Question about Hannspree 22" widescreen LCD Flat Panel HD Monitor
Screen is shaking and going in and out - Hannspree 22" widescreen LCD Flat Panel HD Monitor
Black screen taxk bar shaking
What Operating System are you using? it sounds like the Screen itself mat be faulty.
When you say it's shaking does it look like the screen is shaking or is it the picture on the screen.
Is the screen itself completely black and only the Taskbar is showing?
Apr 26, 2013 | Sony VAIO Computers & Internet
Screen shakes and red lines go through screen?
can you tell me the brand and model number of the set?
Dec 04, 2012 | Televison & Video
My lenovo y410 screen keeps shaking
Go to BIOS and check if the screen will shake in there if not try to uninstall and re-install the video driver that you have. If the screen is also shaking in BIOS it means there is something wrong with your video card.
Nov 19, 2012 | Lenovo 3000 Y410 Laptop
My psp screen shakes anytime i try to load a game from my memory card even if i reset the cfw enabler and try to load a game it still shakes and becomes slow please kindly advise me on what to do.
Go to Home screen, press menu, go to XMD speed .. may be your speed is at slow value .. change to higher, say above 222mhz and that will solve the problem .. enjoy ..
Apr 05, 2011 | Video Game Consoles & Games
My psp slim screen is shaking!
turn of your psp
1.turn on the psp by holding the (R trigger) you will be in the recovery menu
2.scroll down to CPU SPEED and change the xmb to default and game to default
this should work
Mar 29, 2010 | Sony PlayStation Portable (PSP) Console
Screen vibrates intermittantly. Also buzzing noise.
This is a problem with the lens gyro we can keep it from shaking it requires the camera to be taken apart and amodification done to the lens repair cost 65.00 in most cases.
May 14, 2009 | Sony Cyber-shot DSC-T70 Digital Camera
Nintendo ds
I have a similar problem with my bottom screen. when I started using it it was fine, but then it started to shake. calibrating it didn't do anything. and what's weird is that the screen only shakes in the nintendo ds menu. it doesn't shake during games. and it still works just fine technically, just...shakes...during things like pictochat and startup. weird...
Aug 31, 2008 | Nintendo DS Console
Screen is shaking
This is usually an indication that either the screen or the screen inverter is going out.
Jul 08, 2008 | Acer TravelMate 2300 Notebook
Screen Shaking/Vibrating
Yeah, Degaussing is basically resetting the magnetic field inside the monitor. go into the menu options, and search for that option. if this does not work, then your monitor is really old, and needs replacing.
Jan 26, 2008 | Batesias V172RTNRA 17 in. LCD Television
Shaking screen
Check the 9v regulator Ic2p01 on the signal board for correct regulation 8.9 to 9.1 volts. If voltage at the output is under 8.9v, replace the regulator Ic. Always replace C2p05 100 Ufd 16 V on this set and that should take care of the shakes but you may want the tech to go ahead and ESR some of the other troublesome caps throughout the Tv. He'll know what you mean. Many of the 100mf caps replace automatically. Several others will have a questionable ESR and should be replaced. Caps are inexpensive, but probing with an ESR meter is somewhat labor intensive so you miht discuss with the tech just how far you want him to go testing for bad caps.
A Mits is a great Tv and this repair is clearly worth it..
Bill
Dec 19, 2007 | Mitsubishi VS-45607 45" Rear Projection...
Hannspree 22" widescreen LCD Flat Panel HD Monitor Logo
44 people viewed this question
Top Hannspree Computers & Internet Experts
justwinwin
Computer Links
Are you a Hannspree Computer and Internet Expert? Answer questions, earn points and help others
