Question about Zenith Z50PX2D 50 in. Plasma HDTV
I need somthing called an A Board ever heard of it and about how much will that run me?
  • 11,361 Answers
Clicking noise in front end of car when going over bumps
Probably the front struts your sway bar links can cause the same noise if they are failing but you should have heard or felt somthing while turning regardless of bumps if the sway bar links were bad. Like the other people said start with the struts.
May 28, 2012 | Cars & Trucks
My 1150 rs fell over onto it's right side now it will not crank?
Probably knocked somthing loose check all conectors battery and ground fuses check every thing
Dec 28, 2011 | 2004 BMW R 1150 RS
Stopped running - no cooling
most common correction for this is the pc control board . sometimes called the main board . loccated on the back of freezer wall ( on the back out side ,) . there is a cover remove it and it may even smell burnt or often sounds of clicking . can be heard . board is arount 180 .00 plus service . if needed .. hope this helps mm ..
Oct 21, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
My whirlpool duet washer displays an "F 74" error code. We had a power outage, the washer is plugged into a surge protector. I called whirlpool last night - they had me unplug for around 10 minutes, plug...
F74 is not a valid fault code. If it was F14, then it was bad eeprom value (on timer board).
Try tripping circuit breaker or unplugging the power cord. Connect power back and follow reset procedure again, that will reset NVRam.
Ensure that there is no water inside the machine. If there is water, while machine is disconnected, empty water.
If that does not work, the control board may be defective.
Oct 09, 2009 | Washing Machines
Unit not running, no lights on pannel but lights work inside.
Could be a control board issue, a broken wire somewhere, maybe the plug came off of the board. Try to unplug the refrig and plug it back in....A lot of times that will reset the board
Sep 13, 2009 | Maytag MFI2568AES Stainless Steel Bottom...
RCA D52w26
Your CRT leaked on the board. You will need to replace the seal as well as the board which got leaked on. Can you post a picture of the board and I will post the board number as well as post a link where you can get another boards at.
Apr 14, 2008 | RCA P52926 52" Rear Projection Television
My LG Plasma TV RU42PX10C
Hi all..i had the same problem with my 42 inch LG
rz42px11. its a faulty zsus board(Z sustain part no 6871QZH033A) the pop
sound was the fuse on the board blowing.not that hard to replace but be careful with the connector ribbons! got my replacement from
https://www.chsinteractive.co.uk/ £150....expensive,but probably cheaper than
calling someone out to fix it.
P.S i tried just to replace the fuse on the board T2AH 250v but it blew,i think the fact the fuse blows means the board is faulty..but you could try.
hope this helps someone.
Good Luck
Dec 21, 2007 | LG RU-42PX11 42 in. EDTV-Ready Plasma...
Zenith R56W36 television
sounds like the flyback transformer is bad would need to change the supply module 6871VPM997D approx $175.00 or replacement of flyback T403 and part number 6174Z-6400B runs 49.27 but would require soldnering skills
Nov 20, 2007 | Zenith R56W36 56" Rear Projection...
Somthing burning
I have never heard of this company. When i run across a thing such as this , I talk to the customer and see if they have the owners manual as therte has be be a service contact inside of the manual. Good Luck
Jul 20, 2006 | TechView P4204TW Television
Zenith Z50PX2D 50 in. Plasma HDTV Logo
109 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
