Question about Samsung CXJ1352 13 in. TV/VCR Combo
Help with reprogramming
I need help reprograming a samsung tv-vcr combo cxb1922 using a
urc 3021w remote. There was a power outage and now I am unable to access all the cable stations. When I press menu, I am unable to reprogram. I had success before with this remote but now I have not been able to program. Please help.
  • Musicleader2 Feb 21, 2008
    I have new cable service and now only get stations 2-21. I have the remote and can get the menu, but don't understand how to have it reset the stations. My TV/VCR como is a CXB1922T but I suspect it should work the same. wkangas@comcast.net
SOURCE: tv vcr combo cannot program tv
Try pushing the volume buttons in the middle so that you are mashing both the up and down button, your menu should appear. then you can use the channel buttons for moving up and down.
Posted on Jan 09, 2008
SOURCE: How can I turn to AV without a remote control (Samsung TV/VCR 19in Combo)
I had this problem with my TV/VCR combo unit (Samsung CXC1972) after losing the remote while in the dorms. I tried a few different universal remotes and dozens of codes before I tried the Philips 3 device universal remote as pictured below with code 037 programmed into the VCR/DVD button. I can't change the volume with this code but the input key switches between line in and tv. You can also change the channel, access the menu and operate the VCR functions with the code. I bought the remote for less than $10 at Walmart so it might be worth a try, and if it doesn't work you can always bring it back. Hope this helps.98fe8a9.jpg
Posted on Jan 19, 2008
  • 476 Answers
SOURCE: My remote no longer works and I can't get the menu
You will have to disconnect the TV from the AC outlet for a few seconds(10-20) then reconnect the TV and press power. You should get the start up menu after you get a picture. What you have to do is use the vol up/dn , chnl up/dn keys to select the autoprogram setting after chosing from cable or antenna signal. the enter key should be one of the DVD keys either play or stop or some other key, you'll have to experiment a little with it. There is an owners manual available at retrevo.com in case you need it, but I am posting a brief description stated in the manual on how to do this. Chapter Summary: The STARTING SETUP function makes installing your TV/DVD easily...It leads you the Language selection, TV/CABLE selection and auto channel memory automatically...... Make sure that the antenna or cable TV system connection is made... ENTER CANCEL... Starting setup... Press POWER...The starting setup function begins and the Language setup menu appears on the screen...Press or to select your desired language, then press ENTER...... Users also looked at: Press or to select the “AUTO CH MEMORY”, then press...... 5S10101A [E] (P13-23) 23... This TV/DVD is equipped with a channel memory feature which allows channels to skip up or down to the next channel set into memory, skipping over unwanted channels...In addition to normal VHF and UHF channels, this TV/ DVD can receive up to 113 Cable TV channels...When shipped from the factory, this selection is in the CABLE position...... Press or to select “TV” or “CABLE...... Press MENU in the TV mode, then press to select option...... Cable TV chart... Press or to select “ADD” or “DELETE”, whichever function you want to perform...... The chart below is typical of many cable system channel allocations...... Press or to select “TV/CABLE...... Press press... TV/CABLE selection Automatic memory tuning... TV/CABLE AUTO CH MEMORY ADD/ DELETE... or... to select “ADD/DELETE”, then...
Posted on May 19, 2010
SOURCE: need samsung CxJ1952 universal remote code
Can anyone pls help me with the universal code of Samsung CXJ1952.
Posted on Sep 26, 2010
gopakumarg43
  • 75846 Answers
SOURCE: I need a code for our Samsung TV/VCR using a
Hello
For Combo Devices, in many cases a single code operates both parts of the device (e.g. the TV and the VCR). In other cases you need to set up two codes. For example, one for the TV and one for the VCR. Where codes are shown below as [### ###] the first code operates the first part of the device's name, and the second code operates the second part. E.G., for a TV/VCR device, the first code operates the TV and the second code operates the VCR.
Where the code is listed as [### ###] the first is for the TV and the second is for the VCR. Otherwise just the one code operates both the TV and the VCR.
0358_0942
Posted on Nov 22, 2010
How to reprogram a universal remote control?
http://www.youtube.com/watch?v=fXDdeXmJjfM
http://www.remotecentral.com/features/remotes.htm
Instructions
    • 1 Find the brand of the universal remote you own on Internet sites like Remote.com (see Resources below).
