Laptop has screen light up but no picture
My laptop has no picture but the back light does show. What would cause this??
  • 1 more comment
  • hollyavila Jan 10, 2008
    Ok in safe mode it doesnt go on is the inverter the same thing as the video card?
  • pupscrubber May 23, 2008
    I changed my graphics setting and lost all picture how do i get it back
  • jredman941 Mar 26, 2009
    I have a aopen 1557g , I get back light but no picture, if I plug in a crt, it works fine on it but nothing but back light on the lcd.
    Genius:
  • 1,601 Answers
The video card would cause this. To check it restart your laptop and press F8, this will take you to safe mode. If there is still no picture, then it is bad.
If it works then you need a video card driver re-install.
Posted on Jan 10, 2008
  • Thomas Christopher
    Thomas Christopher Jan 10, 2008
    hollyavila,
    No, the inverter changes dc to ac to operate the backlight. the video card is another component and may be an add-on card or built into the motherboard.
Laptop comes on but can't see screen
Hook a spare monitor to the video output usually on the back, if picture okay! the problem is the laptop screen caused by a inverter board, "located just under the LCD display, or the backlight behind the LCD screen. But if both show the same symptom it is the video graphics card that is defective normally built into the motherboard.
Apr 07, 2012 | Dell Inspiron E1405 Notebook
My laptop is not showing anything on the screen
Hook a spare monitor to the video output, usually on the back. If picture okay! it is a LCD issue in the laptop. But if symptoms are the same it indicates a motherboard issue due to the video graphics card. But just to be sure, sub the ram out one at a time, "often causes similiar problems. Next remove hard drive and reset it back in place, sometimes restarts
Mar 17, 2012 | Dell Studio 1558 Notebook
Dropped laptop and i get a blank screen.
I assume the rest of the laptop is working, hook a spare monitor to the video output on the back of the laptop, if okay! the laptop screen is the problem, causes! bad inverter board, the back light behind the screen has failed, or the video cable from the motherboard to the display has come loose. If both screens show the same problem, it is the video graphics card that is part of the motherboard. If you can provide additional information, that will help narrow the problem down.
Feb 09, 2011 | Toshiba Computers & Internet
I have an old toshiba satellite 1400/2400 and the lcd screen first happened to show black stripes and the picture was shaking, and now the screen is fully black. Is there a way to fix it?
If the laptop appears to boot up and the hard disk LED flashes, then the problem could be a back light fault. This fault could be caused by a faulty inverter or a faulty CCFL lamp. Please clcik on this link and follow my instructions to determine the fault and fix :-
http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Nov 23, 2010 | Toshiba LCD Display for SATELLITE...
The screen on my Advent 7211 shows a picture but is very dull... what could cause this ..?
This can be cause by the Back light in the LCD panel. This type of performance means that it is defective or showing signs of wear.
Once it has failed you will need to repair the Back light or replace the laptop
Mar 29, 2010 | Computers & Internet
My hp wont turn on..the power light is on but its like my laptop is frozen or somethng
· First troubleshooting - When you turn the laptop on, are you able to see the splash screen? This would be the computer manufacturer's screen display that usually shows a picture but may also be text and usually appears right before the Windows logo screen. If the answer is yes, then more than likely, the operating system is corrupt. This can be caused by several things including viruses, power surges or hardware failure. If your computer hits the windows screen and reboots back into a loop, this is also signs of Windows being corrupt.
Solution - Take the hard drive out of the laptop and slave it to another working desktop computer to retrieve your data. You may need a special cable for this because the laptop hard drive is smaller than the cable in a desktop. This process can be done, taking precaution that both computers are off while slaving the hard drive. After you attach the hard drive, turn the desktop on, it will read it like another drive and you will be able to pull all of your information from it. You only want to grab the user files, not other data and run a scan to rid of viruses. Then attach the hard drive back on and reformat it.
· Second troubleshooting - If you hear the operating system chime but do not see a picture and all the lights are on, then this would indicate that the back light on the screen is out. You can test this simply by hooking the laptop up to a monitor and see if you get a picture. If the computer screen shows on the monitor, then your back-light is out. If it doesn't show up then your video graphics card is out.
Solution - If the back light is out, it is easier to order a new screen (new or used) from eBay and just switch out (simple process and you can find a replacement for under 50 dollars on eBay). If it is the video graphics card, then you can also purchase one from eBay and switch out (a little tougher because you have to take the top of the laptop off). You can get assistance with this from the manufacturers website (service manual) and pull specs for free.
· Third troubleshooting - To test the battery, take the battery out of the laptop and turn on with just the adaptor. If it boots, then the battery will need to be replaced. There is no way of testing the power adaptor but 85% of the time, this is the problem. Even if lights come on, the adaptor sometimes gets so overheated that it silently goes out but gives just enough power to make the lights come on. The power adaptor can be found on eBay for under 20 dollars and is cheap enough to replace (first) to make sure that is not the problem. The battery can also be found on eBay for under 60 dollars.
· Fourth troubleshooting - If you do not hear any beeps and the above solutions did not work. Then your motherboard has failed. This can be caused by surges or dust. You can purchase a replacement from eBay for a fraction of the cost and replace (this is tough and I am not sure if they have specs for this). You can do it yourself, just be sure and put everything back together as it was.
Jan 30, 2010 | HP Pavilion dv2000t 14.1" Notebook Laptop...
No screen display
Dec 29, 2009 | Acer Computer AOA150 Notebook
Screen went black during start up.
Dec 21, 2009 | Sony VAIO VGN-FS640W Notebook
Computers & Internet Logo
556 people viewed this question
Alun Cox
David Payne
David Payne
