Question about Yamaha Rx-v465/rxv465 Home Theater Receiver
How do i assign audio from optical AV to hdmi4?
    Scholar:
  • 127 Answers
Hi, unfortunately this is not possible on RX-V465. HDMI can have sound only from HDMI. All A/V inputs are paired, except for analog Audio 1-2, to which you can assign any of the analog video AV1-6.
But you can connect the video via HDMI directly to your TV and connect only audio to receiver via optical AV1 or AV4.
Posted on Aug 13, 2010
Is HDMI4 correct or HDMI1?
how many jacks do you have . I would think it will be 1 or 2
Feb 22, 2016 | Dynex Televison & Video
Apple tv to optical audio on avr 1601
You need to assign the optical input to the video input you are using. It's under the 'Input Setup' menu.
Or use HDMI, it will output the audio thru the HDMI connection. Once again assign the input under the Input Setup menu (press the Menu button on remote to access setup menus)
Nov 19, 2011 | Denon AVR-1601 Receiver
Hi, when I plug my TV's optical out into the Nakamichi AV8's optical input, and switch to "DVD/Optical" (after hitting "Digital Input" buttno) ... no sound comes out. I have...
Maybe assign it?
If the digital TV-related audio actually originates elsewhere (Cable Box?) you could skip the TV and use the Cable Box as the audio source. Nothing is gained by flinging an audio or video signal around the room to be handled (but not improved) by any device. I have no video entering my receiver and nothing but bare bones analog audio going to my TV in case I want to just watch the news or something else lo-fi.
Jul 14, 2011 | Nakamichi AV-8 5.1 Channels Receiver
Should I be using a separate optical cable when connecting a Blu ray player with and HDMI ?
hi,
There is no need of connecting optical cable. the only thing you have to do is set the digital input assignment as HDMI (means setting the digital input source HDMI) in your av receiver. Also remember one thing, set the digital output setup of ur blue ray player also as HDMI. then only u will get audio through HDMI
if you need any more assistance fell free to contact me through fixya.
ok
Jan 26, 2011 | Yamaha HTR-5063 Receiver
Just installed my new 32le5300. Cant switch to dvd player. manual won't play on my imac. Can you help?
The manual is available as a PDF here: http://www.lg.com/us/tv-audio-video/televisions/LG-lcd-tv-32LE5300.jsp . Click on Support and then the Televisions Manual on the right. Just above is a link to Adobe Reader if you need the program.
LG doesn't always support Mac systems but that shouldn't change the manual access if you have a working optical drive. If you have Adobe Reader, then the problem might be that the disc won't autoplay. Try manually accessing the contents of the optical drive. (Open the File explorer and then the optical drive.)
Next: is your DVD player a stand-alone device or is it part of the computer? How have you connected the TV and the DVD player? The model number would help. Generally, you need to change the source for the TV to match where the DVD player's cables are going into the TV. There is a button for this on the TV's remote (and on the TV, just left of the power button) - labeled Input. The DVD player should be off when the TV is turned on and then set to this source. (The TV can get confused otherwise.)
The HDMI and HDMI2 ports should work with a PC connection (1920x1080 with the input label set to PC for the TV if you change the label for the HDMI ports). The entire list of inputs should be TV, HDMI1, HDMI2, HDMI3, PC (VGA), AV in 1, Component in 1, AV in 2, Component in 2, HDMI4.
I hope this helps.
Dec 30, 2010 | LG Televison & Video
Which optical inputs should I use for (1) audio output from hi-def cable box (connected to HDTV with component cables) and (2) audio output from DVD (connected to 3805 with component cables?
Hi, the Optical and Coaxial inputs are assignable to whichever input you need them on. Plug the Optical cables from your DVD and HD cable box into any of the OPTICAL INPUTS (1 and 2 is fine, but write down your connections on paper)
You will then need to go into the setup of the AVR on the screen and assign the OPTICAL connections to the correct inputs (Probably TV/CAB and DVD.
Use the SYSTEM SETUP button on the factory remote, and you should see the on-screen menu appear on your TV. Go to INPUT ASSIGNMENT and choose the input for the DVD and assign OPTICAL 1 or 2...
Reply here if you need more help.
Jul 06, 2009 | Denon AVR-3805 Receiver
No audio from my PS3 through the Onkyo 5100 7.1
Have you assigned the audio to the optical cable? I am doing the same thing with awesome results. Simply go into your PS3 main menu under System Settings. You can then go to either audio or video options. I prefer to go the Video Options route, since it will ask if you would like to change the audio as well. In Video Options it should state something about the Video Output and to the right of that you will see you current resolution settings. Select this and set your resolution options. It will then ask you if you would like to assign audio options, and you will need to choose yes. In here it will let you assign what port the audio should be assingned to. Choose the Optical Out option and then click enter. From there you should hear the sound through your Onkyo.
Jan 27, 2009 | Electronics - Others
Open Questions:
See all Yamaha Rx-v465/rxv465 Home Theater Receiver Questions
Yamaha Rx-v465/rxv465 Home Theater Receiver Logo
360 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
