Question about Car Audio & Video
Unlock code for mit factory rado
Ineed the code to unlock my radio
  • fishman45 Jan 10, 2008
    Need Help
  • prettylilmis Aug 18, 2008
    i need the code to unlock my aiwa cdc x207
  • 2,042 Answers
If it a factory radio reove it call dealer they gonna ask for the number behind the radio and they suppose to give you the code cheers
Posted on Jan 14, 2008
6ya staff
SOURCE:
Anyone know a rado unlock code for 1995 mercury sable? I replaced battery and radio hasn't worked since. Has power to it (lights up when headlights come on like it's supposed to) but when you try to turn...
Hello, Donald -
Have you thought to check with a Mercury auto dealer in your area to find out the right radio activation code for the radio? The dealer may be able to obtain the code using the VIN.
Best wishes.
Jan 24, 2018 | Mercury Cars & Trucks
Ineed unlock code please
Unlock code only comes from your Telecom carrier. It is locked with a PUK code which they supply when you take the service.
If you mean a user password because you found it, you would have to do a factory reset via a computer.
Dec 10, 2015 | Samsung Evergreen SGH-A667
Hi.. I have a alcatel OT 4010x and i cant get my unlocking code anywhere.. Provider ID 4010X-2CTWIE1... Network is Tesco Moblie... And i live ine ireland... So if you can get m
There are 2 methods to make factory data reset on your phone:
Method 1: Under power on mode
Please go to menu > Settings >Privacy >Factory data reset
Method 2: Under power off mode
Turn off the handset, press the volume up key and the Power key at the same time for a few seconds until you see the reset interface, then press Home key >select wipe data or factory reset via volume key > Press Power key to confirm > Select Yes to delete all user data > Press Power key to confirm again > Please select Reboot system now and press Ppower key to confirm to reboot your phone. The handset can be used without screen unlock pattern after its reboot.
Please note that factory data reset will erase all data from your phone. If you want to quit it before performing factory reset, you can select Reboot System Now or remove the battery and re-insert it, then restart the phone
Feb 02, 2015 | Alcatel Cell Phones
Ineed factory wiring colors for 88 monte carlo radio
Does this have 3 plugs or just one in the back of the radio? If it is 3 plugs, here are the color codes:
http://www.tehnomagazin.com/images/GM12-car-radio-wiring-connector-audio.gif
Nov 07, 2014 | Kenwood Kos-a300 Factory Radio Upgrade...
Is there a way to get a radio unlock code for 2001 Mits. Galant without taking the radio out and looking for serial number?
need to notify a dealer for the code-- but call first they can also advise how to retrieve the radio id code or can advise of using the vin number of vehicle
Apr 08, 2010 | 2001 Mitsubishi Galant
Radio is locked. Serial code 462473 Ineed the unlock code
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} The radio will have to be removed from the car dashboard .
Then please quote the MAKE + MODEL of your radio plus ALL the LETTERS and NUMBERS on any LABELS , BARCODES or STAMPED IN THE METAL CASING.
Also quote the MAKE of CAR it is fitted into.
Mar 09, 2010 | Vehicle Parts & Accessories
I have a Mit. Montero Sport 1999
Your code is 4886.
Use preset button 1 to scroll through the first digit, preset button 2 for the second digit, etc.
Once the correct code is displayed, push the unlock button to unlock the radio. The unlock button varies between models, but it is always either CD, AM/FM, or TAPE. There is no penalty for pushing the wrong one as long as your code is correct.
Aug 15, 2009 | 1999 Mitsubishi Montero
After changing my battery my rado shows LOC on the display. I didn't have the code when I bought it my chevrolet venturra 1997. Please help me
you will have to take the vehicle to the dealership for them to unlock your radio. for those radios the loc feature should be something that the user sets and is only active when power is removed but can by undone by the dealer they usualy do not charge for this.
Apr 21, 2009 | Car Audio & Video
CD PLAYER CODE LOST
If it is a factory radio you will have to remove it> call your local mit dealer and give them the # on the back of the radio. They will tell you the code.
Mar 28, 2009 | 2007 Mitsubishi Montero Limited
Radio code
According to the dealership, Chrysler doesn't use lock code on their radios. The dealer advises to buy a new radio.
Jul 06, 2008 | 2001 Chrysler Voyager
Car Audio & Video Logo
88 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
