Question about Tilia FoodSaver VAC420
Foodsaver V2490 will vacuum but will not automatically stop and seal. Can you help
I experienced the very same problem. Pulled out the two foam seals, rinsed them under a cold water tap, wiped off with a tea towel, reinserted,
Posted on Sep 27, 2010
  • 5 more comments
  • oxy53 Sep 27, 2010
    The narrative, for some reason, was cut short. Again, pulled out the two foam seals, rinsed under cold water, wiped with a tea towel, reinserted somewhat damp, and, presto, just like new.
  • sbilinski
    sbilinski May 07, 2012
    Oxy53,
    I had the same problem and wow your solution was genius. My 10 year old machine works like new as well after cleaning the seals. Thank you so much!!
    SB54
  • riderdiver
    riderdiver Nov 12, 2012
    It works!!!!
  • Kathy
    Kathy Oct 15, 2013
    Wow! Thanks! Mine wouldn't vacuum the canisters or the bags. Just ran and ran and ran. I removed the 2 gaskets as well, cleaned them with cold water and it works like new!!
  • Michelle
    Michelle Jan 06, 2015
    Amazing!! Thank you so much for posting this easy FIX!!
  • Marcy Smith
    Marcy Smith Sep 17, 2016
    I found a nice one at a thrift store yesterday.it seals perfectly but it wouldn't vacuum all the air out and would not shut off.I did as Kathy said and it worked perfectly! Thank you so much!!!
  • swakida Oct 26, 2017
    It works!!!!! 'nuff said. Thanks! Oxy53
    President:
  • 1,335 Answers
Assuming the unit coil is not defective, this indicates that you are not getting a complete vacuum seal.
Make sure the ends the open end are in the vacuum chamber and that they are laying flat (a crease will allow leakage).
Turn on the vacuum and press down on the cover (this is to check to make sure a good vacuum seal is being provided by the oval gasket).
The air should be vacated, the heating light should come on and seal the bag.
If it is the gasket that is not properly sealing, you can order a replacement from the www.foodsaver.com.
Let me know if this solves your problem.
Please rate this solution. Thanks.
Posted on Nov 17, 2009
There is a key distinction here to observe.
If the unit is not pulling the air out of bag then it is quite likely that you do not have a good seal or there is a leak within the unit.
However if the unit is removing the air from the bag and you can hear the pitch of the pump increase but the unit will not automatically advance to sealing, it is likely the vacuum sensor has failed or its solder joints have failed and it has become detached electrically from the circuit board inside the unit.
Posted on Dec 28, 2018
My foodsaver rattles when vacnmming
Posted on Jul 02, 2011
SOURCE:
Not sealing
I have the same problem on my V2490. Will not heat to seal or create bags. So I took it apart! The heating element is only heating at the ends. Since Tilia doesn't repair or sell parts, I found a cite that carries replacement items.
www.elementandteflon.com/product/HE-14-FS
I don't know how if a replacement element will help. I am trying to find a wiring diagram to make sure i do it right...
Sep 19, 2010 | Tilia FoodSaver VAC420
I have an older model Foodsaver. The machine will
This is likely happening because the unit cannot detect that a vacuum has formed, and the gaskets around the vacuum channel are the probable culprit. The Foodsaver gaskets will deform and/or dry out with time, just like in any device, but you don't necessarily have to replace them. I've tried this inexpensive solution on my own Foodsaver V2490, and it works perfectly.
Buy some food-grade silicone grease and apply it to both the upper and lower gaskets. I remove the gaskets and coat both sides with a thin layer of grease before replacing them in their respective channels. And since this grease will be absorbed and/or dry out with time, you will have to do this occasionally, so I also flip the gaskets (i.e. turn them over) whenever I apply the grease.
You can buy a 2 oz container of silicone grease at any dive store, or you can buy it over the Internet by searching for "Trident silicone grease".
This is a link where you can buy it for around $7.00:
Dolphin Dive Center
I do not work at this dive center, but I am a scuba diver and already had some grease that I use for the numerous rubber gaskets in my gear. The 2 oz. jar will last you several years, and you will find many other uses for it around the house since the grease will last longer than a spray.
Jul 24, 2010 | Tilia FoodSaver V2240
Foodsaver will not seal and light will not turn on or off
This is likely happening because the unit cannot detect that a vacuum has formed, and as a result, the unit never "turns on" the heating element to seal the bag, with the gaskets around the vacuum channel being the probable culprit.
Dolphin Dive Center
Jul 21, 2010 | Tilia Foodsaver V835 Vacuum Sealer
Foodsaver Food Sealer Vacuum V2240 T: Foodsaver Professional II Turbo. Vacuum pump work...
This is likely happening because the unit cannot detect that a vacuum has formed, and as a result, the unit never "turns on" the heating element to seal the bag, with the gaskets around the vacuum channel being the probable culprit. The Foodsaver gaskets will deform and/or dry out with time, just like in any device, but you don't necessarily have to replace them. I've tried this inexpensive solution on my own Foodsaver V2490, and it works perfectly.
Dolphin Dive Center
May 17, 2010 | Tilia FoodSaver V2240
My foodsaver Vac 420 Vacuum Sealer won't heat and seal the bags.
This is likely happening because the unit cannot detect that a vacuum has formed, and because of this, the unit will not seal the bags, with the gaskets around the vacuum channel being the probable culprit. The Foodsaver gaskets will deform and/or dry out with time, just like in any device, but you don't necessarily have to replace them. I've tried this inexpensive solution on my own Foodsaver V2490, and it works perfectly.
Dolphin Dive Center
Mar 29, 2010 | Tilia FoodSaver VAC420
Vacuum on foodsaver II seems to have slowed down or quit working any suggestions? and at times seal doesn't work. any parts source?
The Foodsaver gaskets will deform and/or dry out with time, just like in any device, and this will result in no vacuum or a very slow process, but you don't necessarily have to replace them. I've tried this inexpensive solution on my own Foodsaver V2490, and it works perfectly.
Dolphin Dive Center
Feb 26, 2010 | Tilia FoodSaver VAC420
Can you purchase a replacement seal/gasket for the Foodsaver vac420
I posted this solution for other problems - it might help you, too:
Dolphin Dive Center
Dec 10, 2009 | Tilia FoodSaver VAC420
I have a foodsaver tilia,,and don't know how to use it...I can make it seal but don't get it to pull a vacumn..
Dolphin Dive Center
Nov 05, 2009 | Tilia FoodSaver V2240
My foodsaver v2490 will not vaccum the air out the bags...it is almost new with very little use
the problems with vac is allmost allways the gasket or the tubing in the unit there is a few fittings that get britlle over time and the heat in the unit and the china parts dont help i have got a bunch of these broken units on ebay and fix with drip irr fittings
Oct 21, 2009 | Tilia FoodSaver VAC420
Foodsaver vac1050 wont stop runing go to 3 bars thats it
Dolphin Dive Center
Aug 12, 2009 | Tilia Foodsaver V835 Vacuum Sealer
Tilia FoodSaver VAC420 Logo
11,263 people viewed this question
Top Tilia Kitchen Appliances - Others Experts
elementsandt
Level 1 Expert
Sheldon Dedek
Vitally Alcher
Are you a Tilia Kitchen Appliances - Other Expert? Answer questions, earn points and help others
