real strong and then it lights and sounds like an explosion.
Where is the problem -- in the oven burner or a stovetop burner?
If something got spilled on a burner ring and clogged the small holes, especially near the igniter, the burner will be slow to light. A stiff wire (small enough to fit) can be used to clean out the holes.
Mar 18, 2012 | Kitchen Ranges
Starter clicks but doesn't light burner
either the gas valve for that particular burner isnt opening,or if all burners are like this then the dual valve that feeds the broiler and stovetop has a bad stove top side of valve portion its underneath the oven cavity behind the lower pan drawer
Jul 31, 2010 | Jenn-Air 30 in. CCG2423 Gas Cooktop
You have to light burners on stovetop with a match all the time.
The pilots for the range top are beneath the top of the range top. YOu will see them if they are there. YOu stove may use electronic ignition and you can hear the sparking when you turn the knob to the "light" position.
If it is electronic ignition, make sure the stove is plugged into an operating outlet
Apr 15, 2009 | Tappan MGF500PBW Gas Kitchen Range
One stovetop burner does not initiate igniter sparking.
Its most likely the igniter. It might just be dirty, but its easy to install a new one. They are attached by two screws and a single plug. I'd suggest turning the power off to the stove before plugging in a new one.
Feb 14, 2009 | Viking VGSC306-4B Gas Kitchen Range
How to light oven with electric power off?
Sorry, but this oven will not work without electricity. Looks like stovetop suppers for a few days. Hope this helps!
Jan 28, 2009 | Ovens
Stovetop not lighting
Get a small wire brush and scrub around the ignitor real good so that it can get a good ground.
Jan 08, 2009 | Kitchen Ranges
My Oven and broiler won't heat but stovetop burners work
I have a Frigidaire Model Number GLGF377ASF. The stovetop burners work just fine but the oven and broiler do not work.
Dec 08, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Gas stovetop burner - continuous clicking
WHEN CLEANING YOUR BURNERS YOU HAVE PROBABLY MOVED THE IRON TOPS-READJUST AND YOU WILL FIND THE CLICKING WILL STOP.
Sep 18, 2008 | Cooktops
Igniters do not spark on one side of cooktop
Is the gas able to flow freely through and out of the bad burners? Sounds like they may be clogged somehow
Jul 11, 2008 | Jenn-Air JDS8850AAS Dual Fuel (Electric...
Kitchen Ranges Logo
203 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
