Question about Honeywell Heating & Cooling
My Honeywell thermostat does not heat the house to the selected temperature. It will come on but not long enough to heat the house to the temp I selected.
My thermostat says it's 62 degrees inside, but I don't know how to set it for 70 degrees?
Posted on Nov 08, 2011
    Scholar:
  • 111 Answers
Verify that you have heat coming from the vents.
Also do you use a heat pump system with electric emergency heat?
It may be that if it is to cold outside that the heat pump can not handle the load due to the cold outside and you will need to turn on the emergency heat.
Keep me posted.
FlaTech.
Thank you for using FixYa!
I’m happy to help further over the phone at https://www.6ya.com/expert/michael_341f3f9dee622e54
Posted on Nov 17, 2009
Can I manually override a Honeywell 69-0940-2? I don't want to program it. Just want to turn the air on for a few hours to cool the house. Thanks
That thermostat cannot be overridden to remove the seven day schedule. If you select you desired mode (HEAT or COOL) using the SYSTEM button, then using the UP or DOWN arrows next to the screen to set your desired temperature, finally press the HOLD TEMP button to lock that setting in. It should stay there until you press hold temp again, make a temperature set point adjustment, or a loss of power. These thermostats are kinda complicated for the everyday user and were usually installed in commercial buildings where the end user's access was limited. Hope this helps. I also provided a link to the Honeywell Manual. http://www.transtaracsupply.com/pdf/t8600manuel.pdf
Dec 13, 2017 | Honeywell Heating & Cooling
Thermostat does not reach programmed temperature
Have you checked with a thermometer to see if the area is reaching the temp you have it set at? A thermostat has nothing to do with the temp in your house. If you have it set at a temp for Example ( 72 ) and it is not reaching that temp to shut off then you have a problem with your unit or insulation in house. If you set stat on cool at 72 and the house gets down lower than 72 then there is a problem with stat.
Dec 19, 2014 | Honeywell CT500 Digital Heat / Cool Manual...
Honeywell emm-3 goes to high heat when thermostat does not call for heat
Replace it (thermostat), but first make sure its in a good location to read the space temperature.
Nov 29, 2013 | Heating & Cooling
How can I set fan speed manually to balance temperature in house?
Basements are supposed to be cooler . after all they are basically a cave .
Oct 17, 2017 | Honeywell Electronic Programmable...
Can't increase the heat on the thermostat
Instructions1 On nearly every Honeywell thermostat, the heat setting can be increased by simply pressing the HEAT option or AUTO and using the arrow keys to adjust the setting higher or lower until the desired temperature is reached.
2 To set an automatic heating schedule for Wake, Leave, Return and Sleep, press the SCHEDULE button, then EDIT.
3 Select the current day and use arrows to select the time and temperature for Wake. For example, if you typically awake for work at 6:00 a.m. and want the heat to come on, use that as your Wake time and adjust the temperature to suit.
4 Select the day and use arrows to select the time and temperature for Leave. Since you will be leaving the home empty for several hours, this setting will allow the thermostat to lower the heat until your arrival back home.
5 Select the day and use arrows to select the time and temperature for Return. This is the time and temperature that you will choose for returning home from work and may want the heat on to warm the house for your arrival.
6 Select the day and use arrows to select the time and temperature for Sleep. Set the time you normally go to bed. The thermostat will automatically adjust itself to your selected temperature at that time.
Thanks
Apr 01, 2012 | Lakewood 2096ET Oil Filled Radiator Heater
Indoor temp is 5 degrees colder than display reads on digital thermostat
Where are you measuring the indoor temperature?
To compare it to the thermostat temperature you have to measure both temperatures at thermostat.
The thermostat will only control the temperature at the thermostat, not any where else in the room.
The room temperature depending on insulation in walls and ceiling and distance from outside wall and outside temperature, can be as high as 10° difference from outside wall to inside wall of house.
The lower the outside temperature, the greater the room difference in heating. The higher the outside temperature the greater the room difference in cooling.
Feb 13, 2010 | Honeywell Programmable Thermostat Heater
My round Honeywell T-87 on the main floor(middle) of the house has no ON/OFF switch. It controls the temp of that level of the house and even though it is set at 60, the temp is way too high and reads 74....
What you are describing is the Heat Anticipator. It is a small resistor that helps the thermostat from overshooting the set temperature by heating up and shutting off the thermostat just before your set temperature. I don't think that is related to your over heat. 14 degrees is a lot and the Heat Anticipator will only effect it 4 or 5 degrees. I would remove the thermostat and check if there is a call for heat. If so, you have a shorted wire. If not, replace the thermostat.
Dec 30, 2009 | Honeywell Programmable Thermostat Heater
Honeywell Digital Thermostat won't click on if temp is below 59
do you live there? if so here are the rules for setting back temperature: do not lower the temperature more than 8 degrees F from the temperature you want it when your there, setting it back for periods of less than eight hours is also somewhat futile. Due to laws of thermo-dynamics the heat required to recover from more extreme setbacks or shorter periods of time exceeds the savings acquired by taking said action. As to your question directly there are no reasons why your thermostat should not function at any setpoint temperature that it is allowed to set to (45 normally being the lowest) if it does not function below 58 degrees it has a failure and should be replaced before it fails completely. Suggest a Robertshaw or Braeburn brand thermostat, Honeywell quality has slipped over the past decade to unacceptable levels. Unless your considering a Hunter in which case buy another Honeywell.
Dec 17, 2008 | Honeywell Programmable Thermostat Heater
Loss of temperature control
Is the heater staying on all the time? Most likely cause of themostat trouble is the sensor. Try to find it and measure its resistance at different temps to verify the trouble.
Dec 31, 2007 | Honeywell CT3200 5-2 Day Electronic...
Heating & Cooling Logo
208 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
