Question about Kitchen Ranges
Getting F1o code - Kitchen Ranges
  • clayton winklepleck Nov 17, 2009
    yes I meant F-10 what t'stat r we talking rwe talking oven control thanks for the help
    yes I apprecirate that solution . when u said bad t'stat I was thinking erc thank u verymuch haundi24
  • 986 Answers
Ok Iam not sure but I think you mean F10? Thats a runaway oven temprature. You have a bad thermostat.
If you ment F1.....You have either a bad ERC (clock) or a bad touch pad.
  1. Disconnect power to stove
  2. Gain access to the back of the clock (electronic range control or ERC).
  3. Unplug the touch pad ribbon connector from the ERC. This will be a flat wire approx. 1 1/2" to 2" wide.
  4. Make sure everything is clear and will not short out when power is turned back on.
  5. Turn power back on to stove.
  6. Watch for the F1 and listen for the beep.
  7. If you get the F1 and beep, replace the ERC.
  8. If after approx. 30 minutes you do NOT get the F1 and hear the beep, replace the touch pad.
    NOTE: Some models incorporate the touch pad and the clock as one part.
Posted on Nov 17, 2009
  • 1 more comment
  • Roger Campbell
    Roger Campbell Nov 17, 2009
    Ok here is the procedure for a oven temp sensor.
    Its in the oven
    Here is a IMG
    Remove power first.
    Due to productions changes and continuous improvements, it may be necessary to use an adaptor wire harness or wire nuts for a compatible connection.
    Remove screws from inside the oven ( some newer models like Frigidaire/Kenmore have the 2 screws on the outside at the back ) and pull towards you the inoperative sensor.
    If the connection on the sensor or the wire harness is not applicable to your model, use two ceramic high temp wire nut connectors to splice the wires together. Strip insulation on each wire approximately 1/2" from the end. On some models, the sensor may be serviced from the front, on others the hole in the oven liner is not large enough for the wire nut/connector to pass through and must be serviced from the rear.
    Important: Make sure the wire nuts/connectors are completely through the insulation and not touching the back of the oven cavity.
    Once the wire nuts/connectors are properly positioned, reinstall the sensor screws removed earlier.
    Any more questions feel free to ask.
  • Roger Campbell
    It just controls the oven temp. Its the most likely cause.
  • Roger Campbell
    Let me rephrase that. It senses oven temp and sends the signal back to the ERC. If the oven temp sensor goes out the oven will call for more heat. thus a runaway temp fault.
Get off demo mode f1o didn't work
HP use F11 key to restore the operating system.
Mar 09, 2014 | Computers & Internet
How to get my ninja saga candy code??
  • 03C20DB76A5B6D588478918574EB963C70
Nov 07, 2012 | Ninja Saga
How to get code
What is your mobile and model ?
Also what type of code does your mobile needs ? Is security code or network unlock code ?
If security code means get it from the mobile service provider otherwise want network unlock code get it here Unlock-free.com , it gives you a best instructions for getting the code for your mobile from the network lock........
Nov 14, 2011 | Cell Phones
Hi i want to unlock and get the MEP code for my blackberry bold 9700 here is my IMEI #: 359564.03.121762.5 thank you
No one can give you free unlock code. because each blackberry have different unlock code. As far as i know unlocking by codes is the simple and safe way.You will need the unique MEP Code for your Blackberry and to get it you can use a website with service for Blackberry unlocking .so you can use a website to Unlock your Blackberry Bold 9700 online instantly - OR local mobile shop .they are mostly using cables to unlock it and the price is higher then on unlocking websites but the result is the same: SIM free Blackberry.
Oct 12, 2011 | RIM BlackBerry Bold 9700 Smartphone
What is my code?
It asks for PUK Code or PIN code means get from service provider ,asks for Security code means you can get the code from service provider,If asks for Network Unlock code means you can get the Unlock code from here
Theunlockspot and unlock it,check code for Mobile Brand ,Model,network and Country it locked now?also you can reset the Phone from security code or password lock code using the master reset code,You can get the Master reset code for Nokia DCT Phones and Alcatel Old Model Phones there itself.
Aug 15, 2011 | Cell Phones
I am getting Error code 0x80043ac9
What Code Error,Security Code Error getting while entering code,or else getting code error while entering the Network Unlock code,?
You can get the Network Unlock code correctly at here
http://www.mobileunlocksolutions.com/blackberry-bold-9000/rs1wp9/ as well as security Unlock code at there ...
Jan 19, 2011 | RIM BlackBerry Bold 9000 Smartphone
Alarm & Stereo not working... Digital odometer constantly reads 'deck' as if the hood is open, but it is not. The alarm does not honk as it used to when battery cables are reconnected. Dome light does...
well u may want to repost after my answer but any way the (deck) light on is the trunk lid is not closed on closed right and it being open will not let the alarm set its self
Dec 19, 2010 | 1998 Chrysler Sebring
Blackberry codes
You can get the MEP code from the mobile carrier or vendor ,
who provide the blackberry device,
this is service is not a free service in market or internet,
Jun 07, 2010 | RIM BlackBerry Storm 9530 Smartphone
Looking 4 samsung j750 unlock codes
hi,
you are in need of of unlock codes right
the fact his you cannot get it forfree..........................
you have to spend some money to get unlock codes youcan get your code according to your specified imei................
you can get it within 1-2hrs
and activate your code quickly....... to get codeyou refer this site
here is the link
Click Here ...................i hopethis site provide you codes quickly and easily
All The Best
May 27, 2009 | Samsung SGH2100SGH600V300 Unlock/Unlocking...
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
