Question about Jenn-Air JGD8345 Gas Cooktop
Jenn-Air gas cooktop downdraft fan sucks flames away from pans.
Just bought house with new Jenn-Air gas cooktop (Prostyle JDG8348CDP). Even on Low setting, the downdraft fan (between burners and grill) pulls the left front and back burner flames to the side (toward the fan) so much that it is difficult to get even cooking. Should there be a shield next to the fan vent? Or some other solution (other than abandoning those two burners)?
aborcass
  • 2651 Answers
SOURCE: Jenn-Air JGD8130 Gas Cooktop
grab hold of the installed burner cartridge at he top of unit and pry up slightly, should lift up without much effort, if not try lifting front side. they jsut lift up and slide back in no screws hold them in place
Posted on Feb 23, 2008
  • 1314 Answers
SOURCE: Jenn-Air 8130 installation problem
Rotate the blower to the proper angle
needed for your installation. The blower
can be swiveled 90°. To rotate the blower:
a) Remove the filter from the blower housing
b) Loosen, but do not remove, the nuts
around blower inlet.
c) Rotate the blower housing for the
proper angle.
d) Retighten the four nuts and install the
filter.
try this its general for this type of cooktop
Posted on Mar 30, 2008
  • 161 Answers
SOURCE: JENNAIR DOWNDRAFT COOKTOP
bibman: Sounds like the control switch or possible loose wiring. Take the element out and test the slots for voltage. You should get 220 Volts when on high.
DMA Jennair The fan motor is bad and needs to be replaced.
I suggest a new cooktop as THIS IS THE WORST DESIGNED COOKTOP I HAVE EVER USED. Not enough power, very hard to clean,
Posted on Jul 01, 2008
SOURCE: Jenn-Air 30 in. JGD8130 Gas Cooktop
Yes. Buy a burner module. Sears sells them also most appliance part stores. (I am assuming you have the model with 2 knobs on the grill side) The electric version of burner modules is around $100 Gas should be similar price.
Posted on Jul 07, 2008
Eddie Rentas
  • 59 Answers
SOURCE: downdraft vent on jenn air cooktop
Hello
Just get a dryer vent tube the flexible ones and some aluminum tape and that will do it, I had the same problem and thats how the gas company told me to do it and it works excelent.
Eddie Rentas
Tupper Lake NY
Posted on Jul 26, 2008
Jenn air downdraft fan 2e speed doesn't work
Probably the switch or a burnt out resistor.
Mar 18, 2014 | Cooktops
I used my grill for the first time, & the downdraft didn't work we'll, the house filled with smoke & eventually the downdraft shut off and I had to finish cooking in a pan. My Jenn-Air is...
The downdraft is electric so there must be something malfunctioning with it. It is a high volume downdraft fan that is to be vented to the outside. Could it be that something has clogged the vent hole up, not allowing the fan to evacuate the smoke?
While I am not a big fan of Jenn-Air, their fans are usually high quality if they are installed correctly, with the proper vent lines.
Jul 06, 2011 | Jenn-Air JGD8345 Gas Cooktop
I just replaced and old '80s Jenn Air downdraft cooktop with a new JED 8430 and the fan blows rather than sucks. How do solve this problem? Its wired the same as the old one with the whitel and ground...
Best off to call a reliable service company such as Sears. If you just purchased it, the repairs will be covered under the manufactures one year warranty.
Feb 01, 2010 | Jenn-Air JED8430 Electric Cooktop
Soot deposits from my brand new downdraft jenn-air gas cooktop
Is this on LP or Natural gas? If LP was it converted to LP? In any event,The air shutter must be adjusted on the gas burner tube. You need more air. The valve orifice may also need adjusting.
Sep 28, 2009 | Jenn-Air JGD8345 Gas Cooktop
What is the cabinet cut out for a Jenn-air 30" prostyle cooktop model# jcp430adp. The manufacturers specs are not specific
The pictures that are posted on the Jenn Air site are confusing. I waited until I received the unit to make the cuts. I am glad that I did.
Jul 18, 2009 | Jenn-Air 30 in. Pro-Style CCGP2420P Gas...
Downdraft cover and grill grates
i bought mine new from HD. Neither the dd cover nor grill grates have bushings on them. however thats a good idea.
Dec 31, 2008 | Jenn-Air JGD8345 Gas Cooktop
Downdraft vent on jenn air cooktop
How do you get the inside area of the vent clean from the grease and oils where the filter is?? I have a rectangular box style downdraft that the vent goes into the floor, I pulled the filter, but the box is to slender to get an arm into to scrub the grease....... does the bottom come off, or is it a sealed unit? How do you get all the brease from the bottom if you cannot reach it?
Jul 09, 2008 | Jenn-Air JED8230 Electric Cooktop
Exhaust fan not starting
Bearings are worn. You should be able to replace with a standard utility fan. You can find them at your local big box hardware store or order online here.
www.appliancepartsdepot.com
Jan 27, 2008 | Jenn-Air 30 in. CVG4280 Gas Cooktop
Jenn-Air JGD8345 Gas Cooktop Logo
292 people viewed this question
Top Jenn-Air Cooktops Experts
Dan Webster
Dan Webster
paulcarew
Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
