Question about NetGear WGR614 Wireless Router
Cannot access ssid that has excellent strength. Its a Netgear WGR614v7 It stopped working after I added WEP security and a password. when I click on SSID it just says Window cannot access SSID. It's ok with an ethernet cable through router. Would appreciate advice. Bob
  • Anonymous Mar 17, 2014
    I already registered my netgear 4300 n750 with the factory SSID and password...if I change them, do I reregister the new password?
  • NetGear Master
  • 32,281 Answers
To connect to your wireless router, it needs its wireless settings configured and also the wireless card in all the laptops and or computers needs to be configured with the router’s wireless settings. Then the laptops and desktop computers can communicate with your wireless router.
To set-up and secure the wireless router from unauthorized access, follow these steps: -
1. Connect the wireless router to your computer with a LAN cable.
2. Start your browser and enter the router's configuration URL IP address.
3. Enter the router setup, login and password
4. Change the admin password
5. Go to the wireless settings and change the default SSID and turn off SSID broadcast.
6. Setup encryption key the strongest is WPA2 (if not then WPA).
7. For further security measures - turn on MAC address filtering and enter the MAC address of the wireless cards on the computer/s you want to connect to this wireless router.
8. Record the settings you have made and keep it in a safe place and Save the settings.
9. Configure the wireless cards on the computer/s with the SSID and encryption settings of the router.
10. Remove the LAN cable between the router and the computer then the computers should be able to connect to the router wirelessly.
Posted on Nov 17, 2009
What is the code for netgear WGR614v7 to enter to a laptop for wireless wifi?
Connect a LAN cable from the Netgear to the LAN port on your computer, open a browser and enter the Netgear configuration URL -
http://192.168.0.1
The default login = admin
The default PW = password You can now change the default admin password and configure the wireless settings.
Go to the wireless configuration and set up the SSID and WPA or WPA2 encryption to protect your wireless network and Internet from unauthorized access.
Now apply these settings to the wireless card in your laptop/computer.
To secure your wireless network from unauthorized access, please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security b>
Jan 28, 2013 | NetGear WGR614 Wireless Router
How do we find the WEP key for my WGR614v9
Configuring WEP:
  1. Use an ethernet cable to connect a computer to any one of the four LAN ports of the NETGEAR router.
  2. In a web browser, enter the router's IP address - either http://192.168.0.1 or http://192.168.1.1 by default.
  3. When prompted for a Username and Password, enter the default username and password (admin; password) unless you have already changed it. NETGEAR recommends changing the default password to increase the security of your network.
  4. Select Wireless Settings from the Setup menu in the left-hand navigation bar. n101675_image001.jpg
  5. Under Security Options, select WEP (Wired Equivalent Privacy).
  6. From Security Encryption (WEP) > Authentication Type, select Automatic.
  7. From Security Encryption (WEP) > Encryption Strength, select 64-bit or 128-bit. NOTE: You will need to configure your wireless computers with the same setting.
  8. From Security Encryption (WEP) Key, select Key 1 and enter a key.
    • Note: WEP keys are entered in hexadecimal digits, which are any combination of 0-9, A-F.
      • If you selected 64-bit under Security Encryption (WEP) > Encryption Strength, then enter 10 hexadecimal digits for your key.
      • If you selected 128-bit under Security Encryption (WEP) > Encryption Strength, then enter 26 hexadecimal digits for your key.
    • SAVE or KEEP NOTE of these values - they will be required to connect wirelessly to your network.
  9. Click Apply to save the settings.
Feb 21, 2011 | NetGear WGR614 Wireless Router
How do i hook it up
Netgear WGR614 54Mbps Wireless Router
  1. Begin setup of your Netgear Wireless Router by first reading the instructions in the included manual, and following their guidelines for plugging in and initializing the access point. The first few steps in this guide should coincide with the information found in the manual, however we will follow up with important information on how to secure your wireless access point.
  2. After powering up the router, use an ethernet cable to connect your computer to one of the ports on it marked 1 through 4. Next open a web browser window on the connected computer and type http://192.168.1.1 into the address bar and press enter. This will take you to the Netgear Smart Wizard welcome page, click OK to begin the configuration. The router will attempt to detect the type of connection you have and the next message you receive should be Dynamic IP (DHCP) Detected, click Next once you see this.
  3. Next you will enable the wireless capability of your router. In the dropdown box for the region where you are located select United States from the list. On this screen you should also change the Wireless Network Name (SSID) from its default value to something unique so that your Base Station will not be confused with another. Click Next.
  4. You should now see a message confirming that your connection is working and wireless is enabled. However, your are not secured yet. Read the notes and click Done. Then direct your browser to http://www.routerlogin.net to continue the configuration. A window will pop up prompting you for your login and password, enter admin for the username and password for the password, then click OK.
    Accessing the router settings through a web browser.