    • 2 Click on your universal remote brand on the website to find the code list for that remote.
    • 3 Check to see if your remote is preprogrammed to operate your TV, VCR, or Cable Box using the following codes: TV - 000, VCR - 000, Cable Box - 000, AUX - use VCR code 037.
    • 4 Manually turn on your device. Hold down the "Code Search" button on your remote, then press and release the device button you want to set up until it flashes.
    • 5 Push the power button repeatedly until the device turns off, then hit "Enter."
    • 6 Press any other button while the device is on to see if the device responds. If it does, you don't need to do any other programming. If it doesn't, repeat steps 4-6.
Read more: How to Reprogram a TV Remote ' eHow.com http://www.ehow.com/how_4454612_reprogram-tv-remote.html#ixzz1mji7B48P
Feb 17, 2012 | Sony DVD/VCR Combo Player
Can not control the volume on an rca
Ok to reprogram the remote and this only works if you just use the remote for the tv and the receiver. Like i was saying to reprogram the remote hold the tv button till all the top lights flash, then push the red power button, then hit the up arrow button slowly til the tv cuts off, once it cuts off hit the pound (#) button. The top lights should blink three times, that should reprogram the remote, If it is a tv/vcr combo or a tv/dvd combo then there isnt a code for it. Also there is a series of years that the rca tv's wont take a full code and u can just control the power and the tv channel
Sep 05, 2010 | DISH Network IR Remote Control
I need the code to reprogram my Symphonic tv/dvd/vcr with a GE Universal Remote 24944
Symphonic tv codes are 0053 0189 0227 0456 0024
tv/dvd combos 0456
dvd/vcr combo 0456 {0458 & 0227}
{0899 & 0236}
hope this helps if not i can scan the code list for you
Jun 16, 2010 | Universal Remote Control GE174Universal...
I need code for URC-3220 Universal remote control for toshiba tv/vcr in one.
I can help you reprogram your URC-3220 Universal Remote for your Toshiba TV/VCR Combo.
The Toshiba TV/VCR Combo codes are 1145 & 0845.
Please review my Fixya Tip posts for:
TV/VCR/DVD Combo Codes
Searching for the proper codes, or
Downloading the URC-3220 users manual / owners guide.
I hope that helps.
Apr 07, 2010 | Universal Remote Control Remote Control
Have a combination DVD / VCR unit. Controller works on DVD side only. Would it help to reprogram it?
Yes, I recommend reprogramming it.
Note that you must program the combo codes for both the DVD and the VCR function button.
I hope that helps.
_______________________________________________
Reassign URC-3021 Device Key
Urc-3021 Code List Download
One For All URC-3021 Code Search
One For All URC-3021 Code Entry.
Apr 03, 2010 | One For All URC-3021 Remote Control
Need code for philips vcr/tv combo
I can help you with your URC-3021 Universal Remote Control issues.
I do not see a listing for Philips TV/VCR Combos in the Urc-3021 Code List.
But don't give up; many manufacturer's re-use other's control codes.
Therefore, I recommend using the One For All URC-3021 Code Search feature to find the compatible codes to control your device.
I hope that helps.
Feb 14, 2010 | One For All URC-3021 Remote Control
What code do you use to reprogram a universal remote to a memorex tv/vcr/dvd
The codes for Memorex TV /VCR/DVD Combos are: 0162, & 1237.
For complete instructions on entering the URC-3021 remote codes, please refer to my posted Fixya Tip One For All URC-3021 Code Entry.
I hope that helps.
Jan 01, 2010 | One For All URC-3021 Remote Control
Please i need a code for a samsung tv, vcr, combo please
The Links for your remote are here
Product
http://www.oneforall-na.com/remote.php?type=URC%203021
Code for your TV is a four digit code, one of these 1075 0820
Programming instructions.
http://www.oneforall-na.com/set_up_remote.php
Code page
http://www.oneforall-na.com/list_codes.php?db_value=expert4&remote_choice=URC%203021
If these help Please don't forget to rate it FIXIT!
Charles
Jan 08, 2009 | One For All URC-3021 Remote Control
Tv vcr combo cannot program tv
Dec 02, 2007 | Emerson EWC1902 19 in. TV/VCR Combo
Samsung CXJ1352 13 in. TV/VCR Combo Logo
Jerry Greenberg
Jerry Greenberg
