Question about Refrigerators
Water ffreezing on bottom of freezer basket , also ice maker does not work
  • 90 Answers
The fill tube for Icemaker may have came off. if this is ok . maybe defrost drain tube may be froze need model number
Posted on Nov 17, 2009
Where does the water go in the model IM90 emerson ice maker
open the lid and remove the plastic ice basket. Look on the walls under the ice basket and you should see a "fill line".. Water should be poured into that area (below where the basket goes) no higher than the max fill line.
Oct 21, 2014 | Emerson IM90 Portable Ice Maker
Why is my ice maker causing blocks of ice at the bottom of ice bucket ,also on freezer baskets ?
Sounds like there is a leak in the water fill line to the ice maker or the timer in the ice maker is defective causing the fill cycle to overflow the cube tray and then freeze into blocks in the freezer.
Oct 08, 2014 | Kenmore Refrigerators
Have water dripping with no ice maker in freezer
Pull the upper basket out, rearrange food so it does not exceed the top of the basket, then trigger the light switch to make sure there is power going to the freezer compartment.
Sep 29, 2014 | Amana 21.9 cu. ft. Bottom Freezer...
Ice maker has water but no ice
HI.TERRY.freezer has to work at its optimum.for the ice maker to work. i would try to defrost the freezer completely first and try.good luck.Ali
Jun 28, 2012 | Samsung Refrigerator Ice Maker -...
Ice maker not working
my icemaker has a wire overfill sensor which shuts off the icemaker if there is too much ice in the basket. If this wire gets pushed up it will stop making ice until level lowers OR manually lowered.
Feb 08, 2012 | Electrolux EW28BS71IS (278 cu ft) Bottom...
I hear the ffreeze running but the items are melting
The clicking noise is most likely from the compressor start relay.
It is going bad and must be replaced.
Jul 11, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Admiral HMG 62163 water leaking internally & freezing in lower basket
good attempt, its actually a clogged drain thats backing up and your drain water is not able to leave refrig so it falls to bottom of freezer floor and eventually out the door. romve the items from the freezer and take the lower back wall off form inside, directly under the evaporator under all that ice there is a drain hole, youll need to clear that hole of iec( pouring boiling water down until you get a free flow of water then you can reassemble uint problem solved
Oct 25, 2008 | Admiral 26 cu. ft. Side-By-Side...
Ice/water flows in the freezer compartment RS2534sw
The drain for the water to get away when defrosting is frozen shut...
Checkout this tip to help you..
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Jun 23, 2008 | Samsung RS2534 Side by Side Refrigerator
Water leakage in and below freezer on Maytag MFD2560HES
you have a clogged defrost drain, or your ice maker (if so equipped is leaking. clogged drain can be remedied removeig drawer , andmelting ice build up behind rear panel of refrig, you see an aluminum trough that the water drips down,using a hair dryer melt all thatice out of the way to clear the drain tube(i use a steam machine i purchased from infomercial works extremly well
Feb 24, 2008 | Maytag MFD2560HES Bottom Freezer French...
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
