Question about Vostok Europe Automatic K 3 Submarine Stainless Steel 2432/0325032 Watch for Men
I have a vostok automatic watch that the stem is loose and dose not wind the watch, i can set the time though
idkia_33
  • 70 Answers
SOURCE: Stem pulled out of the watch when trying to set the time
radioshack, walmart, or a jewelry store
Posted on Jan 22, 2008
  • 6 Answers
SOURCE: Prague skeleton EG-8901 loose penulum
did you find a solution for this? I had the same problem. Good looking watch jeweler couldn't fix.
Posted on Nov 05, 2008
escapement
  • 2334 Answers
SOURCE: How do I close the stem on a zodiac watch?
Your watch do not have screw down crown feature. You can only pull out or push in that crown.
Check instructions for yourself from the official Zodiac document here:
https://www.zodiacwatches.com/images/pdf/zodiac_watchinstructions.pdf
Rate me, please.
Posted on Mar 15, 2009
  • 2501 Answers
SOURCE: the winding stem came out when i was trying to set time formula 1
I would advise you to take it to an authorised dealer (see the Tag Heuer web site (www.tagheuer.com) ) and let them sort out why the stem came out. I feel sure that this shouldn't happen and it is likely that a repair is needed.
(It may be that something that restricts the movement of the stem has become detached. If this is so, then something may be moving about inside).
Posted on Feb 11, 2010
  • 5 Answers
SOURCE: Fault with a Vostok Europe Red Square watch
The crown holds in place by one little screw inside of the watch. It is a very easy fix - you just need too open the watch and tighten the screw.
Or even better solution - send it back for repair. All Vostok-Europe watches are covered by 24 months warranty.
W-Precision
Posted on Mar 19, 2010
How to set date and time of the Armani watch, AX1071
Pull the right post out. It may first have to be unscrewed to unlock it. Pull it out one click to set the date, two clicks to set the time. I recommend setting the time first and go all the way past 12 to see if you are on AM or PM (the date will advance or won't). Set the time correctly, then push the stem in one click and set the date. Push the stem in all the way and then turn it to wind. You can't over wind an automatic watch but always use gentle pressure to avoid damage.
Apr 11, 2014 | Rolex Datejust SS
Tip
HOW TO START YOUR AUTOMATIC WATCH
mcdevito75 here,The Automatic feature in your WATCH consists of a counter-weight attached to the MAIN SPRING by a gear that allows a SLOW but steady wind of your watch with the motion of your WRIST, ARM. Once, only in HIGH END watches, today almost all watch manufacturers have this feature in some of their models. Everyone who owns an AUTOMATIC watch knows, you can START your AUTOMATIC watch by WINDING THE STEM and you can continue to wind the stem with no end. This will at least START your AUTOMATIC watch and, this is true to some extent BUT, does this apply to my watch you ask?, Here"s how to tell if your AUTOMATIC watch will START with a few winds of the stem or not. ------- Very Simply, Hold your AUTOMATIC watch to your ear and wind the stem, if you hear a sound as though something is DRAGGING or the stem feels slightly stiff one way you wind the stem and you hear a clicking sound when you wind in the other direction, then you have the TYPE of AUTOMATIC watch that will start with a few winds of the stem, approx, 20 turns or winds. If on the other hand you hear nothing when you wind the stem and the stem feels very loose when turnning then you have the TYPE of AUTOMATIC watch that winds only with the motion of your wrist / arm, to start this type of AUTOMATIC watch, simply hold the watch in your hand and rock your watch back and forth, say from the 12 O"clock to the 6 O"clock, and or, Hold your watch securely in your hand a make circular motions with your hand, any movement to get your watches counter-balance to turn and thus wind your watch. Approx. 1 minute of this extra motion will start your AUTOMATIC watch, then simply wear your watch and your wrists / arm motion will keep it wound.
on Jul 06, 2010 | Watches
How to set day on non digital george watch
I'm not familiar with the George watch but analog (non-digital) watches typically have a stem with which you set the time and the day. On most watches the stem has two clicks when you pull it out (gently). The first clich should set the day by rotating the stem counter-clockwise while the second click sets the time. On wind-up watches this stem also winds the watch when not pulled out.
