Question about Sony Playstation 3 (PS3) Console
Once i plug in my ps3 slim into my standard (normal) tv will it automatically read it or not?
  • 490 Answers
Yes of coarse y wouldn't it? all appliances work the same you plug in and play
Posted on Nov 17, 2009
My ps3 does not transmit video or audio on any cords
Reset Video Output
If you are changing cables or cannot see an image on the screen, you may need to reset the video output to default settings. To reset the video output:
  1. While the PS3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive On/Off button on the front of the system until the PS3 beeps a second time (approximately 5 seconds), then release it.
  2. The PS3 will power up, the Video Output Settings will automatically reset to the standard resolution (or detect the current display output settings of your TV/monitor).
Dec 23, 2013 | Sony PlayStation PS3 Slim 120GB Bundle...
I recently moved house and have connected my ps3 80gb to a TV not previously used to connect the ps3 to. When I switch on the ps3 all I get apart from the Sony log on tune is multi coloured vertical wavy...
It sounds like the PS3 is sending a signal that the television isn't 100% compatible with. I'd start by plugging the PS3 in using standard RCA jacks, and making sure that the video and audio configuration settings are all set to automatic. Then, plug back in using the HD cords that you have, and the PS3 should reconfigure its signal output to match what the TV can handle.
Mar 16, 2011 | Video Game Consoles & Games
When i turn on my ps3, the green light stays on and the tv screen doesn't even change. i changed the cords to make sure the audio/video wasn't just out. i tried to enter 'recovery mode' but it won't even...
If you have a "slim" ps3, it does not beep 3 times. Try this.
First, with the system off,plug in your old red, white, yellow cables into the tv. (make sure your tv is on the correct setting). Now, just turn on the ps3 the regular way. Did you hear the sounds it normally makes when booting up (the ps3 boot music?). If so, thats good. If you did not, check again that the tv is on the right channel, and if possible, try another set of red, white, yellow cables.
If you heard sound, but do not get a picture, turn the ps3 back off. After the red light comes on, hold your finger down on the power button for about 5 seconds. If you have a fat ps3, it will beep 3 times after a few seconds to get back to regular tv mode. If you have a slim ps3, it will beep once, then 1 more time a few seconds later. It should reset and turn back on. If your tv is on the right channel and the cables work, then you should now see a picture and you know your audio/video is working. You can now try your HDMI cable and it should prompt you to use the HDMI at this point.
Hope that helps.
Mike!
Mar 02, 2011 | Sony Playstation 3 (PS3) Console
I have a PS3 slim console and it is having some internet problems that I cannot figure out. I have a CAT-5 ethernet cable plugged directly into my modem which is directly connected to my PS3. Many times...
PS3
You will have to open the following ports in your modem /router
Make sure the firewall is disabled in the Modem /Router
Make sure that UPnP is Enabled
Playstation Network Required Ports
TCP 80
TCP 443
TCP 5223
UDP 3478
UDP 3479
UDP 3658
Playstation Online Game Ports
Call of Duty 3:
UDP 3074
TCP 3074
MotorStorm
UDP 3659
UDP 3660
You can use http://whatsmyip.org/ports/ to test if the ports are open.
Nov 07, 2010 | Sony PlayStation 3 Slim Black Console
My PS3 Slim 120GB won't read Blu-Ray games!
I had this problem once this is what you do... goldcoast.gumtree.com.au/c-Stuff-for-Sale-tv-audio-music-SONY-PLAYSTATION-3-PS3-SLIM-120GB-GAMING-CONSOLE-BLUR...
Jan 08, 2010 | Sony Playstation 3 (PS3) Console
Switching our ps3 from hd to normal
with only the PS3 and the TV connected, touch and hold the systems’ power button for more than 5 seconds to switch the system back on. The video output settings will automatically be reset to the standard resolution
Feb 22, 2009 | Sony Playstation 3 (PS3) Console
Can a sony ps3 work in a standard television
yes it can,u willl have to use the supplied vga cables and adjust the display settings on the ps3,perhaps to 480P..hope it helps!
Nov 16, 2008 | Sony Playstation 3 (PS3) Console
Connecting x rocker chair to ps3
I HAVE THE SOLUTION for all ps3 and ps3 slim gamers with the x rocker chair. it took my 2 long hours of frustration but i finally figured out how to make it work with ps3 slim. okay, forget about the red and white audio output plugs, those aren't needed. (my tv has no audio output jacks so i had to find a different solution) find the cable with the green headphone plugs on both sides. plug one end into the tx box and the other into the headphone jack on your tv. make sure your sound settings on your ps3 are set normally so that the sound is coming out of the tv. turn on the tx box, turn up the chair volume (and volume on the tv) and there you have it. enjoy!
Oct 04, 2008 | Sony Playstation 3 (PS3) Console
Hd to normal tv problems
i had the same problem, but the reset worked for me, hold down the power button until u hear the "beep"
Apr 26, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
44 people viewed this question
Top Sony Video Game Consoles & Games Experts
shaun taylor
marley mcelhinney
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
