Oil pressure is high should I do an oil change or will that help at all?
  • 5,081 Answers
Oil pressure is the amount of hydraulic force used to move the oil through the engine parts. High pressure can be caused by
  1. wrong type of oil, 50 weight in an engine thatshould have 5W-30,
  2. plugged part of the oil system,
  3. sludge in oil passages or very dirty oil filter,
  4. internal engine part(s) being out of tolerance,
  5. clearances too tight on bearings or oil pump, or
  6. faulty sending unit or
  7. Gauge just showing high pressure.
So the first way to check is by just changing the oil, go ahead and do it. It might fix the problem.
Posted on Nov 17, 2009
    Brigadier General:
  • 4,088 Answers
The viscosity of the oil (higher number, higher viscosity) can cause high oil pressure--especially when the engine is cold. You shouldn't require any higher viscosity than 30 Wt and 10-30 Wt is great for cold weather. If you have had a fairly recent oil change (with new filter), the pressure sender on the engine block could be defective. That should be verified by checking the pressure with a mechanical gauge. Hope this helps!
Possible dsmsge from driving weeks with high oil pressure? btw 2004 GMC Yukon XL Denali
No damage will occur. Have you checked the oil pressure with a manual test gage? If not do that and please understand GM oil pressure gages are prone to reading high pressure when the sender is defective.
Jan 19, 2017 | Cars & Trucks
High oil pressure at start up
Yes it will be higher at start up owing to the oil being thicker .change the oil every 5000miles with a oil filter every third oil change and i think this will cure it use a 10/40 oil for diesel and petrol engines
Mar 30, 2014 | 2005 Dodge Ram 1500
I have a 2005 Nissan extera and the iol pressure guage stays on high v6 2 wheel drive automatic what could be the problem it does need an oil change
some say, it's good to have high oil pressure. but it is abnormal to the system. does it means there is restrictons from oil gallery that makes the oil pressure go high. any kind of motor or engine needs change oil. you had manaul recommending,when you change oil and what kind of motor oil you're going to use. change your oil filter too.
Feb 12, 2012 | Nissan Xterra Cars & Trucks
Oil pressure is still reading high even though I just changed the filter and oil.
A high oil pressure reading is a good thing, low oil pressure is something to worry about. Normally with a cold start, your oil pressure will remain high until the engine has reached operating temperature, then drop a bit, but again, high oil pressure readings are a good sign of a healthy engine. One other factor to consider is the viscosity of your oil, if your engine uses 5w30 and you switch it to a higher viscosity such as 10w40, you may also see higher oil pressure readings, so be sure you are using the correct oil for your vehicle. I hope this has helped you! :)
Jan 21, 2011 | 2001 Jeep Wrangler
Hi,i have a 1988 toyota conquest. the oil light is continously on. im thinking its the oil pump. anything else i can check before that? when rerved high,the light goes off. then, when at low rerving,it it...
CHECK OIL PRESSURE.DO A OIL CHANGE AND FILTER CHANGE SEE DOES OIL PRESSURE IMPROVES.IF NOT OIL PUMP FAULTY.WORN ENGINE BEARINGS CAUSE LOW OIL PRESSURE.OIL PRESSURE SHOULD BE 4.3 PSI AT IDLE THATS WHAT MANUAL SAID.
Sep 17, 2010 | 1988 Toyota Corolla 4 Door
Oil pressure gauge reads 80 yesterday it ran normal
The higher the oil pressure the better it is, if you had a recent oil change the oil pressure should be high. there is no problem with having high oil pressure.
Oct 14, 2009 | 2003 GMC Sierra 1500
High oil pressure in vw cabrio 1996
MY 1996 VW CABRIO HAS A HIGH OIL PRESSURE THE SWITCH IS BLOING OFF AND LOOSING OIL ANY IDEA IS IT JUST A REPLACE THE PART KIND OF JOB.. THANK YOU
Sep 25, 2009 | 1988 Volkswagen Cabriolet
Oil Pressure Suddenly Reading in High and Low Ranges
either the oil pressure sender is defective or the pressure relief ball valve in the oil pump is sticking, my money would be on the oil pump pressure relief valve ball sticking.
May 27, 2009 | 1998 Dodge Intrepid
Oil pressure too high
nothing wrong ignore and stop worrying,change oil every 6000miles and use cheapest from supermarket,change oil filter every third oil change to save money and pollution of the disposal of old oil filter.If you worried about high pressure then stop beleaving the adverts for synthetic oil and putting in oil thickening agents like slick or duckhams.You could get the sender units changes for the oil pressure but just go for a burn and enjoy and stop worrying its only a car when all is said and done
Dec 20, 2008 | 1997 Ferrari 355
I have a 2000 Pontiac Firebird with 90,000 miles on it. I put in Gunk engine cleaner and ran it for 5 minutes as directed then drained the oil. I then did an oil change (Quaker State 10-30) and put in...
The sensor can show high pressure when that is not the case, they fail high not low, take the sender out and plug in a mechanical guage to verify this, that is the only way to be 100% sure.
Sep 29, 2008 | Pontiac Firebird Cars & Trucks
376 people viewed this question
k24674
