Question about Whirlpool LER5636P Electric Dryer
LER 5620KQO won't start. Any ideas?
LER 5620KQO won't start. Any ideas? There is power running through line.
  • 612 Answers
I would think that you either have a bad thermal fuse, Thermal cut off or bad door switch. Most likely a bad thermal cut off.
Posted on Nov 17, 2009
  • James Hilton
    James Hilton Nov 17, 2009
    I would think that you either have a bad thermal fuse, thermal cut off or bad door switch. Most likely a bad thermal cut off
BMW x5 2003 rough idle lose power can start the car and won't Have any power restart it up to 3 times and runs normally any ideas
its probably the o2senser iam not real sure were it would be on a bmw but ive had the same problem before
Jan 21, 2013 | Cars & Trucks
When you push start button nothing happens
see this causes and fix it. God bless you
User Control and Display Board If the washer won't start, the user control and display board may be defective. Check for power to the washer first.
Timer If the washer won't start the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
Line Fuse If the washer won't start the line fuse might have blown.
Thermal Fuse If the washer won't start the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
Line Fuse and Holder If the washer won't start the line fuse might have blown, or the line fuse holder might be damaged and need to be replaced.
Main Control Board If the washer won't start the main control board might be defective. This is not common. Check other parts and causes first.
Door or Lid Latch Assembly If the washer won't start the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't start the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Incoming Power Problem If the washer won't start check to see if there is power at the electrical outlet which the washer is plugged into. Plug a lamp or radio into the outlet to check it. If the outlet is dead, check the circuit breakers or fuses for the home.
Power Cord If the washer won't start, check to be sure there is power to the electrical outlet for the home. If that is OK, the power cord itself might be defective. This is rare. You can check the power cord with an Ohm meter for continuity.
Sep 28, 2012 | Washing Machines
I have a 89 dodge lancer with out turbo it was running fine driving down the highway it all of a sudden lost power and died and it will turn over but won't start it is getting plenty of fuel and have...
It could be the chrankshaft sensor or the egnition coils. check to make sure that your plugs are getting spark.Can be a lot of things but this is a place to start.
Feb 18, 2012 | 1989 Dodge Lancer
I have a 026stihl that won't start
It would be a good idea to check the compression first to make sure there is enough to make the saw run. A person can run in circles trying to figure out an issue if the compression is below 100 psi, there should be about 150 psi. Older Stihl saws are also notorious for cracked fuel lines. Check the fuel line to be sure it is ok, also check the spark.
Aug 04, 2011 | Stihl Garden
Have a whirlpool dryer model #LER 7646AWZ...does not start at all..power is available
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jun 14, 2011 | Whirlpool Dryers
No heat but dryer runs
First verify 220 volts of power to the dryer at the wire terminal where the cord hooks up. Look for a loose or burned connection here also. If power is OK,ohm the TCO and hi-limit thermostat on the heater canister. Ohm the heater. No ohm reading on any of these parts replace them.
Sep 29, 2009 | Dryers
Whirlpool LER5636P Electric Dryer Logo
190 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