May 01, 2011 | Watches
How do I wind up my tag carrera automatic using the crown??
Wow, how wrong yall are.
There are three positions for the Carrera's push-down crown. The inner position is used for normal wear and winding. To wind the crown manually, simply rotate it clockwise.
Changing the date on the Carrera is done from the middle crown position. Turn the crown clockwise to advance the date, one day at a time. Push the crown back to the inner position when finished.
The outer crown position is used for setting the time. You can turn the crown in this position either clockwise or counter-clockwise. Adjust the time forward or backwards. Setting the time backwards will not damage the watch. When the time is correct, press the crown all the way into the inner position.
Feb 24, 2011 | Tag Heuer Automatic Chronograph Series...
Emporio armani 4211
mcdevito75 here, There are 2 ways to wind your Armani Emporio watch, I'm figureing it"s an automatic watch, on some automatics you can start an initial ticking by winding the stem in any direction, if when you wind the stem you feel any resistance then this is the type of automatic watch you Start with about 20--30 winds of the watch. If on the other hand when winding the stem feels very loose and free, no resistance at all, then this is the type of automatic that relize on pure wrist and arm motion to start ticking, simply hold the watch in your hand and make small circle motions, or rocking motion, you should detect something moveing inside the watch, this is the winding counter balncer it's normal, rock or circle the watch for approx. 30 seconds to get it started. In both cases, after the watch starts, the motion of your wrist / arm keeps it wound as you wear it.
Jul 10, 2010 | Giorgio Armani Emporio Armani watches...
WILL RUN A SHORT TIME THEN STOP
mcdevito75 here, I would imagine your Rolex is an automatic, not all Rolexes are. After 2 days not running at all your Rolex needs a very good start not just putting it on and that"s it. Sorry to say!, I would ask you to do this, With your watch close to your ear I would like you to wind the watch, listen closely, if you haer a clicking or a drag sound you know you have to give about 20 winds to your watch before you put it on, after the 20 winds the automatic takes over. If the stem just spins and no sound, Click or drag, then your rolex is fully automatic, after you put it on you"ll have to ttwist your wrist back and forth to get the automatic moveing to wind your watch somewhat. Twist your wrist back and forth maybe 20--30 times, this way your watch has an initial wind and as you wear it the winding continues with the motion of your wrist, after it"s wound pretty good if it stops and goes, have the watch serviced.
Jul 01, 2010 | Rolex Day-Date President 118238 Wristwatch
Unable to reset brietling colt, even after ajusting stem to 1st and 2nd postions.
mcdevito75 here, Let"s hope your description of the problem with your watch is wrong. Try this sequence, First, wind your watch, the automatic continues to wind your watch when you where it but to get it started, wind it 20--30 times. 2nd, your crown locks down, turn the stem Clockwise to un-lock it (the stem) now pull the stem all the way out then back in 1/2 way to set date. Set DATE to DATE before the real date turn crown counterclockwise. Now pull out crown all the way and turn clockwise to set the DATE and time (real Date) push the crown back in and turn counterclockwise to lock the crown. If this doesn"t work, look for a small watch repair shop in your area for this adjustment.
Jun 28, 2010 | Breitling Aeromarine Colt Ocean A64350...
What can I do if my clock is over wound?
mcdevito75 here, The mainspring can jam iof winding is forced to it"s limit. I personally have my technique but I would have to have the watch or clock here with me. You can try too pull out the stem and move the hands as though setting the time, at times this action can get the mechanism going again, You can also try tapping on the stem, as though you were trying to hammer it dowm, make sure stem is fully seated to wind, use a knife handle to tap on top of the stem. Other than that you can visit the repair service directory right here at FixYa, bottom of the page click on repair service directory then watches.
Jun 26, 2010 | Watches
Vostok N1 watch
In the 2nd position of the stem rotate the hands between 8 and 12 and the date will change.
Sep 26, 2008 | Vostok Europe "Rocket N 1" Black Dial with...
Vostok Europe Automatic K 3 Submarine Stainless Steel 2432/0325032 Watch for Men Logo
56 people viewed this question
Top Vostok Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Vostok Watch Expert? Answer questions, earn points and help others
