Question about Dell Inspiron 1525 Notebook
While plugged in, my monitor goes dark. i tried changing outlets and it didn't help
  • 460 Answers
You need to replace the laptops power supply..
Posted on Nov 17, 2009
Lg flatron w2353vp
make sure the 'VGA' lead is plugged in properly. if still dark turn up the brightness on the monitor. if still dark after that, go onto the computer settings and turn up the brightness on the display settings.
Hope this helps!!!
Feb 21, 2014 | Computers & Internet
Screen goes black or pixelates
1. Verify the monitor's power cord is plugged firmly into the wall outlet and the back of the monitor.
2. Verify the monitor cable is firmly connected to the computer and the monitor.
3. Verify that you have turned the monitor power switch on.
4. If the power light on the monitor is not on, test the wall outlet (plug in a light or something you know works).
5. If the power light on the monitor is not on, try a different power cord.
6. If the power light is on and yellow or flashing, but nothing displays, or the display is incorrect, borrow a monitor from a friend. If that works, your monitor probably needs replaced.
7. Also, you could try your display on a friend's computer. If it doesn't work, your monitor probably needs replaced. If it works properly on your friends computer, the problem may be with your computers video output port, motherboard video chip (or video card, if you have one), or drivers.
Aug 18, 2013 | ViewSonic VX715 17" LCD Monitor
Photos flicker then get dark
You directed this question at me, but unfortunately I'm unable to provide you with a "real" solution at this time. FixYa has informed me that by providing you with this "solution" your question will then be made visible to other experts; hopefully one of them will be able to provide you with a real solution.
It would also help if you could tell us what device or accessory you're referring to.
Thank you for using FixYa.
Nov 16, 2011 | Cameras
My viewsonic vx1940w monitor won't turn on. There's no lights or anything. The outlet it's plugged into is working because I tried another device in the same outlet. My settings didn't...
I had two ViewSonic's that did the same thing right around 2 year as well. They worked really well for me and then just died.
I found out the first one had a faulty power cord, and the second one just wouldn't turn on at all.
I think there's a good chance that your monitor bit the big one just based on my experience with the brand. I would recommend taking it in to your local computer repair shop and let them take a look at it. If it is 2 years old then it is probably out of the manufacturer's warranty unfortunately. I hope this helps answer your question :(
Thanks for using FixYa.
Aug 27, 2011 | ViewSonic VX1940w LCD Monitor
My LG 17" CRT monitor , screen is blinking rapidly with slightly dark shadow. pl. help
If it is an older monitor, this may just be a sign of aging. It is possible that the adjustment knobs and buttons on the front, bottom, or side of the monitor may have been moved. Try adjusting those to see if you can tone out the problem. Also check to make sure the monitor cable is secure to both the monitor and the computer. You may also try plugging the monitor's power cable into a different outlet. Finally, you could try adjusting your video properties in Windows, but that's probably not the problem unless you have been in there before.
Jul 20, 2010 | LG Flatron F700P 17" CRT Monitor
Scanport N9 Monitor Model #M19FBK flashes one time and goes dark.
Not likely it got damaged in the move.
Make sure the plugs are firmly seated. That is, the power cord and the video plug at both ends.
Apr 18, 2010 | Scanport N9 19" LCD Monitor
Monitor turns on for 3 secs then goes black. Monitor will not stay on
try changing into different wall outlet,switch plugs monitor/pc
Oct 20, 2009 | LG W1934S-BN 19" Monitor
Dark screen
reset your monitor settings with deafaults with menu.u see some buton on lcd or monitor.
Dec 29, 2008 | ViewSonic VG900 19" Flat Panel LCD Monitor
Power Supply
Check all power cables plugged into M/board if these are correct
remove all hard ware
hard drives / cd player and anything else
except for video and memory and test to see if it boots. If it does, one of the removed hardware is faulty if it does not then you have M/board failure
Aug 02, 2008 | E-Machines Emachine T5026 power supply **...
Dell Inspiron 1525 Notebook Logo
90 people viewed this question
Alun Cox
