Question about Sony Ericsson Z750i Cellular Phone
Sony Z7501 sometimes won't turn on. Charging battery does not seem to hold as it just shows continuously as charging. Intermittently no voice path either way.
Tip
Battery keeps dying for no reason:
Is your Battery good or bad?
Sometimes a battery seems ok then later it seems dead. sometimes it charges and then it won't take a charge. This keeps going on and doesn't really seem like the battery is bad. This is a common problem happening to everyone at times.
Could be a dead cell in the battery, try measuring each cell in the battery. If one cell is low it will seem like a dead battery. But the battery really needs to be replaced. The debris in the bottom of the cell is intermittently shorting the cell.
Hope this helps.
on Apr 23, 2015 | Cars & Trucks
Sony Vaio P Series Netbook shows its charging but stills stays at 1percent availabe almost 3hours
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced.
Aug 12, 2012 | Sony VAIO VGN-CR205E/P Notebook
WHITE OUTDOOR ZERO TURN MOWER MODEL #13AT626G190 WON'T STAY RUNNING AS BATTERY GOES DEAD HOW CAN I CHECK THE CHARGING SYSTEM?
put a volt meter on the battery then start it and check the voltage before and after if it is not more running it's not working if it is not charging remove the top cover from the engine and see if mice chewed the wires
Jul 04, 2012 | Garden
I have a sony cybershot dsc w120 camera and it turns on and maybe lets me take 1 or 2 pictures before shutting off (sometimes with the lens still out). It hasn't been dropped or exposed to water, so I
Things to check first for a camera that won't turn on, or works intermittently are the battery contact points, ensuring that they're clean, and making good contact with the battery. Troubleshooting tips on other things that need to be checked may be seen here. These tips won't work for every case, but they're worth a try.
Nov 23, 2011 | Sony Cyber-shot DSC-W120 Digital Camera
Battery won't fully charge. Max charge seems to be slowly going down. First noticed charging light coming on intermittently but battery only reached about 93%. 4 days later and the max charging seems to...
It seems that the issues is with the battery itself, not the cppu.
To double check, you can do the following:
1. Disconnect adapter and run battery completely dead.
2. Reconnect adapter and let charge for at leasst 12 hours OR until battery displays 100% charge.
If it still won't charge to 100%, then you know for sure the battery is defective/worn out..
If you want to know more about this, look on wikipedia for: "Laptop Battery Lifespan" or "Laptop Battery Memory Charging".
But I'd say it's safe to assume that it's time for a new replacement battery for your Notebook PC.
Hope this helps!
Apr 14, 2011 | Gateway E-475M Notebook
Charger not working
your batteries sound like they need replacing
Sep 17, 2017 | Maha Group Maha PowerEx MH-C800S 2-Hour...
My phone will not show it charging and will not turn on, red light flashing
dear
you have mentioned that ur phone is charging and not getting on. that means ON\OFF path is having problem .due to dry solder of ON\OFF switch its happening. please resolder it and then check it
Nov 06, 2007 | Cell Phones
Sony Ericsson Z750i Cellular Phone Logo
155 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
270rexton
270rexton
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
