My computer system shuts down - Computers & Internet
    Brigadier General:
  • 10,406 Answers
If you are asking it to do so, then it is good that it obeys.
If it is overheating (because one of the fans inside the desktop has failed) then it is shutting itself down, to prevent heat-related damage.
Do you have a surge-protector (or a UPS [Uninterruptible Power Supply]) between the AC power and your computer?
Surges from the local Electric Company could be affecting your computer.
Posted on Nov 17, 2009
System doesn't get on after shut down
Check the system BIOS. I know that in certain HP systems you can disable the power button so that it doesnt do anything. It's to stop the system being accidently shut down
Jan 26, 2014 | HEWLETT-PACKARD Hewlett Packard HP...
Gateway MT6840 unexpectedly shut down and wouldn't
First - re-seat the hard disk and reboot the computer. If the computer does not boot up then reboot and go into the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty.
Then the hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
Feb 12, 2013 | Computers & Internet
Windows keeps shutting down unexpectedly
Your computer is overheating, it is shutting itself down to prevent damage to the internal components.
Your computer should be serviced by a computer technician. He/she will clean the components and chassis of dust. This will increase airflow over the components, meaning your system will be stable and will not shut down unexpectedly.
Take care!
damnor01
Apr 28, 2012 | Microsoft Computers & Internet
Shut down the system but no shut down restsrt system
1. Click Start > Run and type REGEDIT
2. Click the plus sign next to HKEY_LOCAL_MACHINE
then System
then CurrenControlSet
then Control
then click CrashControl
3. Double-click on AutoReboot on the right side and change the value from 1 to 0.
Close regedit and restart the computer. Now the computer should shut down normally instead of restarting.
Hope this helps. Please rate my response.
Thanks.
Have a good day
Jan 21, 2011 | Intel DG31PR Motherboard
Computer keeps shutting off every five minutes or so
Computer may be shutting od due to following reasons:
Computer Virus
There are higher chances of a computer shutting down due to the interference of a computer virus. The virus gets into the computer and fiddles with crucial sections of the operating system, which may cause the system to shut down automatically. You need to install a good antivirus software and get the computer scanned thoroughly for any malware and viruses. Also see to it that the operating system and all hardware drivers are updated.
Power Supply
The computer power supply unit is an equipment that is installed in the cabinet to provide power to the system for operation. Your computer can shut down, if there is not enough power supplied to it for handling the programs running. If you are using the computer for running intensive software such as PC games, the system would require more power than what is actually available. Another reason can be overheating of the power supply. After the power supply is used for a substantial period of time, there is a possibility of dust getting collected inside it. And this may cause it to overheat, resulting in the shutdown of the desktop computer. If the power supply is at fault, you may need to get a new one installed.
Overheating of the Motherboard and the Processor
As with the case of dust getting collected in the power supply, the computer motherboard and the processor can also collect dust, which may be the reason for their overheating. This may also be one of the reasons why your computer keeps shutting down and restarting. You need to open the computer cabinet and clean the dust off the computer parts. The CPU board and the processor can also overheat because of many applications running. If this is the case, then it is suggested to keep the running of applications as less as possible or increase the size of Random Access Memory (RAM). Bad capacitors on the motherboard is also one of the reasons, why your computer keeps shutting down very often.
The 'Automatically Restart' Setting
If you are using Windows XP operating system, there is a setting that indicates the computer to reboot if it detects an error in the system's operation. In order to check if this is the problem, click on 'Start' and 'Control Panel', then select 'Performance and Maintenance'. Click on 'System', then the 'Advanced' option, and select 'Settings' from the 'Startup and Recovery' section. You will find an 'Automatically restart' option, which you need to uncheck for preventing the system from rebooting. Read more on computer keeps restarting on its own.
These were the possible reasons, why your computer keeps shutting down and rebooting. You also need to check if the power cables are properly connected to the cabinet and to the UPS, as loose connections can also be a reason for system shutdown. The most common cause of the computer getting shut down or restarted is due to overheating of the power supply and other internal computer parts.
Dec 29, 2010 | Mirus Computers & Internet
I am having a problem with shut down the computer.After shut down command it displays windows will shutting down and hangs but will not shut down i need to press the power button to shut down(My computer...
Something is not closing on exit. Try running in safe mode, then shut down. If it shuts down then something is loading and present in the taskbar which isnt closing down.
Dec 19, 2010 | Computers & Internet
I was running the program "windon Defender" on it and walked away. When I returned the computer was off and wasn't turn back on.
The Windows Defender Application is the Antivirus Software which will be pre-installed with the Windows Operating System(Windows Vista, Windows 7).
The Computer will always Shut down after any Windows Updates or any Operating System Updates are downloaded and installed.
If you are connected to the Internet and running Windows Defender, the Computer will automatically download the Updates for the Windows Defender Application.
Once the Updates are downloaded and installed, the Computer will prompt for a shut down.
The count down will be for 10 seconds.
After 10 seconds, the Computer will install the downloaded Updates and shut down.
This might be the reason for the Computer to shut down while using the Windows Defender.
If the Computer still shuts down randomly, the issue might be due to overheating.
All the Processors in Notebooks are designed to shut down automatically, if there is any overheating issues.
The overheating issue mainly occurs due to the malfunction of the Cooling fan.
If the Computer shuts down frequently, the issue might be due to the above factors.
It would be better to get the Unit examined at the Service Center.
Jun 22, 2010 | Acer (56.04145.901) (5604145901) Power...
Computer Shut Down Problem
Is the computer taking forever to shutdown in the blue screen or is it something else. Perhaps try closing the applications running with the system to help the process speed up and actually work without the usage of the power button.
Feb 06, 2010 | Lenovo ThinkPad T400 PC Notebook
My computer won't shut down it just keeps restarting
The most common shut down problem is that the system will reboot rather than shutting down. In most cases, the reboot is triggered because Windows XP is designed to reboot after a critical failure. To stop windows from rebooting in case of a failure, you need to take the following steps:
Right click on My Computer, Select Properties, Click on advance tab, Click on Settings under Startup and Recovery, Uncheck the option Automatically Restart under System failure, Click Ok twice and try to shutdown the pc. If it shows any error code then let me know
Nov 24, 2008 | Toshiba Satellite M65-S809 Notebook
Computer says nt authoritysystem
Hi, it sound to me like you have a heat problem.
Check your heatsink fan on the processor and also clean out all dust from the haetsink and motherboard.
Regards mistyman
Oct 10, 2007 | Intel Motherboard
Computers & Internet Logo
144 people viewed this question
David Payne
David Payne
