Question about Samsung RB215LASH
Why does the ice machine not fill the tray it will only drip the water out and shut off
  • 441 Answers
Change the filter
Posted on Nov 17, 2009
  • 489 Answers
SOURCE: Lg side by side Ice maker not filling all of the tray/dripping
You may have a restriction in the icemaker.  Remove the icemaker and make sure that there is no ice buildup other than in the cube slots.  Also make sure that the fill tube is clear of any ice obstruction.
Posted on Apr 27, 2008
  • 6 Answers
SOURCE: freezer drips water into frigde filling up ottom tray
Hello, If it is a top mount freezer then there is a drain that runs from the freezer to the drain pan that gets gummed up sometimes and if that happens then the water has no place to go but the fridge. Look all the way in the back of the fridge and you'll see a yellowish colored tube. You can just pop that out and take it to the sink and clean it out.. Hope this helps
Posted on Feb 18, 2009
Sea Breeze
  • 4654 Answers
SOURCE: brand new ice maker, water fill to tray will not shut off
The new ice maker should tell the dual water valve on rear of refrigerator to turn on if the tray makes a complete cycle. So the new ice maker is defective or the water valve on back is stuck open that leads up to the ice maker. Unplug the wires to the water control valve on back of the refrigerator and then turn the ice maker on. If the water continues to flow I recommend replacing the water valve. If the water stops coming to the ice maker I recommend returning the new ice maker. You only need to unplug the side of the water control valve leading to the ice make. I also recommend a pre-filter for the incoming water before the water control valve. Makes the water and ice better and keeps trash from damaging the water control valve. Let me know your results or if you need more assistance, Thanks, Sea Breeze
Posted on Jul 14, 2009
  • 363 Answers
SOURCE: water on the ice maker doesn't shut off - drips into the ice pan
Most models of Ice makers have an automatic timer for the amount of water that is allowed to enter the Ice Maker tray. If your timer valve is going bad you need to replace it. First I would reduce the amount of water coming from its source. There should be a tapped valve under your sink, connected to your water line. You have to turn the top of the valve clock wise to reduce the amount of water the is going to the back of your refrigerator. That is where you will find the timer valve. Reducing your water flow should help reduce the volume of water being let into your Ice Maker.
Posted on Jul 16, 2009
  • 415 Answers
SOURCE: The water to the ice maker continues to drip then freezes up.
the loud noise is from the water freezing and hitting the fan blade in the freezer, is the imkr level? have you replace the filter if has one? is it hooked to an R/O water drinking system? if so remove the filter in frig. last thing to do if others questions ok if the shutoff to that water line going to frig is on the bottom of the pipe shut all the way off then turn back on if you have a dispenser and water is really slow to come out this may clear up the low water pressure. If on most units if you do not have appx 35psi it will not allow the valve inside the watervalve to seat and allows water to dribble by
Posted on Sep 03, 2009
Water leaking from ice maker
What is the model number? I believe you have a defective water control valve sticking open or leaking like a dripping faucet.
Appliance 911 Sea Breeze
Nov 03, 2015 | Refrigerators
Pim10bls
Possibly the water control valve is leaking when shut off, and water constantly drips into the ice tray fill tube. When this happens, the fill tube becomes clogged with ice, and the ice tray does not fill. The ice tray will cycle often, because there is no water in the tray, but will remain empty. If this is the case, the water control valve at the bottom rear of the refrigerator will have to be replaced.
Jul 31, 2014 | Polar PIM10BLS Portable Ice Maker
Why is my Uline ice maker filling with water not ice ?
At first I wanted to say it has to fill with water to make ice but I know you mean the ice bin is filling with water. You either have an issue with the water control valve leaking or your timer isn't working properly. Listen for the water to flow and when it seems to shut off look at the tray fill spout and see if it actually stopped dripping. If it continues to drip (not flow normally) then the valve is leaking. If it isn't dripping but the water in the ice tray over flowed, then the issue is either with the timer or the adjustment is incorrect.
Jun 04, 2014 | U-Line ULN Marine Series 12-lb Crescent...
We have the water hooked up at the back of machine. there is a spout for the water to come in and fill the ice tray.but is does not. If we turn the water on it fills up the space under the ice basket. I...
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze blocking the fill tube.. You can take the water line off the valve and watch to see if it drips.
With the fill tube blocked with ice the water can drip down the back wall or drip into the ice bin or just stop up. You can use a hairdryer to thaw the tube out.
Feb 18, 2011 | Vacuums
My franklin chef FIM200 is dripping water from the back, right side. The water fill valve was spraying out above the tray, we managed to get that under control, but, water is dripping right behind that...
Try putting a compression coupling in eliminating the valve. Did that on my machine a few months back, have not had any more leaks. Just other issues with thick ice and won't harvest correctly. Any suggestions?
Nov 24, 2010 | Franklin Industries Franklin Chef FIM200...
Thanks for your response Woodchuck 789- it is greatly appreciated. I tried checking the dual inlet valves as you suggested - switching electrical connectors and checking output, etc. The valves seem...
its hard to ck a valve that drips / and the ice maker may be over filling . if ice cubes are stuck to gether it is over filling . if driping . it may be a bad valve that does not shut off tight. I would replace the valve .. ****
Jan 07, 2010 | Amana 22.6 cu. ft. Side-By-Side...
Our model 532 keeps over filling the ice maker causing a build up on the back and down all of the drawer. We can turn it off and thaw the entire box and the water keeps filling the tray even though the ice...
The fill valve for the ice maker could be stuck partially open and dripping into the ice maker. If this is the case shut off the water line to the ice maker and if the water stops you will need to replace the ice maker fill vavle
Aug 10, 2009 | Sub-Zero Freezers
Water on the ice maker doesn't shut off - drips into the ice pan
Jul 16, 2009 | KitchenAid Superba Architect KSCS25INSS...
Water Leaks from Ice Maker of Sub-Zero 642
Sounds like the water inlet valve to icemaker is leaking - not closing completely after filling the tray. Rare, but possible. Prove it by shutting off icemaker arm or switch. If that is the cause, the drip will continue.
If dripping stops when I/M is off, then it is ice blockage in I/M fill tube and or diverter funnel at end of ice tray. Remove I/M, clean ice from both, and re-assemble.
Replacing that valve (water supply to refrig connects to it in the back) should solve it.
Jun 13, 2009 | Sub-Zero 30.1 cu. ft. Cabinet Depth...
Samsung RB215LASH Logo
102 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Paul
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
