Question about Refrigerators
Frigidaire FRS26R4CW1, buzzes. When I noticed that the freezer was warm the unit was unplugged. The refrigerator was left unplugged for about 20 hours. When it was plugged back in it was ran, was quiet and the freezer temperature quickly dropped to 0 degrees F. It ran for about 4 1/2 hours and then the buzzing started again and the temperature began to rise. After being unplugged for about 10 minutes, it was plugged in and again ran fine. Is it possible that the start capacitor or PTC starter is bad and causing the buzzing when the compressor tries to cycle on?
  • Refrigerators Master
  • 43,501 Answers
Yes, what you are asking is possible. It is also possible that the compressor motor has a flat spot or is even siezing up when hot. If you are comfortable changing the cap. then I would do that first a see what happens. Changing the compressor will be much more costly and maybe more than you want to put into you refrigerator.
Posted on Nov 17, 2009
Frigidaire FRS26R4CW1 icemaker not working and food freezes in refrigerator
Contact a tech professional to diagnose the unit. You could have a floating restriction in the coolant lines and cannot easily be found on your own.
Aug 05, 2012 | Frigidaire FRS26R4C Side by Side...
Both sides not getting cold... there is no ice build up... fan is running... there is a buzzing noise about every 20-30 min...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Sep 19, 2011 | Frigidaire FRS3R5EMB Side by Side...
Yesterday morning I noticed that the unit was buzzing. The refrigerator door had been left open and the temperature inside was 70 degrees. The freezer temperature was 20 degrees. This morning, 24 hours...
Hi
You have condesation built up in your freezer whereby the evaporator fan or the vents are most likely blocked off.
Turn fridge off. Empty freezer and either put a pot of boiling water inside freezer or with the aid of a hair dryer try to defrost the freezer. If you are able to remove the back panel on the freezer that would be ideal as you can directly target the frost.
Good luck
Ash
Sep 06, 2011 | Refrigerators
Frig warm compressor clicks on for about 20 secounds then goes off
heatman101
Aug 26, 2011 | Frigidaire Refrigerators
Model flsc23f6ds1 mfg 08 04 one day the light and the temp reading started flashing then it quit and thawed out . we unplugged it and left it unplugged for a few hours . we plugged it back in and in...
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
heatman101
Jan 26, 2011 | Frigidaire FRS3R5EMB Side by Side...
Freezer is not going below 20
Refrigerator
heatman101
Dec 30, 2010 | Frigidaire FRS-26DR7D Side by Side...
REFRIGERATOR AND FREEZER IS WARM. I HAVE UNPLUGGED THE UNIT AND IT STILL RUNS WARM AND DOESNT MAKE ICE
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
heatman101
Aug 31, 2010 | Frigidaire FRS23R4A Side by Side...
Frigidair Gallery fridge/freezer... Freezer is
change the control board in the rear lower left corner of unit part# 4334000 2 appliance parts pros
Oct 31, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
My refrigerator is 60 degrees and my freezer is hovering around 25 degrees
Seems to me that your defrosting timer is not working.When defrosting is not working unit will collect ice on element(Hidden)Could also be fan inside refrigerator which is not working properly.You need a repairman.Jan
Feb 02, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Refrigerators Logo
198 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
