Question about Sony KP-57WS500 57" Rear Projection Television
Tv lookks like its in 3d
Tv looks like its in 3d yellow,green,red are the colors
    Master:
  • 450 Answers
Coloers need to be calibrated, or the bulb is going. They're only good for around 2000 hours, then need replaced. You can check manual for recalibrating, probably do it yourself fairly easily.
Posted on Nov 17, 2009
How do i connect a Blu-ray player to my TV
It should connect best to the one with blue,green,red and then the two for sound--red and white---This is component hookup.
once connected you select the input via the remote or menu..
The ones with the yellow, white and red are composite (yellow is video and color and red/white are audio---doubt it will work off blue ray unless similar outputs on that.
Mar 19, 2012 | Toshiba 36A60 36" TV
Showing irregular colors are red green and yellow and doubles
Tv have a problems known as a picture convergence problems,it is dead.Tv have colors R,G,B lines are mis alignments in pictures,have colors shadows pictures or 3D picture look alike?Yes,than the tv convergence board it dead,tv must require replacement on the tv convergence board like 2 STK conconvergence ICS and some or all of it resistors too,to fixed the tv convergence board to solved tv convergence pictures problems.The tvs shops will cost u like $300-$350 for parts and labors.
Jul 25, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
My Hitachi 57F59A projection tv has a yellow color to it. I have ajusted the color and tried to reset and start over but still yellow. What could b wrong?
All projection TV sets have two very common problems. One is convergence ( 3D/Warped video or dead set) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. In some cases the TV will also not show any video. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can get the correct parts, step by step photo instruction guides, and support from www.TvRepairKits.com or click here
May 04, 2011 | Hitachi 57F500 57" Rear Projection...
My picture is almost 3-D like and is red, green and yellow.
The tv have a problems known as a convergence problems,it dead.The tv colors lines R,G,B mis alignment,have colors shadows pictures or 3D pictures look alike.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts on the tv convergence board,must be replaced to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Oct 28, 2010 | Mitsubishi VS-60609 60" Rear Projection...
Blue & yellow stripe on bottom of screen at first now red and green like 3d
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
•Screen looks 3D
•Colors don't line up
•One or more colors can't be adjusted when using the convergence menu.
•Screen is bowed or warped.
•TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems
fcabb43.pngCONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya - CLICK HERE
Jul 08, 2010 | Philips 60PP9202 60" Rear Projection...
It seems that I am watching my TV in 3D.
im joel a simple electroncis tech. try to adjust the settings but it does'nt work the i think 3 color inside ( red,blue,green) is one or two of them is deffective.so the best solution try to go the expert tech nothing else
Apr 12, 2010 | RCA P52926 52" Rear Projection Television
Picture has ''double vision'' with red.
This is a common problem. Its called a convergence failure.
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Screen may look distorted
  • TV shutdown - does not display video
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Feb 20, 2010 | Televison & Video
My Sony Projection TV middle of the screen curves down on top and curves up on bottom. Picture looks dubble like 3D, screen looks like concaved. Left side of the screen color is light green and blue, right...
This is a very common failure on Projection sets. Its called a convergence problem.
You may have one or more of the following symptoms.
Screen looks 3D
No Audio / No Video - Makes Chirping Sounds
Sep 26, 2009 | Sony KP-51WS510 51" Rear Projection...
Color and foucus is not right.
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded overs.
You can find more details and solutions here on Fixya at the following link below. Or click HERE
3d884ac.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 04, 2009 | Toshiba 50H72 50" Rear Projection...
Sony KP-57WS500 57" Rear Projection Television Logo
61 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
