Question about Sharper Image Ionic Breeze 3.0 Air Purifier
My Ionic Breeze 3.0 makes a clicking noise when it's on.
I have had my Ionic Breeze 3.0 for awhile now. Recently, it has started making a clicking noise when turned on (no matter the setting). I have cleaned it, and this noise persists. What's going on?
  • 45 Answers
SOURCE: my ionic breeze has quit
Have you tried unplugging it, cleaning it (filters/fins or whatever it has), and maybe checked online to see if there is a way or whatnot to do a type of "reset" on it? I had one about 6 months ago that it happened to and I ended up sending it in for warranty-type service. Needless to say I have a different one now that has not given me the first issue.
Good luck with it. I say contact the company and express your concerns, as they might try to make it right for you.
Posted on Aug 20, 2008
Bubbabear64
  • 2794 Answers
SOURCE: Professional Series Ionic Breeze Tabletop
There isn't one. The reason why Sharper Image went out of business is because the Ionic Breeze was proven to be ineffective product and harmful to use in some cases based on Consumer Reports data as well as data from the EPA. They sued Consumer Reports, lost the case, and had to pay all the legal bills.
The Consumer Products Safety Commission is going to making decision on all ionizers by the end of the year. It's quite possible that no one will be selling them anymore.
There is thread I left in the Ionic Breeze section about the EPA data on ionizers and the harmful effects of using them as well as a link about what happen to Sharper Image.
This product should have been regulated a long time ago. Orek and few others are going to be pulling the plug on them real soon.
Posted on Aug 27, 2008
SOURCE: Ionic Breeze Quatra Hissing Noise
While the device is turned off and the filter is out, tip the unit itself upside down and back. Do this several times, there is a slider type cleaner inside that moves as you turn the unit. Be sure to do this every time you clean your filter and you will never hear a peep out of the thing.
Posted on Oct 15, 2009
SOURCE: M ionic Breeze Just quit working. What could be
throw it away!
Posted on Dec 20, 2009
SOURCE: I have 2 ionic breeze air purifiers sharper image.(germical )
I have the same problem as gerardperez7. One of my germicidal light quadras won't turn the light on and doesn't appear to be cleaning the air at all. I even put a new light bulb in it and it doesn't fix the problem.
Posted on Dec 22, 2009
Ionic breeze s1837 making sizzling noise
Generally, they are supposed to as that is the ionizer adding positive ions to the room. you may however read this and consider binning it :>)
http://www.airpurifierguide.org/faq/what-happened-to-ionic-breeze
More information here
ionic breeze s1837 Google Search
Apr 08, 2017 | Air Purifiers
Ionic breeze is arcing after it was cleaned. Let
sharper image has a class action lawsuit against them for the ionic breeze you should look into it
Dec 03, 2009 | Sharper Image Ionic Breeze GP SI730 Air...
I own an Ionic Breeze Quadra unit. It has been working fine and I really like it because it removes bad odors from the house. Mine has just started making a hissing noise. Any suggestions? Thanks
hi,
Sparking, popping, hissing or crackling sounds coming from your Ionic Breeze air cleaner are all signals that it's time to clean your machine. Once you've cleaned the collection grids inside the Quadra, the disruptive sounds will disappear
how to clean
Turn off and unplug your Ionic Breeze Quadra.Grasp the horizontal handle on top of the air cleaning grids--this is in the very center top of your Ionic Breeze Quadra--and pull the grids straight up out of the casingWipe the metal grids down, inside and out along the entire length, with a clean damp cloth. You may need to use more than one cloth if the grids are very dirty.Go back over the grids with a clean dry cloth to remove any water and remaining dirtPut the grids aside on a clean, dry surface and grasp the body of the main Ionic Breeze casing unit in both hands.Flip the casing unit upside down, then right side up, five or six times. You should hear a small bead sliding back and forth as you do this. The bead is cleaning interior elements concealed in the casing; if you don't hear it, your unit may be in need of repair.Place the casing unit back on its base, orient the grids so that the handle slopes in the same direction as the top of the air purifier, then carefully slide them back down into the machine.
thank you for using fixya,rate my answer
vijay
Oct 01, 2009 | Sharper Image Air Purifiers
Ionic Breeze GP S1830 just seems bead, no lights
these things are junk. you could also be doing more harm than good to yourself and the indoor air quality in your home with the amount of ozone these appliances omit into the air. throw it away
Sep 11, 2009 | Sharper Image Hybrid GP (SI724) Air...
Aug 13, 2009 | Sharper Image Ionic Breeze 3.0 Air...
Owner's manual for Ionic Breeze GP
does anyone have (I hope) a free manual for an ionic breeze quadra? I have had this fo awhile but lost the manual
Nov 08, 2008 | Sharper Image Professional Plus Ionic...
Making sizzling noise
Unfortunately Sharper Image has discontinued support on the product line.  There was a recall going on with the product but since the company is chapter 11 right now, I don't think it is being honored right now.
What happened was Consumer Reports ran a test on ionizers, Sharper Image received a bad score and filed a lawsuit.  They lost the suit and had to pay all legal bills.
EPA has reported that using ionizers in a house or business may be harmful to your health.  You can read an article about it on their website.
The Consumer Products Safety Commission is going to release a final report on all ionizers by the end of the year.  Their decision may discontinue all sales of any ionizers in the United States.  This industry should have been regulated years ago just by the EPA data alone and for some reason it has been ignored.
Sep 10, 2008 | Sharper Image Professional Plus Ionic...
The orange tape on the bottom of the ionization bars
There being two strips of orangey tape at the bottom of the rods wipe clean the two thin wires stretching the length of the ionic breeze each time you remove the filter elements to clean the filter. Seems like these wires may be emitting the audible high pitched noise if dirty.
Frank
Jul 12, 2008 | Sharper Image Ionic Breeze 3.0 Air...
Ionic breeze is arcing inside unit
I have a sharper image ionic breeze hybrid gp that ran fine for years unitl it recently started sparking / arcing at the base of the grid blades and always in the same spot. I cleaned it several times but the sparking always came back and the unit went into either "drying grid" or "attention required" mode. The solution I found was to stand the removable grid in 2 inches of Pine-Sol cleaner 50/50 diluted with water for 24 hours then brush again with the cleaning brush and hot water. Presto! No more sparking.
Oct 16, 2007 | Sharper Image Ionic Breeze GP SI730 Air...
Sharper Image Ionic Breeze 3.0 Air Purifier Logo
53 people viewed this question
Top Sharper Image Air Purifiers Experts
Daniel Dollive
Daniel Dollive
Jay Finke
Jay Finke
Are you a Sharper Image Air Purifier Expert? Answer questions, earn points and help others
