Question about Hayward Comfort Zone Electric Spa Heater 11kw
New contact coil chattering,when adjusting thermastat from high to low. Works well on high. I have a Hayward electric spa heater, 11kw.
Is there an adjustment on the cspa xi contact to stop the chattering
Posted on Jan 09, 2011
  • 990 Answers
Their is a chatter guard built into the safty circut and it's job odley enough is to stop this from happening. Your heater needs the buffer this provides to keep the thermostat from cycling on and off when you are close to the set point. Good luck with this all the info you should need is in your book.
Posted on Dec 01, 2009
Can the hayward 11kw electric spa heater be install without a by pass
yes but it is better to be able to bypass you can also increase heat rise with it more efficient
Oct 01, 2012 | Hayward 11kw Electric Spa Hot Tub Heater...
Hello, please tell me what breaker (amps) do I need to use with Hayward 11kw Electric Spa Hot Tub Heater Cspaxi11. What is the normal amp consumption for this equipment? Thanks
Hi and welcoe to FixYa, I am Kelly.
11,000W is the maximum power that it could draw. Given the wattage is over 10,000 I am certain that your Spa / Tub heater is 220 VAC If it is 220 VAC then you will need a 50 Amp breaker. If it only 110 VAC you will need a 100 Amp Breaker. (Gasp!)
Amp consumption will always vary.
Heater on / Off
Number of Blowers and pumps in operation at any given time. Then add lights to the equation. My best guess at any given time it is in "full operation" it will average 6,000 - 7,500 watts. When not in full use it the average amp usage would drop substantially.
Thanks for choosing FixYa,
Kelly
Feb 21, 2011 | Hayward 11kw Electric Spa Hot Tub Heater...
What size breaker does the 11kw hayward comfort zone electric spa heater require?
It does make a difference as to input voltage. But usually at 11KW this would be a 220V unit and require a 50 amp breaker. 11,000W divided by 220VAC = 50 amps. 230 or 240V input the same 50 A breaker.
Thanks for choosing FixYa.
Kelly
Aug 27, 2010 | Hayward Comfort Zone Electric Spa Heater...
Pool heater thermostat lights up but water do not get hot, need wiring diagram.model#C-SPA XI 11,240 volts 5.5kw or 240 volts 11kw
There should be a large, easy to read diagram under the cover once you remove it from the heater. Is the one under your missing or unreadable? Hayward doesn't publish one on their tech website or residential documents page so I have an email into our tech support contact asking for one in case yours is missing. If you find it under the cover please add a comment to that effect. FIXYA website has not been letting me post pictures lately so getting you the info may be a little difficult.
Dec 29, 2009 | Hayward Comfort Zone Electric Spa Heater...
Hayward Comfortzone pool heater pilot will stay lit but main burner will not fire. If the TH terminals are jumpered it will, but it won't stay on.
Have you tried jumping the pressure switch, as well as the on/off switch. sounds like something in the safety circuit is open
Jun 10, 2009 | Hayward Comfort Zone Electric Spa Heater...
My Hayward electric spa heater 11KW is coming on for thirty minutes, then throws the breaker. If I switch back on it will throw it again in another 30 mins or so. It appears to be heating then throws the...
Chances are that your element is drawing too much current. Check the manufacturer's website to make sure that you have the correct size breaker installed. Low water flow could also affect this, so make sure all of your baskets and filters are clean and clear.
Apr 05, 2009 | Hayward Comfort Zone Electric Spa Heater...
Hayward Comfort Zone Electric Spa Heater 11kw Logo
154 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