  5. Once you have logged in you will see the main configuration page (shown above). Now click on the Wireless Settings at the left of the page. In order to password protect your wireless network select the WEP (Wired Equivalent Privacy) option under the Security Options and then under the Security Encryption (WEP) section that appears, select 128 bit next to Encryption Strength. Choose a password between 6 and 8 characters and type it into the Passphrase box under the Security Encryption (WEP) Key heading. Then click Generate. Finally click Apply. You may also select WPA encryption, however not all network cards support this, so check your documentation first.
  6. Next look for the Advanced section heading on the left side of the page and click on this Wireless Settings section. Disable the SSID broadcast option by unchecking the second box in this section and then click on the Setup Access List button.
  7. On this page (seen below) check the box to Turn Access Control On and click on the Apply button to save this setting.
  8. Now click on the Add button, this will display a Wireless Card Entry heading. This is where you will choose a name and enter a MAC Address, also known as Physical Address, for each computer that you will be using to connect to your wireless network. If you don't know how to get this information follow the steps here. Once you have finished, click the Apply button.
    Creating an Access Control List will prevent unauthorized computers from using your connection.
  9. Finally click on the Set Password link on the left of the page under the Maintenance heading. Change the default password for accessing your wireless router setup pages by first typing the old one, password, into the appropriate field and then entering a new one into the New Password field and confirming it. This should be a different password than the one you setup for WEP encryption, but should also be atleast 6 to 8 characters in length. Click the Apply button.
  10. Your Netgear Wireless Router is now secure.
Jan 07, 2011 | NetGear WGR614 Wireless Router
Where i can download set up cd for my wireless router becouse i lost my
Follow these steps:
Oct 30, 2010 | NetGear WGR614 Wireless Router
Dont know how to set it up
Oct 05, 2010 | NetGear WGR614 Wireless Router
How do I rename the netgear connection and make it security enabled? I have WG602v2 router
Please follow steps to fix your issue
1. Connect the computer to 1ST Accesspoint using a Ethernet cable.
2. Open a web browser (Internet Explorer, Mozilla Firefox or Safari).
3. Access the Accesspoint (usually http://192.168.0.227).
4. Login to the Accesspoint (Username = admin Password = Password unless you have changed it).
5. click on Wireless Settings in the left hand side menu under Setup.
6. Change the network name SSID to (any name) and click apply.
7. Click on Security Settings in the left hand side menu under Setup and select Security Type as WEP.
8. Select Authentication Type as Open System.
9. Select Encryption Strength as 64 bits.
10. Under Security Encryption (WEP) Key in the Key 1 box enter the same 10 digit key that was used on the router before.
11. Click Apply.
Hope this will help
Thanks for using Fixya
Jun 12, 2010 | Computers & Internet
Please follow steps to make your network secure and change network name.
11. Click Apply.
Hope this will resolved your issue
Jun 12, 2010 | NetGear WG602 54Mbps Wireless G Access...
Netgear WGR614 wireless problems.
  6. Next look for the Advanced section heading on the left side of the page and click on this Wireless Settings section. Enable the SSID broadcast option by checking the second box in this section and then click on the Setup Access List button.
Also check to make sure you are broadcasting your router, in the settings (Step 6). This will not hide your router from devices that you want to connect, such as mobiles and consoles, which is what you want to do.
Jan 03, 2010 | NetGear WGR614 Wireless Router
When I install it says Card unplugged when it is firmly plugged in
i have netgear wgr614v7 and a broadband connection working without security code, when i tried to configure to put a wep i reset the netgear and now it is not working . what should i do to have a connection via netgear and with security password
Dec 04, 2009 | NetGear WG511T 108 Mbps 802.11b/g Wireless...
I dunno ow to secure my connection with my edimax router
You can read more about WEP and WPA in the following links:
This article explains how to configure WEP/WPA-PSK/Access list on NETGEAR Wireless router (also applicable to access points).
Note:
  • You can configure WEP or WPA. But you cannot enable both at the same time.
  • You can configure Access list and also enable WEP or WPA for additional security.
  • After you enable wireless security features on the router (or access point), you must configure your wireless clients (wireless computers) with matching settings. Your wireless clients will not be able to connect unless you configure matching settings.
  • Its recommended you enable these wireless security settings from a computer wired to the router (or access point).
Configuring WEP:
  1. Connect a computer to any one of the four LAN ports of the NETGEAR router.
  2. Open an Internet explorer and type the router IP address which would be either http://192.168.0.1 or http://192.168.1.1 (by default, refer to your product documentation ti determine the default IP address.) in the address bar and press Enter.
    The Login window will be prompting for a Username and Password. The default Username is admin and the default Password is password
  4. Under Security Options, Select WEP (Wired Equivalent Privacy)
  5. Select Authentication type as Automatic and Encryption Strength as 64-bit (or 128-bit) - You must later configure your wireless computers with the same setting.
  6. Select Key 1 and enter any 10 hexadecimal digits - any combination of 0-9, A-F (26 digits if you selected 128-bit as the encryption strength) and Apply the settings. Please note down these values - You must later configure your wireless computers with the same setting.
Apr 27, 2009 | NetGear WGT624 Wireless Router
NetGear WGR614 Wireless Router Logo
183 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
