Question about Refrigerators
Ice maker does not make ice the ice maker will make one tray of ice and then not make any more. this on an admiral side by side model # HMG62164
  • 725 Answers
This is probably your water vlave that has gone out. How old is your refrigerator? Normally the valves can go out after about 2 - 4 years depending on how your water is in your area and if the water is turned off in your city very often.
You may contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service from 7 Am until 9 PM CST with brand and model number and we will get the correct part as well part removal/installation instructions out to you asap.
We hope to be able to work with you and get this working properly again soon.
Thanks, Ella
Posted on Nov 17, 2009
Ice maker leaking after filling
Most likely the=> 67005154 Dual Waater Control Valve
found on the rear of your refrigerator and down near the floor is becoming worn out and not closing all the way. Are the ice cubes also beginning to stick together? I need you to watch this problem to see if it becomes worse and gets stuck open allowing a lot of water into ice maker. The ice maker determines how much water flows to ice maker about 7 seconds time but if mechanically defective it will not close all the way even when off. I will stick with a solution but will meed you to respond, Thank You, Sea Breeze
Dec 10, 2012 | Admiral 26 cu. ft. Side-By-Side...
Ice maker stoped
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
yy
Sep 25, 2009 | Admiral 26 cu. ft. Side-By-Side...
The Ice Maker is not making ice.
In the freezer compartment I would take the back panel off and thaw the coils with a hair dryer as well as the ice maker. I would also check the ice maker for damage to the gear section as this would result in a timing issue.
Jul 23, 2009 | Admiral 26 cu. ft. Side-By-Side...
Admiral side by side refrigerator ,model sal2027gbb
icemaker water valve is bad check to see if you can tell if the unit is turning
Apr 16, 2009 | Admiral 26 cu. ft. Side-By-Side...
ICE MAKER
Sounds like you are not getting enough water into the ice maker tray. When the ice ejector removes the ice from the tray, it may be causing the ice to splinter which is the crushing you describe. The problems could be:
* The water inlet valve
* The ice maker water inlet is partially frozen in the freezer section
* There is a problem with the water line (kinked or partially obstructed)
* The timing mechanism for the inlet water valve isn't working correctly
Check #2 from the above list first
Mar 15, 2009 | Admiral 26 cu. ft. Side-By-Side...
Ice Maker
replace the water inlet valve
until you can turn off the water to the ice maker to keep from having to clean up again
May 22, 2008 | Admiral 26 cu. ft. Side-By-Side...
Admiral Ice maker water filter, which one?
I have an admiral HMG19149 refrgerator with an ice maker. my problem is that the ice tast horable and cant be used. I looked for a filter to change but can't find it. Please help
Jan 14, 2008 | Admiral 26 cu. ft. Side-By-Side...
Ice make won't drop the ice
The ice mould has a very low wattage element built into it to help release the ice cubes. This heater may be faulty. Most ice-makers have no serviceable parts in them. You may have to replace the complete ice maker.
Oct 24, 2007 | Admiral 26 cu. ft. Side-By-Side...
Refrigerators Logo
56 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
