Question about Garden
Injector line connected to all three injectors
I have a fuel Injector line connected to all three injectors broke on end. Is this a return line of some sort? It's all one piece across the injectors. Not the main feed on top. It has a rubber tube on one end and hard line on other end but has collars that slip over each injector connected to each other by hard line.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 197 Answers
Are there wires connected to each injector?Confused about"not the main feed on top"Older John Deere's would run the return line back to the tank in plain sight.Hook up a hose to the line and run to a container and see if engine will run.If runs OK that would be your return hose,if not that would be your high pressure line.
Posted on Nov 17, 2009
I am breaking oil pipe injector lines at the bango bolt where it goes in the injector pump. What can cause this
Not knowing the car model/engine - a couple of things come to mind: Over tightening the banjo bolt, incorrect oil line placement while tightening, and missing brass washers on the banjo bolt.
Oct 13, 2014 | Cars & Trucks
03 3.7 have new o rings for bottom of injectors do you put it on the head first or on the injector just put head gaskets on jeep
old post but see it asked many times.
assemble the rail first, its 1 piece so must be ready first.
3.7L Engine (FSM) RTM?
(1) If fuel injectors are to be installed, refer to Fuel
Injector Removal/Installation.
(2) Clean out fuel injector machined bores in
intake manifold.
(3) Apply a small amount of engine oil to each fuel
injector o-ring. This will help in fuel rail installation.
(4) Position fuel rail/fuel injector assembly to
machined injector openings in cylinder head.
(5) Guide each injector into cylinder head. Be careful
not to tear injector o-rings.
(6) Push right side of fuel rail down until fuel
injectors have bottomed on cylinder head shoulder.
Push left fuel rail down until injectors have bottomed
(7) Install 4 fuel rail mounting bolts and tighten.
Refer to torque specifications.
(8) Install 6 ignition coils. Refer to Ignition Coil
(9) Connect electrical connectors to throttle body.
(10) Connect electrical connectors at all fuel injectors.
To install connector, refer to (Fig. 37). Push connector
onto injector (1) and then push and lock red
colored slider (2). Verify connector is locked to injector
by lightly tugging on connector.
(11) Connect necessary vacuum lines to throttle
body.
(12) Connect fuel line latch clip and fuel line to
fuel rail. Refer to Quick-Connect Fittings.
(13) Install air box to throttle body.
(14) Install air duct to air box.
(15) Connect battery cable to battery.
(16) Start engine and check for leaks.
Oct 07, 2014 | Jeep Cars & Trucks
Cambelt timing marks 4jx1
sounds like the injector sleeve O rings have failed this was common.
if you put a clear plastic piece of hose on supply line for diesel fuel filter to head fitting at front and fuel is not black but normal diesel colour thats good.
then put clear hose on return line fitting at rear of cylinder head and fuel is now darker, engine oil is by passing injector sleeve top O rings and entering into fuel gallery in head.
rocker cover, injector rail, injectors need removing and injector sleeves need replacing as well as O rings and seats.
a special tool is needed to remove the injector sleeves out of the head. you will also need to drain the cooling system before removing the injector sleeves, so coolant is also needed.
dealers have special tool for injector sleeves
Mar 28, 2014 | 1998 Isuzu Trooper
Can you remove the injectors on 2003 Jeep Grand Cherokee diesell whithout removing the engine not a lot of space to get the back injector out ???????
YEP REMOVE TOP ENGINE COVER AND DISCONNECT INJECTORS ELECTRICAL CONNECTOR,REMOVE FUEL RETURN LINE FROM INJECTOR, REMOVE FUEL INJECTOR HIGH PRESSURE LINE, REMOVE FUEL INJECTOR RETAINER AND RETAINING BOLT,THEN REMOVE FUEL INJECTOR FROM THE CYLINDER HEAD. YOU NEED A FUEL INJECTOR EXTRACTOR TOOL 9075A ON TO INJECTOR AND CYLINDER HEAD.YOU DONT HAVE TO REMOVE THE ENGINE.
Jun 29, 2011 | 2003 Jeep Grand Cherokee
99 Astro van. This engine has a supply and return line from the injectors. Is it possible to flush the system by plugging the return line and running a can of injector flush through the system myself...
You may further cause problems. I would recommend disconnecting the fuel line at the injectors, and disconnecting the fuel line before the gas tank, making sure there isn't a fuel filter along the way. If there is, then disconnect the fuel line at the filter. Use a compressor and blow air from the injector side, down to the filter end. Make sure you try and keep as much moisture out of the line as possible. You can do this with each segment of fuel line to flush out any particles that may have clogged your lines. Your filter may be your main problem. Try changing that first!
Feb 13, 2011 | 1999 Chevrolet Astro
86 buick century 2.5l. car sat about 6 months, no start, but when fuel is added to throttle body fires up. when i pulled the fuel line from TBI it sprayed across engine compartment. but when connected...
pressure underhood is good. i'd check the plug conection at the throttle body(injector).see that the injector trigger wires haven't been cut or crimped around the air filter.the injector can be removed from the body for cleaning,but you may want a shop to do that with an ultrasonic cleaner.does it spray at all when cranked?check all sensor connections too.
Jan 26, 2011 | 1986 Buick Century
Bmw 325tds diesel flowing back to tank when parked
usual problem ,valves in injector worn for the fuel pump.easy quick fix this one ,fit a non return valve in the inlet pipe,check flow direction on valve when fitting and evan better as well is another in the bleed off return pipe .valves available from a motor factor or a specialist garage like bosch or lucas ,cut pipe and fit the valve with a piece of rubber pipe to connect the valve in line.or listen to the people who want to milk the golden cow and have the whole injector pump overhauled .
Dec 23, 2009 | 2001 BMW 325
The three lines that go into the fuel pump. this is a plastic tanl
You have the 1. hi pressure line to the fuel filter and then to the injectors, 2. the return line from the fuel injector system to the gas tank. 3. you have the return line from the EVAP canister at the left rear of the blazer. Note it's common for the fuel line to leak along the frame rail where the lines are clipped on to the nylon brace. Hope this the answer your looking for, the only two lines that is going to have fuel is the hi pressure and return, the EVAP line is vapors from the canister.
Nov 03, 2009 | 1998 Chevrolet Blazer
1994 chevy fuel problem
The last pieces in the chain are the fuel regulator and the injectors. The regulator is inside the throttle body, but it sounds that maybe the injectors are not firing. For nothing else, check out the connections to the injectors. Possibly they are clogged. Try a few treatments of injector cleaner.
Jul 29, 2009 | 1994 Chevrolet K1500
Garden Logo
35 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
